A 12ax7 To Give Smoother Tone?
Discussion in 'Tonefreaks' started by Classicplayer, Jul 11, 2017.
  1. Classicplayer
    Classicplayer Senior Member
    2,014
    879
    Sep 6, 2007
    My tiny Orange Micro Dark gets a wide array of grainy tones, for sure and I'm liking it. Yet, there
    are occasions when I dial in some gain that's just north of the border from clean. With my guitar's volume controls, I can ride that area to a fine degree. It's at that point where I'm bordering between "clean" and gain that a "spikiness” can be heard. Is there a 12ax7 (the MD has just one tube) that can eliminate that aspect? Right now it has the stock JJ 12ax7s in place.
    Classicplayer
  2. Johnnyslim
    Johnnyslim Member
    93
    78
    Sep 4, 2008
    I would suggest a Telefunken AX7. There are varying viewpoints about Telefunkens with the diamond on the bottom of the glass. Some say the ribbed plates are better and some say the smooth plates are better. From my experience, I like the smooth plates better. Both should smooth out the treble some. I know they do in my JTM 45's. I have a few Telefunkens in boxes since I prefer vintage Mullard AX7's. Nothing like an old Mullard.
  3. cybermgk
    12,784
    16,235
    Jul 7, 2011
    If NOS or old pull, Amperex, or many of the rebranded tubes made by Amperex (for Hammond for instance).
    If Current Prod, Mullard Reissue will be more rounded when distorting, but still has similar tone to JJs.
  4. BigM
    BigM Senior Member
    106
    46
    Jan 29, 2016
    5751. It's has a slightly lower Mu than a AX7. That should smooth things out a bit.
    M
    El Pablo likes this.
  5. cybermgk
    12,784
    16,235
    Jul 7, 2011
    It will also change the gain structure and amount on that amp.
    bulletproof and monkfish like this.
  6. irocdave12
    irocdave12 Senior Member
    1,695
    1,591
    Jun 22, 2011
    Which JJ 12ax7 are you using? There are 3 variants made by them. If you're looking for an inexpensive tube then you could try the JJ 803s with gold pins. Definitely a smoother sounding tube than their short plate. They also make a mid gain medium size plate too. Otherwise +1 on the 5751 It will give you more clean room before distortion. The black plate Raytheon windmill getter is just about the best ever made. If you want a good tube NOS RCA, Mullard Amperex all make a great rock n roll tone. Telefunken will be more neutral and crisp. Amazing tubes but not often liked in guitar amps by many but may be just the ticket in the MD. Either way get some tubes and start rolling brother
    bulletproof likes this.
  7. Classicplayer
    2,014
    879
    Sep 6, 2007
    I use the stock tubenin my MD, a JJ12ax7s
  8. yamariv
    yamariv Senior Member
    1,165
    472
    Jul 26, 2015
    If you can afford a nice Old Stock Telefunken or Amperex these would do the trick. I have a few and they are definitely smooth. I find GE or Sylvania a little more gritty
  9. Classicplayer
    2,014
    879
    Sep 6, 2007
    What about the Preferred 12ax7? My reading of a few reviews shows some people are comparing it to the Telefunken. I had that in a Blackstar HT1 as the stock tube. As I remember it, the clean channel was smooth, but the gain channel's sound was a Metal tone even with the gain lowered.
    Classicplayer
  10. lung plunger
    lung plunger Senior Member
    775
    1,044
    Mar 20, 2017
    I could be wrong, but the HT1 may have opamps providing the gain/distortion on the gain channel. That's be the reason it's straight up break up.
    Rhust likes this.
  11. Classicplayer
    2,014
    879
    Sep 6, 2007
    The Metal tone for me in the HT-1 seemed more to do with the design of its gain channel. It reminded me of Mesa tone with the way the mids were handled in its design. I never got on with it. The clean channel, however, reminded me of a Fender Bassman sound of yore. At least, I could dial it in to "resemble" that tone. Very "thumpy" sounding......even with its 8" Blackbird speaker.
    Classicplayer
  12. northernguitarguy
    northernguitarguy SWeAT hOg
    25,827
    40,715
    Feb 22, 2009
    FWIW, I went through a rolling test to make my VOX as clean as possible. Out of a JJ, EH, Tungsol RI and a NOS Philips i65 'Rogers' branded tubes, the i65 is far and above the cleanest and smoothest sounding.
  13. bulletproof
    bulletproof aka tarddoggy V.I.P. Member
    6,722
    10,806
    Jun 1, 2011
    Just my 2 cents,however,give the ole EHX Gold pins a shot. Ive had a wonderful experience with them in my Traynor.
    Kris Ford and northernguitarguy like this.
  14. grayd8
    grayd8 Senior Member
    1,354
    1,087
    May 5, 2014
    The TAD 7025WA really cleaned up the harshness and fizziness in my DSL 40.
  15. J-E-M
    J-E-M Member
    93
    73
    Mar 23, 2015
    I second this. Have one in my HT-5. Tried a JJ 12ax7 before the TAD - the JJ had lot's of gain, but it was too harsh and a bit mushy. The TAD, in comparison, is smoother, more focused.
    grayd8 likes this.
  16. grayd8
    1,354
    1,087
    May 5, 2014
    Plus you can crank the amp a bit more, I laso have one in my DRRI and I have to crank it to 5 or higher when jamming with a full band. Sounds great at that level.
  17. monitor2000
    monitor2000 Junior Member
    13
    0
    Apr 4, 2017
    I like using 12AY7s in my 5F1 Champ clone. Lower output but very rich full tone.
  18. Dilver
    Dilver Senior Member
    525
    473
    Apr 26, 2011
    I think a lot of us are saying the same thing: try an NOS or even used older tube. The JJ's are reliable and consistent, but not really musical to my ears. I went through a whole tube rolling period wth my Swart and old Supro 1616T. I like the old white or orange stamp Black or Grey plate RCA 12ax7s better than GE, Sylvania or Mullards. But that's me, my rig, my ears.
  19. tjdjr1
    tjdjr1 Member
    45
    3
    Jan 25, 2017
    in my 79 marshall master volume I found the Mullard reissue the smoothest and fullest between the JJ, RI tungsol, groove tube and an old RCA. I do like the sovtek for the PI tube.
  20. Matt_Krush
    Matt_Krush Senior Member
    899
    539
    Nov 5, 2014
    Sovtek LPS (or Mullard LP reissue if you like to spend an extra $5 for the same tube)
    JJ 803
    northernguitarguy likes this.
