_MIJ__FAQ_+_Links
Discussion in 'Other Single-Cuts' started by reborn old, Nov 14, 2011.
  1. reborn old
    reborn old Senior Member
    2,561
    1,620
    Jul 24, 2010
    MIJ FAQ : Bacchus, Burny, ESP, Greco, Orville, Tokai
    Links to additional info + pics :
    Bacchus :http://www.mylespaul.com/threads/th...momose-deviser-theory-photo-id-thread.142408/
    Burny - Fernandes :
    http://www.mylespaul.com/threads/th...-burny-theory-photo-id-related-thread.118269/
    ESP Edwards - Navigator :http://www.mylespaul.com/threads/th...ards-navigator-theory-photo-id-thread.130794/
    Greco :
    http://www.mylespaul.com/threads/un...-greco-theory-photo-id-related-thread.120275/
    Orville - Epiphone :http://www.mylespaul.com/threads/th...e-epiphone-mij-theory-photo-id-thread.137929/, http://www.mylespaul.com/threads/orville-and-orville-by-gibson.2299/
    Tokai : http://www.mylespaul.com/threads/tokai-facts-theory-photos-id-thread.167940/
    MIJ - Les Paul pics thread :http://www.mylespaul.com/threads/show-us-your-mij-les-pauls.5600/
    Special thanks to : doublecut , GammyBird , James T , MauiCliff , muccax , Ohjay , o0mobius0o , slapshot , snaredrum , tonebone , Udonitron , wulfman , for their contributions, and a big thank you to paruwi for numerous edits + updates of this FAQ.
    General guidelines that apply to most MIJ manufacturers and models:
    1- MIJ Les Pauls can be dated from first digit(s) of serial numbers.
    Google your MIJ Brand + "Wikipedia" for serial dating specifics.
    2- MIJ model #'s have always been based on sales prices at the time of manufacture,
    so a 1978 -1984 Tokai LS-100 cost 100,000 y, 1982-1989 Burny RLG-90 cost 90,000 y etc.
    Glossary:
    FEB = fret edge binding
    LP = Les Paul
    MIJ = Made in Japan
    MIC = Made in China
    MIK = Made in Korea
    PAF = Patent Applied For (pickups)
    TRC = truss rod cover
    FAQ:
    How can I differentiate Korean, Chinese or "fake" Les Pauls from MIJ Les Pauls ?
    Most fakes are of Chinese origin. Some spotting tips for guitars not made in Japan include:
    1- Three (or one) screw TRC's instead of the standard two screw MIJ TRC.
    (exceptions to this include some ESP LP's with 1 screw TRC's and early '70s Matsumoku 3 screw TRC Grecos)
    2- White rear cavity covers: MIJ Les Pauls all have black rear cavity covers.
    (exceptions to this again include some ESP LP's and early '70s Matsumoku Grecos
    with white covers )
    3- Different headstock shape or center dimple: Open book headstock indicate a MIJ Les Paul for the Japan market. Center dimple headstocks or different headstock shapes were commonly used on export models and Korean manufactured Tokais.
    4- Square nut cross section: Original MIJ nuts all have a 15* slope angle towards the headstock side,
    while Korean and Chinese brands often have square, non sloped, nut cross sections
    5- Bolt on necks: MIJ models featured below, have set necks. Notable exceptions are the 1999 LS-55 MIJ Tokai with a bolt on neck which had a set neck before and after 1999).
    Many Aria Pro II, Yamaha, Ibanez and Matsumoku made MIJ Les Pauls all have bolt on necks with "MIJ" imprints on the neck bolt covers.
    6- Larger Bridge support posts and sleeved bushings: Posts are thicker and typically slotted at the top and thread into a metal sleeve insert instead of directly into the maple top.
    7- Neck scarf joints: Any 45* angled joint in the neck between the guitar body and headstock (commonly referred to as a scarf joint) is an indication of a Korean or made in china Les Paul.
