2017 Tribute HB mods
Discussion in 'The Custom Shop' started by tigger, May 8, 2017.
  1. tigger
    tigger Senior Member
    375
    424
    May 6, 2017
    Still no nitro. Called R&F and the package got rejected on border because it lost it's declarations. They are sending a new one. Very pleasant to talk to.
  2. Riffster
    Riffster Senior Member
    310
    180
    Apr 9, 2010
    You did an amazing job on that binding.
    Who likes this.
  3. RayTorvalds
    RayTorvalds Senior Member
    1,066
    878
    Apr 29, 2015
    Agreed, looks really good ! :applause:
    Who likes this.
  4. tigger
    375
    424
    May 6, 2017
    I'd wait until I put the lacquer on! :) All sorts of horrible things can happen!
  5. tigger
    375
    424
    May 6, 2017
    I put the first coat on (2 light coats, 15 min apart). It looks fine but there are some specks of dust in. I'll have a look at it tomorrow to see if I need to sand them out or whether they aren't actually visible.
    Who likes this.
  6. tigger
    375
    424
    May 6, 2017
    Second coat on. I'm worried about peeling the masking tape off to be honest. Perhaps I should score it with a razor blade first. Or also spray some wood with masking tape and test.
  7. tigger
    375
    424
    May 6, 2017
    Final coat is on and the tape went off without any issues, magic.
    GitFiddle and Who like this.
  8. tigger
    375
    424
    May 6, 2017
    600->800->1000->1200->1500->No2 scratch remover
  9. tigger
    375
    424
    May 6, 2017
    Cream back plates (missing correct screws), Faber ABR-1 bridge, selector switch washer. Missing: proper set-up, electronics (found out my iron is too weak to solder to pots, used to be fine).
    TheWelder, 61LPSG, n32 and 13 others like this.
  10. musicmaniac
    musicmaniac Senior Member
    6,476
    2,525
    Aug 11, 2012
    Awesome job congrats!
  11. tigger
    375
    424
    May 6, 2017
    Thanks!
  12. stp
    stp Senior Member
    100
    23
    Jun 3, 2015
    only see cream backs on eppi
  13. tigger
    375
    424
    May 6, 2017
    THat explains why the plates a re a little thinner I suppose. I much prefer the look of cream plates but might need to insert washers underneath.
  14. tigger
    375
    424
    May 6, 2017
    I broke off one of the stock Gibson pot lugs while trying to bend it to make an eye. I ordered proper CTS 500k pots..
    SD456 and Who like this.
  15. Who
    15,819
    28,142
    Mar 15, 2012
    That's the nicest faux binding job I think I've ever seen.
    To sand the top, you just did it by hand, guiding it with your finger?
    tigger likes this.
  16. tigger
    375
    424
    May 6, 2017
    Thanks. In convex parts, I used a jig made of two tiny pieces of wood. In concave parts I that to make a line and then used finger as a guide as you say.
  17. ARandall
    ARandall Senior Member
    11,803
    7,199
    Apr 16, 2012
    Very nice. I did my HB using hand sanding and can't recall spending as long as you......probably better for your process as you could get a shine with less added coats.
    And yes, only epis and chinese fakes get cream plastics.
  18. sasquatch
    sasquatch Premium Member
    1,730
    388
    Jun 29, 2008
    You must be getting calls from the big guys
    there's no way someone hasn't noticed your work
    and 'needs this guy' in their shop
  19. tigger
    375
    424
    May 6, 2017
    Thanks for the compliment, but I'd probably cut my arm off or something. I am also a little overqualified for their payroll :)
  20. Neb
    Neb Junior Member
    6
    2
    Aug 2, 2017
    Great work! I wonder what's all the hype about plastic bindings and plastics in general on guitars about anyway, yours is pure mapple now ;)
