`69 LPC binding ?
Discussion in 'Vintage Les Pauls' started by neuroy, Jul 10, 2015.
  1. neuroy
    neuroy Member
    93
    14
    Oct 28, 2012
    Hello,
    I was asked to replace about 2 inches of binding on a `69 LPC.
    I need to get the right material in time, because the customer does not want to part with the guitar for longer then one week.
    So my question is : is the LP Custom binding celluloid or is it Royalite / ABS also ?
    Which thickness do I need to recreate the binding ?
    Any help appreciated.
    Thanks
    Cheers
  2. Bill Hicklin
    Bill Hicklin Senior Member
    6,931
    8,611
    Nov 3, 2014
    Body or neck binding?
  3. JJ Blair
    JJ Blair Senior Member
    1,530
    1,279
    Feb 19, 2010
    It definitely would not be celluloid. I would just get royalite, and melt the two together with acetone. The color might be off, but you can tint the lacquer for a good blend.
    When I refin'd my '60 Rivoli, the previous refin had chewed the binding really badly, and I just melted Bartlett's royalite and pasted it on, then sanded it to shape. After some amber lacquer, you can't see any of the shade differences.
    edit: You're not talking the layered body binding, are you?
    2 people like this.
  4. neuroy
    neuroy Member
    93
    14
    Oct 28, 2012
    I was talking about the body binding of a LP Custom. 7 layers black and white.
    The question is to buy ABS or celluloid ( which is very tough to get here in Europe ).
    And the thickness of each layer ( 3 black and 3 white of the same thickness ? Or are the black smaller than the white ? Plus the 7th / outer white layer which is thicker )
    Thanks
  5. rockstar232007
    rockstar232007 Senior Member
    15,109
    10,755
    Jun 28, 2008
    The inner binding is thinner than the outer (last layer) binding.
  6. neuroy
    neuroy Member
    93
    14
    Oct 28, 2012
    IsnĀ“t it 6 layers 0.02 and the outer is 0.06 ?
    In total the binding will be 0.18