    MIJ necks are all one piece (not counting the ear pieces outboard of the tuners or neck heels on Grecos, Burnys and 1990's+ Tokais )
    8- Dime sized pots in control cavity: MIJ pots are close to quarter size while Korean or Chinese pots are often lower grade penny or dime sized pots
    9- Monotone headstock inlays (or suspicious border finish around inlay).MIJ brands below feature pearloid brand name headstock inlays that shimmer when viewed at different angles. They are usually seamless so borders or raised edges around an inlay may point to tampering or a sloppy refinish.
    10- No serial number: Except for 1982+ Burny's, MIJ models in this FAQ feature stamped or inked serial numbers on headstock backs just above top tuners. No serial #'s or use of letters in MIJ models that never used letters, are an indication of a made in Korea or made in China model. Some MIK models have serial # decals.
    11- Headstock logos: vary from legitimate logos or silkscreening. This usually involves keeping legitimate high resolution headstock pics handy for the brand in question. Google image search will usually have examples. There are small variations in MIJ headstock art and placement year to year, but when there are a number of marked differences in font type, size or placement it should raise flags to look for other differences stated above.
    12- Use of other body woods: basswood or other back or neck woods may indicate a MIK or MIC manufacture (including but not limited to: Tokai ALS models, ESP Grassroots). MIJ models used mahogany back and necks. Exceptions include Greco late 70's EG 700 to 900 models featuring Norlin pankake bodies and maple necks and KOA top Custom Shop models from various makers. (Many Custom models feature Mahogany tops.)
    note : Many 1960's - 78 Japan manufacturers featured some of the above characteristics (which remained in use into the 1980's + beyond in Korean plants), most commonly #'s 1,2,3,5,6 above
    What is the best MIJ Les Paul that I can buy for $ X00.00 dollars ?
    Depending on your budget, price based model numbers will be your best guide to choices available to you.
    Each of the listed makes are fundamentally quality Les Paul copies, but depending on what is important to you, some may be better choices for you than others. This is where researching your choices becomes very important.
    IE- if long tenons are important, a Greco Mint Collection or Late model MIJ LP will offer the best selection.
    If one piece backs are more important, Tokai / Bacchus / Navigator mid to premium models will offer the best selection.
    A final word on guitar values => Values are cyclical, but to get an idea of current values for the model you're interesred in, check recent sales amounts using eBay's advanced search feature, which has a check box for completed sales.
    How can I be sure an internet ordered MIJ LP will be good ?
    It is generally agreed that it's better, where possible, to audition a guitar live rather than buy sight unseen.
    There is always an element of risk buying online, but if the price is relatively low and you research the model and brand thoroughly, in order to minimize surprises based on misinformation, the element of risk is significantly reduced.
    There is a good chance the guitar will be what you expected because MIJ craftmanship was reasonably consistent for the brands listed below.
    What does the letter in my serial number mean ?
    1970's Grecos and later Greco EG Custom models often used a letter prefix denoting the month of manufacture: ie- A=January B=February ....alphabetically to.... K=November L=December
    F prefix Tokais are made in Korea, C prefix Tokais are made in China.
    Terada Orvilles have J or K letter prefixes + Terrada OBG have G letter prefixes.
    G denotes Gibson pickups, J or K denote Japan pickups.
    Early Epiphone Japan models retained J prefixes from Terada serial designation and this was later changed to a T prefix. Fujigen adopted an F prefix for later Epiphone Japan models.
    Why do model numbers change from year to year?
    Because models numbers are generally based on values, some manufacturers began making model numbers larger to reflect increased production costs associated with inflation and resulting sales prices. Tokai began this practice in 1985 and still does this today. Specifications can become confusing for later years, with so many different model numbers produced.
    Other companies used cost cutting measures, such as eliminating certain features, to hold the line on costs and sales prices.
    Fret edge binding was only available on Greco Premium models after 1983, as an example.
