Discussion in 'Luthier's Corner' started by notoperational, Mar 6, 2008.
  1. notoperational
    notoperational Senior Member
    6,592
    1,203
    Nov 9, 2007
  2. Mr Bones
    Mr Bones V.I.P. Member
    1,097
    83
    Apr 8, 2007
    I don't remember, but don't those tele deluxes have a tummy contour like a strat. Any way, with the large roundovers and curves on those guitars, you dont really want to sand the finish off, but strip it. This is compounded by the fact that I think they are MIJ, and have poly about as thick as a dime on them. I stripped by sanding a CIJ strat once and it was pure hell. But once you get down to the wood, you are still going to have to finish the body in clear.
  3. BCRGreg
    BCRGreg V.I.P. Member
    12,492
    9,736
    Apr 2, 2007
    Get this little gem to do it.....she LOVES sanding!
    She even dresses up for the task!
  4. mrkenny
    mrkenny Senior Member
    380
    41
    Dec 18, 2007
    I'm a finisher by trade. The poly finishes are tough to get off. I've discovered that making a tray out of alumimium foil works good. Use the heavy gauge foil. Put two pieces of foil face to face, bend one edge over several times to make a leakless seam. Open the two sections and you have a larger piece. Raise the entire outside edge a couple of inches. Fill this "tray" with finish remover (semi-paste) and make a top for the tray to prevent evaporation. Make sure the body is covered with remover. Once it's sealed let things set over night and in the morning the finish will be soft enough to remove. After the air hits the body it will reharden a bit so you have to work with purpose, it may take several times to get completely stripped. Use lacquer thinner to wash off the soft finish, do not use water as this will raise the grain. Make sure not to scrape to hard, it will mark the wood, be gentle. Let the remover do all the work.
  5. Roman
    Roman Master Luthier V.I.P. V.I.P. Member
    6,688
    5,756
    Dec 4, 2007
    If anything it will improve it. Any time I have stripped off a poly finish it opened up in tone and became acousticly louder as well.
