50's Wood? This is How a Good Les Paul Supposed to Sound Like
Discussion in 'Vintage Les Pauls' started by d1m1, Nov 6, 2017.
  1. BBD
    BBD Senior Member
    2,519
    11,224
    Jan 16, 2017
    Thank you Mouse. 100% seriously. I hear the difference which makes me one of the few privileged to hear Wilbur Marker's statement tested.
    Mouse likes this.
  2. EpiLP1985
    EpiLP1985 Senior Member
    138
    83
    Feb 5, 2011
    All interesting stuff. Sustain is just one factor in tone though.
    Not that my intention is to belittle or lessen anyone’s position. Just an observation.
    Mouse likes this.
  3. LenPaul
    LenPaul Premium Member
    2,926
    4,114
    Jul 13, 2012
    little experiment, take a hollow body electric, say an ES335, stuff some padding into the body through the f holes,
    plug in & play, take note of the sustain. Stuff some more padding in & take note.
    Now pull out the padding, plug in & play, take note .
    Is there a difference??
    yeti likes this.
  4. Mouse
    Mouse Senior Member
    2,715
    3,925
    Nov 2, 2008
    You are welcome
    I thoroughly enjoy her, different.
    The first one is also nice guitar, out of phase sound :cheers2:
    But of course ;)
    BBD likes this.
  5. BBD
    BBD Senior Member
    2,519
    11,224
    Jan 16, 2017
    Mouse likes this.
  6. steve2
    steve2 Member
    34
    10
    Jul 8, 2017
    I am just saying there is no way to tell one from the other in a blind comparison. If you are holding the guitar, experts like Rob Chapman can tell what is what, but he is unable to tell the difference when only listening to them
  7. LPandMarshall
    LPandMarshall Junior Member
    3
    4
    May 18, 2017
    @ steve2
    There are huge differences between Les Pauls! I have built 8 Les Pauls by myself just to get very good Les Pauls. It all started with my frustration about the stock Gibson Les Pauls available in music shops 4 years ago. Just a few were really good. The one I liked best was 7000 Euros (8000$). So I decided to build them myself. It was a lucky coincidence that I got the rare opportunity to buy a larger amount of Swietenia Mahogany from an insolvency estate from a wooddealer for little money. So I could try out a lot of things. Its amazing, how different Mahogany is sounding, when you shape some wood to the same size and knock on it. Even if the woods´density is the same! Two preshaped necks with the same weight can sound very different! If you combine the different wooden parts of a guitar due to your taste, or where you want to go tonewise, you get a guitar, that is sounding perfectly for you.
    Today a big guitar building company does not sort out the wood tonewise and does not try to find the pickups and electronics they also fit best to the customers needs, but this effort would pay out big time. I can build Les Pauls now, that are spot on tonewise or come very close, just because of sorting wood out due to frequeny response of the raw wood. Does it sound more bassy or trebly? Does the wood have a nice mid-honk? Does it sound percussiv or has it more sustain? That are all facts that alter the sound of the guitar. And you can of course try to eq any guitar signal, but some things come out oft he guitar and you cant add them with electronics. String separation in chords for example. Or how fast and sensitive reacts the guitar? Does it sound „woody“. These things are only guitar stuff, not electronics. Very important is the use of hot bone glue(!) and a VERY WELL fitting neck/body joint!
    So, what I want to say is, there is no voodoo or some magic mystery in guitar building, but one can influence the guitar´s sound very much. And you can hear it very clearly! And as a general conclusion: A 59 Les Paul is nothing, you cannot recreate tonewise. This is at least for small numbers of one a hte same guitar. A big factory cannot do that. Custommade is the key word.
    6077dino and Progrocker111 like this.
  8. Mouse
    Mouse Senior Member
    2,715
    3,925
    Nov 2, 2008
    ^^ Yup.
    Burst killer, oldgrowth Swietenia mahogani (Wilbur Marker method)
    Plug and play JTM45 kt66
    “These things were made to be played. They were not thought of as classic instruments. They were made to make loud noises, irritating sounds. That’s my view.” Billy Gibbons
    Thermionik and 1969 weatherman like this.
  9. Open_Book
    Open_Book Senior Member
    1,180
    683
    May 26, 2014
    Thats just a bunch of waffle. Its him reminiscing and adding inflection...
    "In studying Les Paul copies"......I mean, seriously...
    They learnt the advantage of a steeply pitched neck to um, later, change it... Cuz it broke...
    There's so much romanticism and baloney about all this stuff people want to believe anything that makes 'em feel all warm and fuzzy about it.
    Like the comment earlier about Hide Glue and a tight joint. The tight Joint is the important part. The glue line is so thin its of no real musical significance. While a Braz board has oil in it, which is a known damping agent - and the board has chunks of wood cut out of it to have pieces of Nitrate plastic glued into those holes...
    A shite piece of riftsawn wood is no different to a shite piece of flatsawn... Its just, well, shite.
    Bill Hicklin likes this.
  10. EpiLP1985
    138
    83
    Feb 5, 2011
    One thing I picked up on when reading Tony Bacon's book was that there was a subtle point that wasn't really ever explicitly stated but can be easily assumed: most of what we think of when we think the classic burst tones are played at higher volume with big amps. I say most because many distinctive and pleasant tones can come out of even Champs but when you discussed the nuance and minutia here, you have to consider how an instrument may react when between 2 and 8 12" speakers are involved. The force of sound coming out of these things can interact with the guitar in ways that amps at bedroom volume won't.
