ABR-1 flushed down when changing strings
Discussion in 'Historics & Reissues' started by MarcBolas, Aug 17, 2017.
  1. MarcBolas
    MarcBolas Junior Member
    23
    33
    Jun 2, 2016
    Hello fellas,
    I recently bought my first CS LP: a lovely 2014 R8 VOS in lemonburst. A couple of days ago I decided to put a fresh set of strings on it, and well, refer to the title of the thread. When I was done winding the strings I realized that the bridge was flushed all the way down into the body of the guitar (more so on the lower strings)! See attached picture for reference.
    I panicked a little bit, then released some string tension and adjusted the bridge up a bit. It seems like intonation didn't suffer, and the action is almost as good as it was before (the action was one of my favorite things about how the guitar felt when I bought it).
    Anyway, I wanted to ask if this is normal or if I should be concerned.
    Thank you!
  2. LeftyF2003
    LeftyF2003 Premium Member
    7,250
    8,157
    Mar 2, 2010
    That is quite low, but the good news for you is you can deck the tailpiece and get some more sustain. If you can get a descent action then it's all good. If it were to the point that you couldn't set up the guitar then I'd be concerned that you'd need a neck reset.
  3. MarcBolas
    23
    33
    Jun 2, 2016
    Thank you for the response! Not sure I understand the neck reset part. The bridge just dropped down after I took the strings off, it wasn't like that before. I was able to use the wheels to bring it back up after I had put the strings on (I had to lower the tension a bit), and now it seems to be fine. My concern was the fact that the bridge sort of fell down on its own when I took the strings off.
  4. cooljuk
    13,774
    16,971
    Mar 12, 2009
    Tape your thumbwheels to the bridge with some blue painter's tape when you are changing strings to keep them from spinning around and adjusting themselves.
    You can use a rubber band, also. Like a figure 8 over the bridge. Then you cut the old strings off and they slip out from under it. That will hold it in place until you put the new ones on.
    Along those lines, if your tailpiece falls off when you change strings, lower one side and raise the other to lock it in. Locking tailpieces my ass! A quarter or half turn in opposite directions of the tail studs will lock a tailpiece in place.
    Trogly, DrSte31n, Who and 3 others like this.
  5. PierM
    PierM Premium Member
    2,353
    3,004
    Aug 19, 2016
    Did you buy used or new? Sounds like your thumb-wheels, and/or the posts, are not matching...so that the bridge is "falling" down with thumbwheels because the thread holes are probably too wide for the posts. If I'm right, you need the string tension to pull the thumb-wheels against the posts, and this is preventing the "gravity" to work. :)
  6. Rocco Crocco
    Rocco Crocco Senior Member
    6,488
    7,632
    Feb 8, 2013
    Great tip for the tailpiece... thanks!
  7. LeftyF2003
    7,250
    8,157
    Mar 2, 2010
    That is odd if the bridge can fall like that. As Cooljuk said you may have the wrong thumb wheels for the posts, or the posts may be stripped.
  8. MarcBolas
    23
    33
    Jun 2, 2016
    Thank you all for your replies. I hope it's something more along the lines of what Cooljuk said: that the thumb wheels just moved around when I was changing strings.
    I just ordered some new pickups and I'll take the opportunity to ask my tech for a setup and to give me his opinion on the issue.
    Thanks again.
  9. cooljuk
    13,774
    16,971
    Mar 12, 2009
    I didn't say that. lol!
  10. DarrellV
    DarrellV About as sharp as bowlin' ball! Silver Supporter Premium Member
    12,331
    18,317
    Nov 1, 2016
    OP is happy...who's counting the score, LOL!:laugh2:
    Bonus points for the win! :dude:
    cooljuk likes this.
  11. LeftyF2003
    7,250
    8,157
    Mar 2, 2010
    Ha ha sorry, didn't mean to put words in your mouth. If OP is happy then all is well :thumb:
    (It was PierM who was suggesting an issue with the thumb wheels)
    PS - personally I try not to take all the strings off at once on my guitars with a bridge / tailpiece. If you change one string at a time you won't have an issue.
    Geronimo likes this.
  12. cooljuk
    13,774
    16,971
    Mar 12, 2009
    I'm just giving you a hard time, man. :D All good. :cheers2:
    Generally, those wheels will stay pretty well put but even a half turn or a turn will throw the action off from what it was so I like tape and/or rubber bands to be safe, myself.
    LeftyF2003 likes this.
  13. Wizard of Ozz
    Wizard of Ozz Senior Member
    110
    67
    May 6, 2011
    +1 on the tape. I've been doing that for years. Tape down the bridge and studs too.
  14. TKOjams
    TKOjams Senior Member
    10,059
    6,800
    Sep 12, 2009
    change you strings one at a time ;)
    mudface, Hope, THDNUT and 1 other person like this.
  15. cooljuk
    13,774
    16,971
    Mar 12, 2009
    Well, ok. There's that, also. ...for the graceful among us.
    At the shop, when I'm changing strings, it's generally because there's more work to be done on the guitar that the strings are in the way of. Sometimes I forget people change strings simply for replacing them. lol! I'm a "grab 'em all at once and nip with dykes" kinda guy. :thumb:
    Why does that sound dirty?
    I Break Things and RayTorvalds like this.
  16. MarcBolas
    23
    33
    Jun 2, 2016
    Thank you all for your kind replies. Indeed, I took off all the strings at once because I wanted to polish the frets and clean the fretboard.
    I Break Things and cooljuk like this.
  17. Dilver
    Dilver Senior Member
    690
    804
    Apr 26, 2011
    I'm confused by this thread. Did the bridge "drop" or did it just get lowered in the process of changing your strings? If it's the former, then as someone mentioned earlier, the bridge probably doesn't fit the posts (it should only lower by turning the the thumbwheels). If it just got lowered in the process of changing the strings, just turn the thumbwheels to raise the bridge to where you want it. No big deal.
    MarcBolas likes this.
  18. I Break Things
    I Break Things Senior Member
    2,975
    5,141
    Nov 27, 2016
    I don't even do that with a floating trem. Snip the things off and wrestle with the daggum thing to get it strung up. That's the only way to do it. Other option is set it on fire and order a new guitar.
  19. mudface
    mudface Senior Member
    3,091
    5,488
    Aug 29, 2016
    One string at a time for me unless swapping pick-ups or fret board cleaning like you said. Sometimes when cutting the strings all off, the relief of tension plays havoc on the neck and becomes a bitch to get it stable again. This happens with newer instruments than older ones that seem to build up wood tension "memory". So replacing one at a time keeps tension on the neck insuring stable tuning. This has been my experience.
  20. asapmaz
    asapmaz Senior Member
    1,290
    1,237
    Oct 13, 2011
    Almost always one-at-a-time for me, too. I don't like releasing the tension on the neck at all.
    I cringe at having to stabilize the neck after a bigger job. It takes a while for the guitar to settle in.
