52/57 Conversion Ebay Europe
Discussion in 'Vintage Les Pauls' started by Mr.Paul, Feb 23, 2015.
  1. d1m1
    d1m1 Senior Member
    2,357
    2,541
    Oct 30, 2012
    i saw it and was wondering why it´s for sale again..
    but something else:
    Bridge volume pot – 1346043 (1960) – 586k
    Bridge tone pot – 134738 (1957) – 603k
    wow, maybe one of the keys for that burst tone?
  2. stockositch
    stockositch Junior Member
    16
    27
    Apr 15, 2012
    I hadn't noticed the pot values but that might explain why the bridge pickup is significantly brighter than I was expecting. I've been having to keep the top end reigned in on the tone pot pretty much all the time. Having said that I do need to redail the amp in as my rigs currently all set up for an old tele fitted with a pretty dark paf in the neck.
  3. hoss
    hoss Senior Member
    1,664
    2,429
    Mar 9, 2012
    Gone again.
  4. boogieongtr
    boogieongtr Senior Member
    1,140
    1,241
    Aug 15, 2008
    I'd switch the bridge & neck volume pots. Get the highest value pot in the neck and it will add treble and the lower value pot in the bridge will tame the treble a bit. Just a thought...
    4 people like this.
  5. stockositch
    16
    27
    Apr 15, 2012
    That's not a bad idea at all although the neck does just sound soooo good as it is and I'd hate to do anything to upset it, you know, toneless modern solder and all that :naughty:
    1 person likes this.
  6. Meddled
    Meddled Senior Member
    102
    82
    Jan 22, 2015
    The advert is written in kraftwerk. Anybody got a translation?
  7. stockositch
    16
    27
    Apr 15, 2012
    Guts of it are:
    This Les Paul was originally built in 1952 and did not have any serial number stamped in the back of the headstock as many others from that year. It was refinished completely (front, back and neck) in the early ‘80s, supposedly by the Gibson factory. Dean Gagliardotto bought it from a Minister in Tenessee and had it converted to 1957 specifications by Terry Mueller. Dean supplied all the original / period-correct parts for the conversion.
    Tom Murphy painted an invented 1957 serial number (7 5225) with a font that looks identical to the original one.
    The guitar has no breaks and includes the following parts:
    • Unopened double black PAFs (obviously with their original covers). Charlie measured the bridge pickup at 8.0k, and the neck one a little less.
    • Pots & caps are period correct for 1957:
    o Neck volume pot – 134623 (1956) – 456k
    o Neck tone pot – 134738 (1957) – 436k
    o Bridge volume pot – 1346043 (1960) – 586k
    o Bridge tone pot – 134738 (1957) – 603k
    • Wiring harness/switch/jack connector are original from 1952.
    • Tuners are single-line, single-ring ("sealed" tuners) with the small lubrication hole.
    • ABR-1 is period-correct from the 1950s.
    • Tailpiece is period-correct from the 1950s.
    • Neck reset to accomodate the correct angle was done by Terry Mueller.
    • ‘Angel Parts’ pickup rings.
    • The pickguard that came with the guitar was recut from old plastic by Terry Mueller. I installed a period-correct one from the 1950s, recut for a guitar with humbuckers.
    • The case is a 1990s Gibson Custom Shop one.
    • Toggle ring is not original nor period-correct.
    • Switch tip is original from 1952.
    • Backplates are original from 1952.
    • Truss rod cover is original from 1952.
    • Knobs are period-correct from 1950s
    2 people like this.
  8. Liam
    Liam V.I.P. Member
    5,955
    2,411
    Nov 19, 2007
    I am really jealous... :naughty: Not generally a fan of the conversion phenomenon at all, but occasionally there are guitars where is has to have been the right thing to do.
    Liam
  9. stockositch
    16
    27
    Apr 15, 2012
    Liam
    I'm 40 miles south of Manchester. If you're ever passing give me a shout and drop in and give her a thrash.
    4 people like this.
  10. jaik
    jaik Senior Member
    651
    607
    Jan 8, 2012
    put up some recordings when you get a chance, I know we'd all like to hear her sing some.
  11. jwinger
    jwinger Senior Member
    2,250
    846
    Apr 7, 2008
    Jealous that a bargain. Lucky I didn't spot it or you could have had had a fight on your hands! Ah. Congrats and enjoy
  12. Liam
    Liam V.I.P. Member
    5,955
    2,411
    Nov 19, 2007
    That is a beautiful and kind offer, and when I get time I'll take you up on it.
    Liam
    2 people like this.
  13. Sharky
    Sharky Senior Member
    4,966
    4,262
    Jan 19, 2012
  14. stockositch
    16
    27
    Apr 15, 2012
    Yes, still a scam, guitar still sitting in my front room still not for sale!
  15. Sharky
    4,966
    4,262
    Jan 19, 2012
    gone already. What a bunch of serious mofos this is.
    Are you enjoying the guitar? I was so tempted when it came up for sale, was too slow though
  16. stockositch
    16
    27
    Apr 15, 2012
    I'm beginning to feel a little persecuted with most of Eastern Europe seemingly trying to sell my new baby for me!
    She's an absolute beauty tone wise although I'm still learning to drive her properly. There's a vast array of sounds available depending on volume and tone positions. I especially like the big kick in terms of gain level over the last 15% of the volume travel - my tubescreamer is virtually redundant.
    The neck fits my hands absolutely perfectly and is remarkably different in the way it feels, both in terms of width and depth, to my alnico custom (which is the closest thing I have to compare it to). It's strange as they're pretty close when you measure them. I suppose the biggest issue to get to grips with is the neck angle being a touch shallow resulting in the bridge sitting lower than I'm used to. I tend to prop my right hand off the pickguard and/or the bridge using my little finger so this means that my playing position is subtly "off" enough make me have to think about it at times. I'll get used to it soon enough though I'm sure.
    Weightwise she's a hair lighter than the alnico custom and about half the weight of my 25/50 custom.
    All in I'm chuffed to bits with her. I'm grateful that she cropped up when she did when I was fortunate enough to have a pile of cash lying around.
    4 people like this.
  17. Reno_1ted
    Reno_1ted Senior Member
    560
    490
    Nov 13, 2013
    Very cool guitar indeed mate, congrats! Thats interesting about the feel of the neck even though both have similar measurements. Sometimes a neck just had a 'feel' to it.
  18. NaughtySpinach
    NaughtySpinach Junior Member
    14
    6
    Sep 17, 2015
    Hey guys, I'm new to this Forum. Hello to everyone!
    Just stumbled over this thread because it seems the LP that is topic here is on sale again on the bay. Since there seem to be a lot of scam offers earlier this year I thought it could be worth it to mention the new offer here.
    Vintage Gibson Les Paul 1952 1957 Conversion mit orig. PAF Humbucker | eBay
    Is this offer true?
  19. hoss
    hoss Senior Member
    1,664
    2,429
    Mar 9, 2012
    Not valid, a fellow forum user owns the guitar.
    And they are using my friend's old description again :(
  20. NaughtySpinach
    14
    6
    Sep 17, 2015
    Thanks!
    It's crazy...scam again and again with the same guitar and description :-(
