2x12 cab to match Marshall 2245
Discussion in 'The Squawk Box' started by Rubber Duck, Nov 3, 2017.
  1. Rubber Duck
    Rubber Duck Member
    51
    154
    Sep 9, 2013
    I am considering a Marshall 2245 reissue head, but I am looking for a 2x12 to match it.
    Basically I want a cab that looks like a 1960AX but with the size of a 1936.
    Checkerboard front and vinyl "leather" like the 2245 head, no corner protection etc.
    I checked the Marshall "design shop" but it seems hard to get it spec'ed like I want.
    An empty cab could work, I can install speakers and wiring myself but the vinyl I hope to get fitted from supplier.
    I checked out a few cab builders but so far I haven't found what I'm looking for.
    Any suggestions on where to look?
  2. Brewdude
    Brewdude Senior Member
    833
    1,373
    Jun 26, 2014
    http://sourmashguitarcabs.com/
    Id highly recommend Sour Mash, Ive bought a head and cabinet from them and both are absolutely gorgeous and very well made. I think they are even very reasonably priced for what you are getting too.... You can also pretty much customize them to whatever design options you'd like, just send them an email if you can't configure it online to your exact spec and they can probably make it happen.
  3. Rubber Duck
    Rubber Duck Member
    51
    154
    Sep 9, 2013
    Thanks Brewdude, this might be exactly what I am looking for.
  4. Big John
    Big John banned, mentally V.I.P. Member
    7,011
    5,665
    Mar 18, 2007
    Could also go with this Mojo and put a Marshall logo on it.
  5. tolm
    tolm Bigsby Junkie Premium Member
    3,639
    2,148
    Jul 20, 2008
    I've was very disappointed to discover that the 2061CX cab is 15mm narrower than the 2245 head ... would have been a perfect match, otherwise. I ran my 2245 through a Cornford 2x12 with Vintage 30s. Solid pine, though ... damn thing weighed 30kg ...
  6. GySgtFTL
    GySgtFTL Senior Member
    931
    704
    May 8, 2011
    Mather cabs. As good as it gets.
  7. EndGame00
    EndGame00 Senior Member
    696
    319
    Sep 1, 2013
    Avatar makes 2x12 diagonal cab.
  8. Rubber Duck
    Rubber Duck Member
    51
    154
    Sep 9, 2013
    Thanks for all the inputs.
    I was instantly convinced that I need a Mather cab when looking at their site, it appears to be spot on for my need. Also Sourmash seems very nice.
    As I am located in the o-so-far-from-US country of Norway, it turned out that none of them are able to ship to me. Still hard to get over the Mather cab but I guess I need to move along.
    So, anyone knows of builders in Europe doing the same stuff?
  9. The_Nuge
    The_Nuge Senior Member
    1,733
    1,146
    Dec 12, 2010
  10. Rubber Duck
    Rubber Duck Member
    51
    154
    Sep 9, 2013
    Thanks, looks interesting, especially with the convertible back.
  11. The_Nuge
    1,733
    1,146
    Dec 12, 2010
    I think they speak English too, but if you need assistance, please let me know!
  12. Rubber Duck
    Rubber Duck Member
    51
    154
    Sep 9, 2013
    Thanks for your help. I will send them an email.
    The cabs looks good I think, but I can find very little info online about them. Have you tried their cabs? Or heard any customer feedback in general?
  13. The_Nuge
    1,733
    1,146
    Dec 12, 2010
    A friend of mine ordered a Dumble Combo cab from TT, and it's well made. However, if you can do a bit of woodworking, you can make your own quite easily. I'll post some pics of mine later on.
  14. derms87
    derms87 Senior Member
    201
    161
    May 5, 2010
    +1 for sourmash cabs. They made me a custom head cab for 36watt head and it was exactly what I wanted. Fit and finish was second to none.
    Best of luck finding what you are after.
  15. The_Nuge
    1,733
    1,146
    Dec 12, 2010
    As I said earlier, you can make you own quite easilly too! Here are mine:
    Geeze likes this.
  16. Geeze
    Geeze Junior Member
    9
    9
    Feb 18, 2017
    This or find a design, figure out size requirements and contact a cabinet shop. My preference is for hardwoods over plywood as many of them are lighter in weight - pine, poplar, African mahogany are a few. If you go down this road the http://www.wood-database.com/ is a great place for wood 'specs'. You don't have to cover it either -
    Russ
    RAG7890 and The_Nuge like this.
  17. sonar
    sonar Senior Member
    2,825
    1,875
    Sep 10, 2008
    I'd also recommend looking for a local cabinet shop, although I still prefer my amps in tolex.
    I had a Marshall 2X12 cab, pre-800 by a few months, so it had the modern looks without the 800 badge. One of the best cabs I ever owned.
  18. NHTom
    NHTom Senior Member
    619
    662
    Jun 7, 2014
    I just picked up a Swanson Cabinet for my MGL20..........has that older "look" to it.
    NHTom
  19. bblooz
    bblooz Senior Member
    2,301
    854
    Oct 8, 2014
    What's wrong with a 1936? Mine sounds incredible, and is a lot lighter than a 1960. Here's a pic of my 1936 behind the 335 (and the 2245 w/KT-66s).
  20. dsmcl77
    dsmcl77 Senior Member
    2,687
    7,742
    Jun 2, 2014
