Advice on best effects loop design!
Discussion in 'The Squawk Box' started by Freddy G, Mar 8, 2018.
  1. Freddy G
    Freddy G V.I.P. Member
    11,869
    25,479
    Mar 18, 2007
    Hey you amp gurus!
    I would kindly appreciate your input (bada boom!) on which effects loop designs you like and why.
    I want to install them in some of my amps....particularly my Hiwatt and also a matched pair of homebrew amps.
    Thanks in advance!
  2. bilbarstow
    bilbarstow Premium Member
    2,736
    3,835
    Apr 1, 2011
    I remember that Don (Soul Tramp) did a bunch of work to determine that for his amps. You might ask him directly ?
    bulletproof likes this.
  3. Lungo
    Lungo Senior Member
    6,547
    9,597
    Feb 19, 2009
    I'm not sure if this applies, but I like foot switchable effects loops. I've owned Mesa Boogie amps with that feature and it really came in handy.
    bulletproof and Freddy G like this.
  4. mmd
    mmd Senior Member
    2,474
    2,417
    Sep 24, 2012
    I prefer tube-driven, parallel effects loops with send and return controls, footswitch-able (of course). I prefer this design for a couple of reasons.
    First, being parallel, I always have some original signal in the "blend". Much like adding effects in a mix, my guitar sound stays more focused when not drenched/saturated by the effect.
    I like tube driven because, if I am choosing to not use any effects I have an extra gain stage (my Riveras have this and it works great as a tube driven boost) - plus it works as a great buffer.
    The variable send/return is ESSENTIAL for me (and as a recording dude, you'll get this) because it lets me get the best signal/noise ratio along with blend/ratio of wet/dry signal. I can dial in my effect the way it sounds best at the unit (pedal or rack, though I usually still use rack units in the loop), and then have control of the "mix" at the amp too.
  5. Freddy G
    11,869
    25,479
    Mar 18, 2007
  6. Soul Tramp
    Soul Tramp Speaker Snob V.I.P. Member
    6,528
    15,065
    Jul 19, 2012
    Freddy, here are the features of the loop I designed after considerable trail & error:
    1) Tube buffered
    2) Tube gain recovery stage on return
    3) Toggle to bypass loop and remove from signal path (loops can be a bit of a tone suck)
    3) Toggle to switch the loop between parallel and serial modes (some pedal work better in one mode vs the other)
    4) Knob to adjust the loop gain
    5) Knob to mix the wet and dry signals
    cooljuk and RAG7890 like this.
  7. Freddy G
    11,869
    25,479
    Mar 18, 2007
    OK...Sounds like you've covered all the bases! Do you sell these babies?
  8. Soul Tramp
    6,528
    15,065
    Jul 19, 2012
    I sorry, but I don't sell them. I'm apprehensive about my schematic getting out into the public domain.
  9. Freddy G
    11,869
    25,479
    Mar 18, 2007
    Booo!
    Bummer. Oh well.. can you recommend one?
  10. Soul Tramp
    6,528
    15,065
    Jul 19, 2012
    I'm sorry Freddy, but I don't keep up with what's on the market. Are you able to design your own circuit (with help)?
  11. Freddy G
    11,869
    25,479
    Mar 18, 2007
    Sure, I don't think I need parallel.... just series. All I want to do is insert time based effects....delay, modulation and reverb. And also preamp channel switching.
  12. Soul Tramp
    6,528
    15,065
    Jul 19, 2012
    A serial loop is fairly simple. A quick google search brought up the following schematic that looks fine. It has all the features you'd need.
    http://www.blueguitar.org/new/schem/misc_mod/fx_loop.gif
  13. Freddy G
    11,869
    25,479
    Mar 18, 2007
    Thanks Don.
    That does look simple....I don't think I'll even bother etching boards for that!
  14. Soul Tramp
    6,528
    15,065
    Jul 19, 2012
    It would be a simple turret or eyelet board. Are you able to fab either?
  15. Freddy G
    11,869
    25,479
    Mar 18, 2007
    Yeah...I've got some turrets left over from a mic pre I built:
  16. Soul Tramp
    6,528
    15,065
    Jul 19, 2012
    If you need board material, I have FR4 G10 glass epoxy I use for my boards, I can send you.
  17. KP11520
    KP11520 Senior Member
    6,473
    7,216
    Apr 11, 2014
    Could you please share this journey on this or another thread?
    I'd bet many would love to have an effective FX loop modded into their amps that don't have one. Thanks!
  18. Freddy G
    11,869
    25,479
    Mar 18, 2007
    thanks Don....I have the material I need.
    Sure.
    Soul Tramp likes this.
  19. KP11520
    6,473
    7,216
    Apr 11, 2014
    THANKS! Yeah, I'm a wannabe NERD!
    I'm looking forward to it!
  20. RAG7890
    RAG7890 Premium Member
    14,904
    23,828
    Jul 11, 2010
    Freddy I believe lot of people just buy the Metroplex Loop that George developed?
    I think this is what Dave Friedman uses & it's a great Loop............& you can buy them.
    Cheers, Rudi