    Why is my headstock different from the "open book" Les Paul design ?
    This is one of the most common practices by MIJ manufacturers to stay within the bounds of
    copyright infringement laws for "export" models, along with different headstock silkscreen art that looks very similar to "Les Paul"
    script from a distance, including: "Luper Prade" (Burny "Super Grade"),"Super Real" (Greco), "Love Rock" (Tokai), "Live Road" (Bacchus)
    Fujigen was licensed by Gibson, to use "Les Paul" and "by Gibson" on ObG headstocks.
    Different headstocks shapes are common on export models and models made in Korea, but not for Japan's domestic issues.
    Where was my LP made ?
    These were/are the main Japanese factories producing the majority of MIJ models (and a few notable Korean subsidiaries):
    Asuka (Aska): Bacchus 1994+
    Cort, Cor-Tek: (Korea) Greco 1988-199? "no serial" models, Ibanez
    Dyna Gakki: Greco, Ibanez
    ESP Custom shop: N-LP 280, 380, 480, Kyoto Japan, ESP Korean factories: LTD-1000, LTD-400, Grassroots, ESP Indonesian factories: LTD 250 and lower models
    Fujigen Gakki: Ibanez, Greco 1979-1991, Burny (RLC's and some RLG's), ObG 1992-98, Epiphone Japan 1998+, Yamaha , Fender Japan 1981-1997 (1st CNC LP's in 1981)
    Hoshino Gakki: Ibanez
    Kasuga: Heerby closed early/mid 1990s.
    Ida (Lida) Gakki: Ibanez, Peerless factory, Korea.
    Nippon Gakki: Yamaha , Aria , Norlin
    Matsumoku: (Matsumoto Mokkou) Aria, Burny (1982-86 RLG-150, 120, 90 models), Epiphone1970 - 86, Greco 1970's, Tokai (1980 + 1981 inkies),Westminster, (1st CNC LP's in early '80s)*, Plant closed in 1987
    Terada: Orville + ObG (199x - 199x K, L, J serial), Burny (1980-81 FLG-240,150, 90 models) Higashiku factory, Kanie factory + Shirakawa factory
    Tokai Gakki: Tokai, Burny FLG (1978),Greco EGC 198?, Grandy (1984-86), Fender Japan, (1st CNC LP's in 1982)*
    *Japanese CNC manufacturing accounted for 40% of the guitar making process, 60% of the guitar making process
    was still done by hand including planing, fretting, joining, and assembly.
    MIJ models and feature overview:
    Bacchus - Momose - Deviser
    Bacchus Vintage Series models:
    BLS-56-Ltd Ed GT:
    no tunematic bridge,
    BLS-59-120 Gold Top:
    BLS-59-120 Lemon Drop:
    BLP-59-Live Road Brian
    (MIK):
    BLP-59-Live Road Duke: oiled finish
    Bacchus Classic Series models:
    BLP-STD-H :
    Standard plaintop, humbucker pups: BHV-A5(F).BHH(R), Laquer finish,
    BLP-STD-M : Mini Humbucker
    BLP-STD-FM : Flamed Maple with 1 piece back
    BLP-STD-S : P90 style pickup, also comes with Bigsby
    BLP-CTM : Custom, Pups: BHV-A5(F).BHH(R) (avail w 3 pups also)
    BLP-SP : Special,
    BLP-SPDC : Special Double Cut
    Burny - Fernandes
    FLC - FLG 1975 -1981 "Les Paul model" script
    FLC-85 : Custom,
    FLC-100: 3 piece back, 2 piece top - center seam, FEB, volute,
    FLC-120:
    FLG-70 : plain top, CS, BS, GT finishes
    FLG-75 : plain top, BL (black) finishes
    FLG-80 : plain top, VG, VBS, VCS finishes
    FLG-90 : plain top, VOS, VOBS finishes
    FLG-100: plain top
    FLG-120: plain top
    FLG-140: plain top, 1 piece back, plain top, nitro ,
    FLG-90 : thin veneer flame top, L8001 pups
    FLG-150: 1 piece back , 3/8" thick flame top cap, FEB, nitro finish
    FLG-180: 1 piece back, thicker flame top cap, FEB, nitro finish
    FLG-240: 1 piece back, solid flame top, FEB, nitro finish
    RLC - RLG 1982 - date , no headstock serial #, "Super Grade" script
    RLC-60-70-80
    : Custom, 2 piece solid top , poly finish , BB, CS, BS finishes
    RLG-50: 2 piece solid plain top , FEB, poly finish
    RLG-60: '56 edition GT, p-90 pups , FEB, poly finish
    RLG-90: veneer top, FEB , poly finish,
    RLG-120: 1 piece back, 3/8" thick flame top cap, FEB, nitro finish
    RLG-150: 1 piece back, thicker flame top cap, FEB, nitro finish
    * Specs may vary slightly from manufacturer to manufacturer .
