AHHHHH No noise!!!
Discussion in 'Tonefreaks' started by GammyBird, Aug 28, 2013.
  1. GammyBird
    GammyBird Senior Member
    20,986
    14,124
    Nov 14, 2009
    Well yes there is noise, but not what I'm looking for.
    I plugged in my lp this evening and was met with a buzz sound from my amp.
    Checked amp with another guitar. Pass
    Switched cables. Pass
    Changed input jack. Pass
    Checked and rechecked wiring for bad connections. Pass.
    Suggestions?
    slapshot likes this.
  2. LeftyF2003
    LeftyF2003 Senior Member
    7,467
    8,734
    Mar 2, 2010
    Did you try all the pickup settings? Can you plug it into another playback device for testing? Have you changed anything on the guitar recently? Also try switching the pickup switch a few times to see if maybe the switch has become intermittent.
    Hope this helps
  3. GammyBird
    20,986
    14,124
    Nov 14, 2009
    No changes made to the guitar lately Lefty. Have diddled all the knobs and switch. I can just barely hear the guitar under the buzzing sound as well.
    1 person likes this.
  4. LeftyF2003
    7,467
    8,734
    Mar 2, 2010
    Wow that's very odd. Seems like something must have failed. Most likely something common to both pickups like the switch or output jack, and it sounds like you've ruled out the jack.
  5. GammyBird
    20,986
    14,124
    Nov 14, 2009
    And of course I don't have another switch on hand to test that. :hmm:
  6. AngryHatter
    AngryHatter Senior Member
    17,185
    13,105
    Jun 19, 2009
    Buy a fender and then you'll assume you are the source of all the noise in the universe.
    2 people like this.
  7. AngryHatter
    17,185
    13,105
    Jun 19, 2009
    EDIT: Open the switch cavity and spray some contact cleaner. Or look for broken ground.
  8. Ozzy Mandeus
    Ozzy Mandeus Senior Member
    2,899
    3,922
    Feb 9, 2013
    I'd go with a broken ground too, especially if the buzz gets worse with the volumes turned right down.
  9. michaelinokc
    michaelinokc Senior Member
    6,772
    9,773
    Jan 27, 2012
    Turn your volume knob up past 0. :naughty:
  10. GammyBird
    20,986
    14,124
    Nov 14, 2009
    I walked away from it for bit thinking it was the toggle switch. A quick look a few minutes ago revealed the ground wire had come loose. Fixed :cool:
    2 people like this.
  11. GammyBird
    20,986
    14,124
    Nov 14, 2009
    :thumbs:
    2 people like this.
  12. DPaulCustom
    DPaulCustom Senior Member
    2,219
    1,384
    Feb 17, 2011
    Glad you got it worked out, nice family photo BTW
  13. LeftyF2003
    7,467
    8,734
    Mar 2, 2010
    Glad it's fixed - sorry, should have said ground as that's the other common connection...
  14. emptyisvarah
    emptyisvarah Senior Member
    2,466
    1,874
    Oct 12, 2010
    i told you a million times pat, dont play the guitar while riding a bull, everything will come loose :D
  15. GammyBird
    20,986
    14,124
    Nov 14, 2009
    Imagine how loose everything would become if the bull was riding me :shock:
  16. emptyisvarah
    2,466
    1,874
    Oct 12, 2010
