2015 Les Paul CM - Modding Question
Discussion in 'Gibson Les Pauls' started by lawrev, Oct 20, 2018.
  1. lawrev
    lawrev Senior Member
    192
    135
    Aug 27, 2014
    Hi Everyone,
    I'm in the process of purchasing a 2015 Les Paul CM - brand new and in the box from Sam Ash. Great price too.
    The first mod I am going to do is get rid of the robot tuners and put in normal ones. I'd like to get white button tuners like on a Junior. I was told by someone else that the 3 on a plate type will slide into the existing holes just fine, but that drill holes will need to be added to affix them to the body. Are there any other types/makes that would work with no major retrofitting? I hear Grover is a possibility.
    Any and all thoughts are appreciated. Thanks!
  2. mudface
    mudface Non-Deadbeat/Non-Prominent Double Platinum Supporter Premium Member
    6,376
    20,578
    Aug 29, 2016
    Do you mean one of these?
    marcelm and lawrev like this.
  3. Norton
    Norton Senior Member
    526
    454
    Dec 12, 2013
    I’ve played a handful of the CM guitars. None of em had robot tuners.
    Super cool stripped down rat rod guitars.
    lawrev likes this.
  4. lawrev
    192
    135
    Aug 27, 2014
    Yep. Got a 2015 with the robot tuners still on, and the 2016s had eliminated that, wisely. Once the tuners are replaced, the pickup is next. I want either a Gibson 57 Humbucker or a SD Pearly Gates. But I plan on playing the stock pickup for a while before I make any final decision.
    endial likes this.
  5. dc007
    dc007 Senior Member
    778
    1,168
    Jan 5, 2010
    Only thing I slightly disagree with in the video is not pre drilling the tuner screws. It appears you will discover there are no holes drilled in the headstock with the G Force system.
    lawrev likes this.
  6. dc007
    dc007 Senior Member
    778
    1,168
    Jan 5, 2010
    Let us know how you like the stock pickup. I like those guitars and Sam Ash is getting rid of the 2015 stock they are sitting on. As much as I like lower output pickups in a Les Paul if I had one of those I would put something a little hotter and nastier in it. Single pickup Les Pauls are not supposed to be polite.
    endial, yamariv, Lloyd_m and 2 others like this.
  7. edselman
    edselman Senior Member
    1,241
    679
    Mar 19, 2010
    The three-on-a-plate tuners are available from Grover or Kluson. They are stamped sheet metal like the originals and are nickel plated only. If your tailpiece is chrome you may want to swap that out so that everything matches. Also, the new tuners use press-in bushings. These need to be the conversion ones as the holes for modern USA Gibson’s are too large.
    lawrev and mudface like this.
  8. edselman
    1,241
    679
    Mar 19, 2010
    Another thing, if you just want white plastic buttons I believe that the only company that makes single tuners with these is Kluson (I could be wrong on this). They are still vintage correct, nickel and need conversion bushings. The other option is to put new buttons on your existing tuners, but that’s another issue I know nothing about.
    lawrev likes this.
  9. Gibsonian
    Gibsonian Member
    96
    79
    Nov 1, 2013
    I have the exact same one. Love my robot tuners, especially because I'm tuning challenged, i.e fairly tone deaf.
    lawrev and Arpeggio like this.
  10. Arpeggio
    Arpeggio Junior Member
    6
    5
    Oct 18, 2018
    I have a ‘15 CM also. Like many others who bought one, I’d planned to ditch the robot tuners and the pup. After playing it, I’ll keep it stock for the time being, maybe forever. I plan to experiment with alternate tunings and this is a really good starting point for that. I’m very happy with the ‘61 Zebra pickup. Good crunch at the end of the dial and it cleans up nicely when you roll it back. This is a great guitar and I have zero regrets about its trimmed-down finish and features.
    Gibsonian, lawrev and dc007 like this.
  11. lawrev
    192
    135
    Aug 27, 2014
    Thanks, everyone, for the replies. I am definitely getting rid of the robot tuners, but I will keep the 61 Humbucker a while to see what I think of it. I don't want something too hot, so I will be curious to see how this unit is. Normally I'd purchase a more expensive guitar (and just purchased a 06 SG to fit that bill), but this one is something I can see really cranking on.
  12. 6pack Jon
    6pack Jon Premium Member
    449
    108
    Jun 17, 2009
    Sperzel Ez mount tuners. No extra holes needed. The buttons can be swapped out for smaller ones.
    Arpeggio likes this.
  13. MSB
    MSB Senior Member
    2,562
    2,706
    Jan 21, 2015
    I had a '14 MM for awhile, and fell in love with the thin body. I've tried to like SGs, but never been successful. So much so I got a '15 Less + and sold my standard faded. Even my Studio Standard feels awkward now. These thin bodied LPs are sleepers, imo. I really never play the neck pickup, so quite frankly, this is almost the perfect LP for me. It doesn't have the bling, which turned me off for awhile, but it's got everything else I want. I'd obviously get new tuners, but I still don't get why Gibson puts 1 bridge pickup guitars knobs in the neck position.