    ESP - Edwards *
    E-LP70: Two piece back, solid tops, some w double ring tuners
    E-LP 85 SD: (now ELP-92) poly
    E-LP 90LTS: (now ELP-98) laquer over poly
    E-LP 92:
    E-LP 98:
    E-LP 112/124: basic lacquer, SD1 + SD5 pups
    E-LP 124/132: super circuit, lacquer, SD1 + SD5 pups
    E-LP 130:
    Pure Material : Ltd Ed flame top, 31 produced in 2009
    *ESP Edwards guitars began production in 1992, and are manufactured in China,
    then reportedly finished and quality control inspected in Japan.
    ESP - Navigator
    1976 - 1979
    ES-12
    Standard
    ES-13 Custom
    1980
    LPS 90, LPS 100, LPS 130, LPS 150, LPS 200, Standard
    LPC 85, LPC 100
    Custom
    intro of Espart-LP kits
    1981 - 82
    LPS 100, LPS 150, LPS 200, LPS 250, LPS 300, LPS 350,
    Standard
    LPC 110, LPC 150 Custom
    1983 - 84
    LPS 120, LPS 120G
    (gold top), LPS 250, LPS 350, Standard
    LPG 110 (P-90 gold top),LPC 200
    1985 - 86
    LPS 140G (gold top), LPS 300, LPS 350,
    Standard
    LPC 200 Custom
    1987 ~ 2000 Standard white rear covers
    LPS 250, LPS 350,
    LPC 200
    Custom
    2000 - 2005
    N-LP 280
    : solid flame top, poly finish
    N-LP 350LTD:
    N-LP 380LTD: replaced discontinued N-LP 280 ~ 2001, 1pc Honduran mahog backs, SD pups, nitro finish
    N-LP 320CTM: Custom
    2005 - date
    N-LP 480LTD
    : solid flame tops, 1pc Honduran mahog backs, SD pups
    N-LP 580LTD: solid flame tops, 1pc Honduran mahog backs, SD pups
    N-LP 380CTM: Custom 1pc Honduran mahog backs, SD pups
    N-LP 400CTM: Custom 1pc Honduran mahog backs, SD pups
    N-LP 480CTM: Custom 1pc Honduran mahog backs, SD pups
    Greco
    1971 - 1975 "Gneco" headstock logo. Early '70s Greco LP's had 3 screw TRC's
    1975 - 1981 "Greco" headstock logo + closed "O" in Greco
    EG-380 - EG 480: Chambered body, UD pickups, multi piece back
    EG-500: 3 piece top 1980-81, multi piece back, U-1000 pickups
    EG-500 C: Custom, 2 piece top, multipiece back, UD pickups
    EG-600: 2 piece top, multipiece back, U-1000 pickups
    EG-700: Norlin sandwich type bodies, maple necks + large Head stocks, U-2000 pickups
    EG-800: Norlin sandwich type bodies, maple necks + large Head stocks, PU-2 pickups
    EG-900: Norlin sandwich type bodies, maple necks + large Head stocks, Dimarzio PAF pickups
    EGC-900: Dimarzio PAF pickups
    1979 - 1982 Super Real Series * "Super Real" headstock script
    *1982 transition Super Reals: Super Real heastock script, but have Mint Collection model attributes, including long tenons.
