5E3 Deluxe Build...Initiated
Discussion in 'The Squawk Box' started by Pappy58, Jan 16, 2018.
  1. D'tar
    D'tar Senior Member
    346
    156
    Sep 23, 2014
    A variac$$$ is a nice thing to have if you are a repeat customer/builder/diy enthusiast. IMO it is not as necessary as the limiter$ for a new build. YMMV.
    Jealous!!
    Enjoy your trip!
  2. BlueCajun
    BlueCajun Senior Member
    911
    418
    Jul 26, 2012
    Nice! I've been tempted to pick up one of the Tube Depot kits for my first build. Seems like their instructions are very good.
    I'm curious: Did you notice any difference in sound between the Tube Depot and Mojotone guts? I assume they use different component brands and am wondering how much of a difference that makes.
  3. Cjsinla
    Cjsinla Senior Member
    3,188
    2,274
    Jul 7, 2014
    No, couldn’t tell much difference until I put in the Weber speaker, which made a huge difference. The Tube Depot instructions are very helpful if this is your first build.
    Pappy58 and BlueCajun like this.
  4. Pappy58
    Pappy58 Senior Member
    1,804
    2,979
    Dec 2, 2014
    Ok, had some delays, and still waiting for a variac I ordered way too long ago. (Delivery set for 3/1). So today the sun was out so I broke out the Zinnser and went at the box. Been a while since I've done one. I have ~3 coats on it now. Might scuff it and add one more coat... hope to have a working amp by monday! :cheers: IMG_0572.jpg IMG_0574.jpg IMG_0573.jpg
  5. Leña_Costoso
    Leña_Costoso Senior Member
    733
    687
    Aug 28, 2017
    Ha! Just got new tires on the Harley, so I'll be there for at least part of Bike Week - downtown. Its a "must do!"
    Pappy58 likes this.
  6. Pappy58
    1,804
    2,979
    Dec 2, 2014
    Ok, in the final stretch... my reissue p12R is installed and speaker break in is in progress. I also have a a 62 P12, a 10yo reissue C12N, and a G12-V30 to try. Planning to power the chassis tonight. :fingersx:
    Cjsinla and Leña_Costoso like this.
  7. Leña_Costoso
    733
    687
    Aug 28, 2017
    I'll look for sparks in the northern sky....
    JK
  8. chupe442
    chupe442 Confused as ever..... Premium Member
    3,122
    2,571
    Feb 2, 2011
    Its been a few hours.. No sparks, no news.. Someone want to check in with Pappy?? :Ohno:
  9. Leña_Costoso
    733
    687
    Aug 28, 2017
    I predict two possibilities.
    a. He's having so much fun, he can't stand it... we'll see him in days.
    b. There's a major ooops going on.
    Let us hope and pray for the former, but if the latter, may it be of low impact and easily corrected.
    Pappy58 likes this.
  10. Pappy58
    1,804
    2,979
    Dec 2, 2014
    LOL . Thanks guys...after one more triple check with the DVOM my old eye's were saggin' so I'm on sleep hold. :squint: Don't worry as soon as there is either tone or fire I'll update asap. It will surely happen tomorrow afternoon. Hopefully I'll be :beer: while typing the update.
  11. chupe442
    3,122
    2,571
    Feb 2, 2011
    So..... another day of wait? What is this patience that you seem to have?:hyper:
  12. Pappy58
    1,804
    2,979
    Dec 2, 2014
    Took 40+ years to find, but a wonderful thing it is! :cool2:
  13. chupe442
    3,122
    2,571
    Feb 2, 2011
    sitting on 50 and its no where in sight...:dunno:
  14. Leña_Costoso
    733
    687
    Aug 28, 2017
    Well I'm older than that by a bunch. However, I did hear that patience is a virtue, and I want some now!!!!
    Cjsinla likes this.
  15. Soul Tramp
    Soul Tramp Speaker Snob V.I.P. Member MLP Vendor
    6,388
    14,534
    Jul 19, 2012
    The 10A125 is just not enough speaker for a 5E7. A mix of 10F150s & 10A150s would be an excellent choice. The 10A125 is under powered due to the small motor (voice coil & alnico magnet).
    I use Weber speakers almost exclusively in my amps, except for the 150 watt monsters where I use EVM-12L.
    Pappy58 likes this.
  16. Leña_Costoso
    733
    687
    Aug 28, 2017
    Not big on Weber m'self
    Pappy58 likes this.
  17. chupe442
    3,122
    2,571
    Feb 2, 2011
    Getting to be a big fan of the entire WGS speaker line up..
    Pappy58 likes this.
  18. Pappy58
    1,804
    2,979
    Dec 2, 2014
    IMG_0608.jpg IMG_0609.jpg Turning the big "six-ohhh" in July....so 40+ of learning lessons the hard way. :facepalm: But after raising kids and having members of the "younger' generation report to you for a few years, it really sunk in. The Zen state is the only state! (Or at least I try to convince myself.)
    So...on to the update. I'd say I am at 95% success. I went thru the power up process without arc welds or burn't carbon. :applause: All the tubes are in and we have sound. Two minor anamolies: 1ea new Tung-Sol pre-amp tube croaked 10mins into heat soak and produced a howl. I also have an issue with the NFB. In the position where the NFB resistor is in play, I get the squeal mentioned in mod procedure but the remedy (reverse polarity on the OT) does not seem to solve the problem. In the other two positions we have good clean output, with the stock position bringing the mojo, at least from a short test drive. :naughty:
    Now, for the voltages :io:
    They are high, as some what suspected. With the variac at 120vac, I have the following:
    PT Secondary = 380vac
    B+ = 380vdc
    B2 = 335 (Plate to ground same)
    B3 = 255
    More later. :cheers:
    Cjsinla likes this.
  19. Leña_Costoso
    733
    687
    Aug 28, 2017
    Disconnect the NFB from the OT's output and see if the howl goes away. If it does, you're barkin' up the right tree. If not... gotta put on the thinkin' cap.
    Early picture of a certain someone with their thinkin' cap.
    chupe442 and Pappy58 like this.
  20. Pappy58
    1,804
    2,979
    Dec 2, 2014
    She's altogether and working and quiet (no hum). I went ahead and installed the vintage speaker. Still need to get the NFB thing figured out.. 2/3 positions work including the stock circuit so I'm interested in doing some testing with various input voltages....after I give it good ring in the next couple days!. Thank you gents for all your help and dialog it's is greatly appreciated! :cheers2: Nothing like a little fruition to put one to sleep. Nighty Night Rabbit:thumb:! zzzzzzzzzzz
    Brewdude, Slater529, chupe442 and 2 others like this.
