A 12ax7 To Give Smoother Tone?
Discussion in 'Tonefreaks' started by Classicplayer, Jul 11, 2017.
  1. Norton
    Norton Senior Member
    410
    320
    Dec 12, 2013
    I have a hard time believing you'll get that amp to smooth out much.
    It's entire purpose is to make loud distortion out of a tiny box.
    moreles likes this.
  2. kook
    kook Senior Member
    165
    41
    Dec 2, 2009
    Try a 12at7 or 12ay7
  3. moreles
    moreles Senior Member
    2,718
    1,347
    Apr 16, 2011
    The 7025WA suggestion is excellent. Those tubes are generally very reliable and balanced in tone. I much prefer them to 12ax7 tubes, the vast majority of which are noisier, fizzier, and more distorted (not in a good way) than I can stand. I like distortion and OD tones from good pedals, or power tubes, and do not want preamp tube distortion, period. You may want to look into modding the circuit itself, if you're capable of doing that work safely. I don't have your amp, but have a heavily modded Pro Junior that is my workhorse. One of the major changes I incorporated in that am was to improve the tone, and eliminate spiky, brittle highs via a few simple component changes. There may be some good info for your amp on the web. Changing the OT can do a lot for your bottom end as well, changing the balance so that the highs are not as dominant.
  4. Alligatorbling
    Alligatorbling lol Premium Member V.I.P. Member
    43,103
    51,451
    Nov 15, 2007
    I use a NOS Mullard/Rogers 7025A. Awesome tone.
  5. Classicplayer
    Classicplayer Senior Member
    2,268
    1,242
    Sep 6, 2007
    I have to admit that there's a bit of truth to the Micro Dark being designed for high gain, but I've found that running amp volume much higher than the gain knob, there is a "generic" clean, but not really exciting. I've also found if I keep the amp's volume and gain knob about equal to each other and using the shape knob for adjustment, I've found an attractive Orange "chime" going on. Is this the "old" Marshall vibe many speak of?
    So. I replaced the 2-year old stock JJ preamp tube with a new Mesa 12ax7 that I had been given. What a difference! Gone is the spikeiness and replaced with a really smoother clean and gain, and yes, the Orange chime is still there. Now, my clean is really not generic; it still has some character to it.....just so much smoother.
    I was jonesing for Dark Terror or an Orange OR15H for my PPC112, but I've put that on hold for the foreseeable
    future while I explore new tones. Tube rolling does have its merits.
    Classicplayer
  6. rogue3
    rogue3 Senior Member
    1,235
    1,524
    Apr 22, 2017
    NOS. Mullard.
    rockinlespaul and Kris Ford like this.
  7. Kris Ford
    Kris Ford Senior Member
    4,754
    4,035
    Dec 17, 2011
    This..it has 4 gain stages.
    If ever someone needed to try a Tiny Terror, it's classicplayer..tellin' ya man..THAT is what you want. :)
  8. CGH
    CGH Member
    52
    0
    Mar 1, 2015
    Have experimented quite a bit with my Friedman and Fender Deluxes trying to get some of the graininess out, although I realize that may not exactly be your goal.
    I have a lot of NOS tubes to play with, and have found the NOS Mullards to be very noticeably smoother than most all others, while still providing similar gain levels (not as low as any 5751 version, for example).
    Don't know your amp, but this worked well for me.
    good luck!
  9. Progrocker111
    Progrocker111 Senior Member
    3,338
    2,360
    Oct 30, 2011
    Old Mullard and Brimars have nice 3D midrange, very airy, smooth and big sounding tubes.
    irocdave12 likes this.
  10. rogue3
    1,235
    1,524
    Apr 22, 2017
    Fwiw,i have a tube driven pedal....Butler Real tube,that was originally loaded with a 12ax7. Very grainy,with alot of distortion on tap. After reading about substituting for a 12au7 to smooth it out,i tried it.Wow.It worked beautifully. Just another thing to try for the OP.The amp will be quieter,since its small,it may not be ideal,but worth a shot.Turn up the master.
  11. clintonior
    clintonior Junior Member
    12
    5
    Sep 21, 2017
    I'm going to try a Curtis Mathes long plate in My fender super champ X2HD.
    **Just an update this arrived and really opened up the amp. Improved clarity is noticeable, also Now I enjoy the super sonic ch 13 much more.
    I have the Fender Super Champ X2 HD and run it thru a Marshall AVT 412 and its immense sounding. I wonder how close my super sonic (modeled) 15W is compared to a super sonic 22w.
  12. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    10,072
    10,076
    Aug 12, 2007
    This.