    EG1000 C: Custom, Dry Z pickups, ebony board
    EGF-850 : PU-2 pickups, (some with Brazilian fret boards in 1980 only)
    EGF-1000: Dimarzio pickups, (Brazilian fret boards in 1979-1980 only)
    EGF-1200: Dry Z pickups, all with Brazilian fret boards,
    EGF-1800: Dry Z pickups, all with Brazilian fret boards,
    EGF-2500: solid Quilt top, limited special order in 1980 only, dry Z pickups.
    All models feature FEB, nitro finish,
    EGF-1200 - only model with honey burst finish + usually the fattest ('58 profile) necks of all LP replica's.
    EGF-1800 - solid flame topped special order models, center seam 2pc back, few 1 pc backs, (lower EGF SR models are all veneer tops)
    1982-1995 Mint Collection. open O in "Greco" until mid 1991, no headstock script (except 1982 Super Real).
    All feature a long neck tenon, rectangular bell TRC
    Models EG59-85 upward, have Nitro finishes.
    1982 (and many 1983) models have FEB.
    The middle two (xx) numbers in Mint Collection model numbers designate the LP year featured and similar neck profiles,
    with 56-58 being thickest and 60 being smallest. Middle numbers include 57,58,59,60, and 68 for Customs only.
    EG-xx-450: 2 piece top , heel cap, Screamin pickups
    EG-xx-500: 3 piece solid top 1980-82, heel cap, Screamin pickups
    EG-xx-600: GT Hot Lick (P-90) or minibucker pickups
    EG-xx-650: laminate flametop, Screamin pickups
    EG-xx-700: 2 piece top, mild flame, no heel cap, Screamin pickups
    EG-xx-850: laminate flametop, Double Trick pickups, CS finish
    EG-xx-1000: laminate flametop, DRY-1982 pickups
    EG-xx-1200: laminate flametop, DRY-1982 pickups and 50's style necks, some of the EG58-120's
    EG-xx-1800: solid flametop, DRY-1982 pickups
    EG-59-2400: rare limited editions,feature solid flametops, fatter flamed maple necks, gold hardware, ebony fretboards..
    EG-68-800 C - Wine top Tobacco burst, Double Trick pickups
    EG-1000D 1989-91 Seymour Duncan pickups.
    From 1988-1990 Greco licensed Cort (Korea) to produce no headstock serial # EG models, featuring black plastic fret boards,
    angled end (rather than squared end) cavity routs, squared nuts + TRC area bevels.
    In mid 1991 Greco returned to the closed O on most Mint Collection models.
    Orville - ObG - Epiphone (Japan)
    Orville by Gibson - Manufactured for Gibson by
    Fujigen - models featured long tenons.
    Terrada - models mostly featured medium tenons and K, G or J serial number prefixes
    K prefix Orville LPs were produced from 1989 -1993, necks may have Korean style scarf joins.
    G prefix ObG LPs were produced from 1989 -1995
    J prefix Terada Orvilles began production in 1995 after ObG production ceased,
    L - prefix Orvilles are believed to be of non Japanese origin (or possibly fakes.)
    G = Gibson pickups (ObG), J+ K = Japan PAF pickups (Orville).
    ObG LP Reissues (LPR ) late 1992 to early 1995
    - Gibson USA wiring, controls and pickups, nitro finishes, blank TRC, FEB,
    Rare, ObG RI flametops are rarer still.
    ObG LP Standard (LPS) 1988-1993, no FEB "Standard" on the truss rod cover, but are otherwise identical to the ObG reissues.
