50s LP wiring with phase switch
Discussion in 'Tonefreaks' started by p_baker, Jul 26, 2017.
  1. p_baker
    p_baker Junior Member
    26
    9
    Jul 26, 2017
    Hi everyone,
    long time reader and first time poster here.
    Is this the correct way to wire a 50s wiring with the neck tone pot being a push pull pot, switching the phase of the two pickups in middle position?
    Thank you very much.
  2. ARandall
    ARandall Senior Member
    11,338
    6,499
    Apr 16, 2012
    Looks fine, as long as your pickups follow the Duncan colour coding..
  3. p_baker
    26
    9
    Jul 26, 2017
    I´m unsure about the push pull switch. Where does C1 go when the switch is pushed in? Is it going to 4? Then I would have the normal phase of the humbucker. Or is C1 going to 2? In this case, I think I would have the out of phase sound when the switch is pushed in since 2 is grounded.
    So basically, are 2 and 4 wired the correct way or do they have to be switched?
  4. ARandall
    11,338
    6,499
    Apr 16, 2012
    If you find you don't like the switch operation, simply reverse the connections you describe.
  5. p_baker
    26
    9
    Jul 26, 2017
    Allright. Thank you.
    One more question: What is used on a lot of Les Pauls to ground the pots? This bare silver wire. Is it a piece of solder?
  6. chasenblues
    chasenblues Senior Member
    19,148
    25,685
    Apr 2, 2007
    jonesy likes this.
  7. ARandall
    11,338
    6,499
    Apr 16, 2012
    Yep, its just a connection so there is no need for extravagance.
  8. jonesy
    17,138
    4,368
    Mar 28, 2008
    Here's my 50s wiring diagram for the JP#1 phase mod. Pickups are in phase when push pull is down. When pulled up it flip flops the leads on bridge pickup and neck and bridge will be out of phase when toggle switch is in the middle position. Red wire is pos. + and green wire is neg.
  9. jonesy
    17,138
    4,368
    Mar 28, 2008
    In your wiring diagram of push pull it would be in phase when pot is down and out of phase when pulled up. I am referencing the numbers on the PC boards of the black molded CTS 500K push pulls.
