A/B/Y Pedals / Boxes... Difference?
Discussion in 'Pedals' started by TrippyStormtrooper, Sep 6, 2018.
  1. TrippyStormtrooper
    TrippyStormtrooper Senior Member
    211
    337
    Sep 18, 2014
    Forgive me if this has been covered already, I couldn’t seem to find a tread on it.
    Are all A/B/Y pedals pretty much the same? As in, they shouldn’t affect tone, all they do is switch between channels/amps. Am I missing something in differences between brands?
    Wanting to pick one up for channel switching in my Black Magick Reverb. Considering the JHS mini one.
    Thanks!
  2. monty john
    monty john Senior Member
    300
    322
    Feb 11, 2010
    I had a Star Touch ABY that was grounded and was wired so it was never out of phase....great footswitches...used it on my modded vibrolux...it was used for like $50.....buy a good one with a ground lift and phase switch....the cheapo stuff won't have these options
    TrippyStormtrooper likes this.
  3. northernguitarguy
    northernguitarguy SWeAT hOg
    29,438
    49,846
    Feb 22, 2009
    I say if you're gonna do this, do it right. Don't cheap out and get an ABY that has a buffer and a polarity switch. I briefly used a Radial Twin-City pedal and it was excellent for this use.
  4. 8len8
    8len8 Senior Member
    187
    80
    Jan 24, 2014
    They are not all the same. First, think about what features you need:
    - Active vs passive (cable driving vs transparent)
    - Phase switch (if amps are out of phase)
    - Ground lift (to eliminate ground loop induced hum)
    Then there are the brands. Many cheaper passive ABYs tend to pop when you hit the switch. If you look through various forums you’ll find the most popular passive is Lehle, and the most popular active is Radial.
  5. RAG7890
    RAG7890 Premium Member
    15,043
    24,196
    Jul 11, 2010
  6. The Ballzz
    The Ballzz Senior Member
    1,561
    1,029
    Mar 28, 2013
    The OP asked about differences. The biggest difference is that a passive unit loses 3db of signal strength when both outputs are active and active units "theoretically" keep the output levels the same as the input! If simply using to switch from one amp to another and never using both at the same time, a passive unit should be fine, although having one with the outputs "isolated" from the chassis and each other so that you have ground lifting and phase switching options is a very good idea!
    Just My $.02,
    Gene
  7. northernguitarguy
    29,438
    49,846
    Feb 22, 2009
    I briefly tried the 'tone-stacking' experiment, it was fun but for me, impractical. I tried both passive and active units and I agree that an active unit is a must for 'Y' playing.
  8. Brocko
    Brocko Senior Member
    5,028
    4,925
    Jul 13, 2013
    If all you are doing is channel switching you won't need any features and passive will be just fine.
  9. northernguitarguy
    29,438
    49,846
    Feb 22, 2009
    True. But then, you could just pick up an AB footswitch. Hard to see the point of the 'Y' if it's not gonna be used.
  10. Brocko
    5,028
    4,925
    Jul 13, 2013
    well, quite.
    Although he might have an amp with two separate inputs. So an ABY would be able to switch one guitar line to between the two amp inputs
    Passive would be fine for this usage, any thing else would be overkilllllllllll
  11. TrippyStormtrooper
    211
    337
    Sep 18, 2014
    Part of the reason I want one is because I have the Supro Black Magick Reverb, which does have two channels and would allow me to channel switch.
    I Also want to experiment with using the amps channels in conjunction vs using the 1+2 Input. Should do the same thing but I’m curious.
    I’m also curious how it would sound to run one channel cleanish and the other dirty at the same time.
    Just messing around with options, I appreciate all your guys’ feedback!
    northernguitarguy likes this.
  12. northernguitarguy
    29,438
    49,846
    Feb 22, 2009
    I gave tone-stacking a shot and it was a lot of fun. It ended up being just a faze when I realized it was better off trying to just get a decent sound out of one amp, lol. I tried it first with a homemade passive true bypass pedal from a friend. It seemed cool, but I could tell I was losing a lot in Y-mode. The Radial Twin-City made a HUGE difference and I have to admit, it sounded pretty cool to split FX to two different amps and pound the strings. But yeah, it's a project for a better guitarist than yours truly.
