335 Electronics Installation (a.k.a. How to take years off your life)
Discussion in 'Tonefreaks' started by hillbilly, Apr 8, 2009.
  1. Grahams Cat
    Grahams Cat Junior Member
    2
    0
    Aug 27, 2012
    Hi, Thanks for uploading. I found this article very helpful. However, trying to get the harness back into the guitar has had me running around my backyard with an axe! I've made two so far. I've mounted the pots on a template etc and wired up using braided cable insulated with clear plastic tubing, the same used to draw the pots through the holes. I've used cable lengths pretty much the same as the Gibson effort I removed and have referenced pics of pro harnesses.
    I'm having real issues with getting the damned thing into the guitar as it keeps tangling and getting stuck. Should I make the cables longer to add flexibility or will this make things worse? My last effort snapped the leg off my PIO cap, and is slowly driving me mad! I'd appreciate any advise! Thanks G
  2. freddarl82
    freddarl82 Senior Member
    776
    208
    Mar 12, 2009
    When I did mine, I used a template to build (as you did) but allowed just a little bit of slack in the vintage braided cables running between the pots. You've got to give yourself a little bit of "real-world" tolerance in order to work the pots up into the holes, IMO.
  3. Grahams Cat
    2
    0
    Aug 27, 2012
    :rofl:Ha ha..........at last!
    The damned thing works!!! Def worth making a larger harness. Keeping everything distanced from the switch is the key to avoiding congestion through the pick up aperture. A pair of angled long-nosed pliers helps guide things along via the f-hole. Also earth leads long enough to secure each pick-up pot set prior to stuffing the next set in is useful as too many plastic tubes soon takes up the access.
    For the jack-socket I shaved the plastic plug down on a patch lead & fed it through, again with a lead long enough to secure with the switch sitting in the pick-up well.
    :band: Now finally enjoying my BKP Stormy Mondays and the family's talking to me again. Manys thanks to Hillbilly for that article & everyone else.
  4. MiniB
    MiniB Senior Member
    4,076
    2,924
    Dec 31, 2012
    Hah....I love this thread title...
    "335 Electronics Installation (a.k.a. How to take years off your life)"
    I always tell people that if they haven't tried replacing the electronics/pickups on a 335 before, get ready for the most frustrating day of their lives. :)
    It gets better the more you do it and your hands get more used the contortions it has to do. I also made a wire tool that helps grab or steady things.
  5. mux164
    mux164 Senior Member
    2,631
    1,898
    Sep 1, 2012
    awesome just awesome
  6. neozecat
    neozecat Senior Member
    351
    515
    Sep 23, 2009
    Very helpful thread.
    Thank you Billy :applause:
  7. LPofBorg
    LPofBorg Warranty Voider Premium Member
    715
    949
    Feb 26, 2014
    Thanks to Billy and all the contributors. Setting about to re-wire the Epi Dot.... Not sure I'd have attempted it without reading this thread first. Awesome info!
  8. SilverBurps
    SilverBurps Banned
    341
    257
    Oct 1, 2014
    After reading through this, I'm REALLY glad my 339 has its rear access plate!
  9. Weldaar
    Weldaar V.I.P. Member
    2,357
    403
    Mar 25, 2007
    What an excellent post Hillbilly. Thanx so much for taking the time. :applause:
  10. dcooper830
    dcooper830 Senior Member
    1,556
    520
    Aug 29, 2007
    I did one of my Epi DOTs a few weeks ago.
    Complete replacement of pickups, wiring, pots, switch and output jack.
    I'd never done a semi hollow before.. but I wanted to experience it... and I want to do it again several more times to get better and better at it!!
    I'll post some pics... feel free to laugh at my horrible wiring mess LOL!! Hey it was my first time!
    I plan on improving my skills in this.
    On my bench. I apprenctice at a guitar repair shop. I mostly do setups and pickup swaps.. and starting to improve my fretwork skills. Eventually i want to learn how to repair cracks and breaks.. and do finish work as well... but anyway... I took my own Epi DOT in there so I could get some experience doing semi hollow rewiring...
    The new stuff.... StewMac Golden Age Parsons Street Humbuckers and their deluxe wiring kit.
    Template:
    Other side LOL!!
    All the original electronics out... the Stew Mac pickup container is great for holding the strings out of the way!
    Getting it wired up... I'm happy with my solder joints.
    Ready to go in...
    The string I was using was too thick!! Gave me some greif... I like the plastic tubing idea and will use that next time.
    Sounded very good!! But got muddy when rolling back the volume... I I took it all back out and installed treble bleeds on the volume pots...
    All done!
    Came out pretty good. I got what I wanted which was a LOT more clarity! Also deeper bass and higher highs... a more extended tonal range.
    Although... It still seems there is a lack of punch on the low strings.. like when I trying to do some tight sounding riffs... but I've only played it on a couple gigs so far... gonna keep working with it.
  11. Woderwick
    Woderwick Senior Member
    7,467
    57,003
    May 22, 2012
    Do yourseof a favour, before you pull all the old stuff out, tie some fishing line around the pot shafts etc. Then you can attach that to the new stuff and pull it back through.
  12. Playyouraxeon11
    Playyouraxeon11 Banned
    105
    42
    Mar 4, 2015
    Big thanks to all. Now I know to leave my 335 alone. But I have a Les Paul complete change to do, that looks like a piece of cake (mocking, scary laughter now). We'll see.
    But big, big thanks, great post.
    So! If you see an ants nest kick it, but not always.
  13. Dilver
    Dilver Senior Member
    945
    1,357
    Apr 26, 2011
    Just replaced the pots and caps on my CS-336 and installed treble bleed caps while I was at it. What an ordeal. I've used the tubes method for snaking the pot shafts up through the holes on hollow bodies before, but with the 336, there just isn't room.
    Biggest hassle is having things get tangled up inside. Rather than long leads I found it easier when each set of pots (e.g. Bridge pickup volume and tone pots) was pretty closely spaced and I ran kitchen twine on just the tone pot shafts, using my fingers to pop in the volume pots. This minimized the number of things to get tangled up in. Also helps to tape off the f holes to prevent any finish scraping, and having a set of thin long needle noses pliers
    Hoping I won't have to do that again any time soon!
  14. WesB
    WesB Senior Member
    182
    115
    Sep 22, 2014
    The easiest way I’ve found to open up the pot holes is with a pencil and fine sand paper. Just wrap a layer or two around the pencil to give a snug fit and give a twist. Only took a couple twists to open the holes on my Burny from metric to sae. No worries about chipping the finish with a bit