    ObG flametops are usually laminate, with a few solid flametop examples (LPS-FM 150's and a few re-issues).
    Orville - Japanese electrics and Orville PAF pickups, poly finishes
    some Orvilles had Photo-flametops, which have identical halves and can look the same as other examples.
    In early 1995, Orville by Gibson was discontinued,
    Epiphone (Japan)
    There were Matsumoku made Epiphone badged LP's produced in very low numbers in 1982 and possibly later, until Matsumoku closed in 1987. They are very similar to Matsumoku produced
    Burny RLG's from 1985 + 1986. Controversy remains as to whether they were licensed products or not, but there is no doubt about their build origins.
    In 1998 Orvilles were re-branded Epiphone by Gibson (Japan).
    Japanese Epiphones are identical to Orville's but with an Epi headstock inlay.
    There were no replacements for Orville by Gibson models.
    Early Epiphone Japan serials are the same as the last Orvilles, with no letter serial # prefix from Fujigen and J letter serial # prefixes from Terada.
    For later Epiphone Japan serials, Fujigen started using F letter serial # prefixes at the same time Terada started using T letter serial # prefixes.
    Elite/Elitist series Japan Epis were introduced in 2002
    Export Epi Elite models featured tombstone headtocks in place of Japan domestic open book headstocks.
    Lacquer series models were introduced around 2005 and Epi Japan LP production ended several years later.
    Tokai
    1978-1985
    All Japan made models have 7 digit numeric serial numbers. with the 1st number(s) indicating model year.
    There are 3 different headstock scripts:
    "Les Paul Reborn" - 1978-early 1980
    "Reborn Old" - early to late 1980
    "Love Rock" - late 1980 to Date
    There are 3 different TRC styles:
    Bell shaped TRC - 1978-1980 (some re-appeared in 1983-1984)
    Pointed Bell TRC - 1981 - mid 1998
    Arch shaped TRC - mid 1998 - date
    LC-60: 2 piece top,2 piece back, poly finish
    LC-100: 1 piece mahogany top,1 piece back, nitro finish, 2 pickups
    LC-110: 1 piece mahogany top,1 piece back, nitro finish, 3 pickups
    LS-50: 3 piece top, multi piece back, poly finish
    LS-60: 2 piece top,2 piece back, poly finish
    LS-80: Gotoh 57 PAF pickups
    LS-100: dimarzio pickups
    LS-120: veneer flametop
    LS-150: solid flametop
    LS-200: special order model
    All LS-80 to LS-200 models feature nitro finish, 1 piece backs, 18* heastock angle, FEB to 1983
    Tokai models did not begin using inflation corrected higher model numbers until the LS-55 in 1985.
    LS-70 GT + LS-75 GT limited edition models were introduced in 1981
    Current production line:
    As of 2011, models below LS-92 are no longer made in Japan.
    ALS prefix models are made in China (ALS-47, ALS-48, ALS-53 etc)
    current MIJ models:
    LS-92: plain top, 2 piece back, long tenon, poly finish
    LS-98: veneer flame top, 2 piece back, long tenon, poly finish
    LS-140 F:veneer flame top, 2 piece back, long tenon, lacquer
    LS-160: plain top, 1 piece back, long tenon, US electrics, lacquer
    LS-165 S: GT, P-90s, 1 piece back, long tenon, US electrics, lacquer
    LS-260: solid flame top, 1 piece back, long tenon, US electrics, lacquer
    LS-420: LS-260 specs but with Brazilian fret board, higher grade flame top
    LS-540: LS-420 specs + Honduran mahogany back + premium flame top
    LC-98: Wine red + BB finish, 2 piece back, long tenon, poly
    LC-195 S: BB,ebony fretboard, 1 piece back, long tenon, US electrics, lacquer
    LC-200: as above in Wine red finish
    2010 and newer Greco and Burny models often have a "5" last digit in the model number, with models below xx-85 usually made in China.