    I know from experience that playing an instrument through a 1x12 18 Watt and a half stack can be two significantly different experiences.
    I found the construction chapter in Bacon's book very interesting especially in regards to the wood they selected, how hide glue crystallizes and leaves a minimal film, etc. all very interesting.
    I'm certainly not an expert on the mechanical engineering aspects of instrument construction though so my assumptions and thoughts may be moot.
  11. LPandMarshall
    3
    4
    May 18, 2017
    @Open_Book
    Well, I guess we can at least agree, that there are significant differences between Les Pauls soundwise. Have you ever wondered, where they come from? Being played acoustically, there are really noticable differences. Some Pauls are bassy and muddy, others have a nice mid honk and have a slim bass response and many others have anything between. And the wood is the most important part of a guitar. I roughly preshaped around 20 Swietenia Mahogany neck blanks with the same size and the sound difference between the brightest and the darkest, was between a fourth (quart) and a fifth (quint)! That of course does something with the overall tone of a guitar! It changes the resonance frequency of the guitar. You cant deny that! I know, what I am talking about, because I experienced all that.
    But other things contribute their share, and also does glue. Not much, but a little. Regarding the celluloid inlays, keep them as flat as possible. More important: Dont cut the cuts for the frets deeper than necessary. I only lacquer the top. Back and neck are waxed, which makes a difference. Try that! And those small differences add up. If you change 10 minor important things, than you get a noticeable difference. And the electronics of course contribute their share, too. Sure, you dont have to believe that, but you better do. Trust me, I dont want to sell you something.
    I always wonder, if players, who deny such things, are able to hear the differences. Or do they only play with lots of effects and way too much gain to register those differences?
  12. PierM
    PierM Certified Naysayer Premium Member
    3,801
    6,509
    Aug 19, 2016
    I don't think anyone over here is denial about wood affecting tone. There is just the scientific approach, and the romantic one. First one can be discussed, the second it's a dogma; arguing on that last one it's a big waste of everyone's time. :)
  13. mudface
    mudface Senior Member
    5,982
    18,814
    Aug 29, 2016
    All i know is you can't draw on a tight joint, ...........you just can't keep it LIT.......
  14. Open_Book
    1,180
    683
    May 26, 2014
    There wasn't one part in my post where I said wood doesn't have some effect on tone. Thats a given.
    No. No I don't wonder. I've no need to. I'll state the obvious: Its wood. Its a variable. One plank doesn't necessarily yield identical pieces. Its wood. The weight and pitch of the wood is variable.
    Knocking up 20 necks doesn't make you an expert. Its your opinion. I spent years in a service dept for a major guitar manufacturer. I've probably handled more guitars than you've had hot dinners - my weeners bigger than yours... I know about guitars sounding different so you're preaching to the choir...
    Some people only hear what they want to hear cuz they think they have all the answers. Some are totally lost in their own BS.
  15. Mouse
    Mouse Senior Member
    2,715
    3,925
    Nov 2, 2008
    @Open book: amigo you just don't sound good, probably full moon thing.
  16. Pappy58
    Pappy58 Senior Member
    2,234
    4,408
    Dec 2, 2014
  17. LPandMarshall
    3
    4
    May 18, 2017
    Open_book
    Funny to see, how a post about guitar building experiences ends up into a weener comparision contest. As you posted, some people only see, what they want to see….. I havent claimed to be an expert! Working in an service dept for years has given you certainly a remarkable chunk of knowledge, but that doesnt make you an expert in BUILDING set-neck guitars either, I guess. It makes you an expert in repairing and checking/setting guitars. But again, you know your stuff and I dont want to talk that down.
    Yes, 20 Necks are not much and maybe I was just lucky and the results I achieved happened accidentially. Maybe, but probably not, because I can repeat the results. But what I can say is, that I observed exactly what I was doing and I kept track about what I was doing and learned what caused what. And glue for example is a part of that! I learn quickly. I can build Les Paul like guitars, which sound basically like I want them to sound and of course, I dont claim I am the only one who can do this. No way! I stated it earlier, there is no magic mystery in building guitars and I just offer knowledge here, that I have gained troughout the building process. A kind of knowledge, that is based on facts and not on myths.
    But you know what? I can make a thread about my next build and then you can judge, if I am only a bragger or dreamer with fuzzy thoughts and a little weener, or if the results I will get are satisfying. But I doubt, you would be interested, right? I can provide proof of what I'm writing here.
  18. Thermionik
    Thermionik Senior Member
    11,038
    33,074
    Jan 20, 2010
    I
    wonder
    what a guitar
    made from Tumbleweed timber would sound like
    RAG7890 and Thumpalumpacus like this.
  19. RAG7890
    RAG7890 Premium Member
    14,882
    23,764
    Jul 11, 2010
    ..........I have Copyrights on Tumbleweeds. :p :D
    :cheers2:
    Thermionik likes this.
  20. lewis_grey
    lewis_grey Senior Member
    278
    242
    Jan 11, 2010
    This thread is ridiculous...
    Thermionik and Gem23 like this.
