A potentiometer spec. needed for 2000 LPS
Discussion in 'Gibson Les Pauls' started by jm55, Oct 18, 2018.
  1. jm55
    jm55 Member
    30
    17
    Jan 14, 2009
    I would like to do some experimenting on my 2000 LPS. I have a couple of Bourns push/pull pots here that might work, but I bought them for my Strats, and I'd like to know if they'll fit before I start pulling my electronics apart. The threaded part of the shafts are about 3/8" long. Will that be long enough?
  2. Les Paul John
    Les Paul John Senior Member
    862
    1,414
    Jun 26, 2018
    I did a quick search here and found a good thread someone made.
    You’ll want to make sure the pot is a 500k if you’re removing a 500k - there’s plenty of info online as to what difference that means for tone. Fender generally uses 250k for single coils but if it is a push pull it may have been used to split coil a humbucker and may be a 500k.
    Push pull pots generally aren’t anything special with regard to functionality other than quality.
    But anyway .... http://www.mylespaul.com/threads/what-pot-shaft-length-does-my-les-paul-take.134675/
    jm55 likes this.
  3. jm55
    jm55 Member
    30
    17
    Jan 14, 2009
    That's great! Thank you for the link. The pots I have are 500K, but they're 3/8" so it looks like I'll need some long shafts.