    These generally do not have open book headstock shapes.
    If you would like to add additional information for MIJ brands not mentioned, please feel free to do so.
    JDZ, barchiola, El Kabong and 43 others like this.
  2. Udonitron
    Udonitron Psychedelic Stoner Rock Premium Member
    15,324
    9,820
    Aug 26, 2009
    Nice job Reborn!
    That is a lot of research and very well done and concise mate!
    GRuggier likes this.
  3. muccax
    muccax Senior Member
    409
    167
    Dec 23, 2010
    hi
    i can only say ,,, great work ,,, :) :) :)
    all the best
    otto
  4. Udonitron
    15,324
    9,820
    Aug 26, 2009
    Ah now you changed FAQ to upper case, good plan Reborn :D
  5. GammyBird
    GammyBird Senior Member
    20,923
    14,048
    Nov 14, 2009
    Great job Reborn...your time and effort is appreciated.
    Thanks for the sticky mod :D
  6. o0mobius0o
    o0mobius0o Senior Member
    3,084
    3,352
    Dec 11, 2009
    Hopefully the OP can continue to edit the OP.
  7. GRuggier
    GRuggier Senior Member
    239
    43
    Feb 26, 2010
    YEAH! STICK THIS MO FO!:slash:
  8. reborn old
    2,561
    1,620
    Jul 24, 2010
    Thanks guys, and thanks again to all contributors. :)
    GammyBird likes this.
  9. mono
    mono Senior Member
    7,461
    3,045
    Jun 13, 2009
    Great stuff reborn... hopefully many MIJ newbies will find this very helpful and time-saving! :)
  10. slapshot
    slapshot Senior Member
    22,963
    23,653
    Aug 21, 2010
    Ratae Corieltauvorum likes this.
  11. Udonitron
    15,324
    9,820
    Aug 26, 2009
    Some info for you regarding ESP Navigator & Edwards:
    1979 the Standard LP's were known as the ES-12's
    Customs were ES-13's
    In 1980 they made kit builds known as Espart-LP
    1985 There was the Standard flame/figured topped LPS-350
    Black/White Custom LPC-200
    Gold Top LPS-140(G)
    Edwards 1st showed up in 1992 with full production guitars.
    FYI...the backs should read Honduran not Brazilian :)
  12. reborn old
    2,561
    1,620
    Jul 24, 2010
    Thanks, was up too late. :)
    Updated Navigator info. Still somewhat sketchy from late 1980's through early 2000's.
    Wondering if most were special orders between these dates ,
    like many premium models from other manufacturers.
  13. Udonitron
    15,324
    9,820
    Aug 26, 2009
    In 1987
    LPC-200
    LPS-250
    LPS-350
    No LPS-300
  14. reborn old
    2,561
    1,620
    Jul 24, 2010
    Thanks... Edited.
  15. Udonitron
    15,324
    9,820
    Aug 26, 2009
    NP man, thanks for the compilation thus far.
    We appreciate it.
  16. slapshot
    22,963
    23,653
    Aug 21, 2010
    add a spare parts list to the faq?
    Matty and o0mobius0o like this.
  17. Udonitron
    15,324
    9,820
    Aug 26, 2009
    I should do one for amps :D
    brizzle and GammyBird like this.
  18. Matty
    Matty Senior Member
    8,133
    11,448
    Dec 14, 2010
    This would be very helpful.:thumb:
  19. northernguitarguy
    northernguitarguy SWeAT hOg
    29,166
    49,095
    Feb 22, 2009
    Very cool thread, I love my MIJ guitars!!
    However I wonder why the Yamaha Studio Lord is not included in the OP?
  20. northernguitarguy
    29,166
    49,095
    Feb 22, 2009
    also, does anybody know about Kasuga LPs? Mine was sold under the 'Northern' label up here in Ontario. My aunt bought it used in Hamilton in the early 80s
