2002 standard to '59 'burst re-fin make-over project.
Discussion in 'The Custom Shop' started by badly drawn les, Dec 5, 2014.
  1. badly drawn les
    badly drawn les Senior Member
    725
    1,270
    Sep 27, 2010
    This has been my gigging guitar for 5 or 6 years now. I like the way it plays. I like the way it sounds, particularly since I put in a pair of Mules & re-did the wiring to 50s spec. However, I never liked the glossy cherry 'burst. I've heard these referred to as "clown 'bursts", & I can see Ronald MacDonald playing one of these.[​IMG]
  2. badly drawn les
    725
    1,270
    Sep 27, 2010
    Or maybe as a back-up to one of these.[​IMG]
  3. badly drawn les
    725
    1,270
    Sep 27, 2010
    However, it has a nice flame 'burst, not too over the top, just to my taste. I did a half hearted make-over a few years back. I tried to fade it in the sun, waste of time. I tried to get some checking/patina going' waste of time. Gibson use some crappy plasticy lacquer that they have the cheek to call nitro, hah.
    My options are; sell it & get a R9 (Yikes 3 grand) but still have the same lacquer, or strip it down & start again. You know what I chose.
    I paid £1k for this, OK , short tenon, swiss cheese body, but Gibson made a quantum leap in 2002, making them better than they had done in decades. I feel a project coming on.
  4. badly drawn les
    725
    1,270
    Sep 27, 2010
    OK, let's get this plasticy crap off, but what do I use? Stripper, sander, heat gun? I remember when I was a teenager, going through my Mick Ronson phase. I stripped the front of a 70s goldtop deluxe with paint stripper, yikes, the binding turned to jelly. I tried to save it with masking tape until it set & then sanded it. Just about got away with it but I learnt my lesson. At least it isn't poly, that's a bitch to get off. I went with a heat gun & scraper.[​IMG]
    3 people like this.
  5. badly drawn les
    725
    1,270
    Sep 27, 2010
    I was terrified to get the heat gun too close to the binding but it's tougher than I thought, no problems at all.[​IMG]
    5 people like this.
  6. badly drawn les
    725
    1,270
    Sep 27, 2010
    As I said, plasticy crap. Looks like tomato peel & feels very soft & flexible.[​IMG]
    2 people like this.
  7. badly drawn les
    725
    1,270
    Sep 27, 2010
    Get stuck into the top.[​IMG]
  8. badly drawn les
    725
    1,270
    Sep 27, 2010
    2 people like this.
  9. So What
    So What Senior Member
    8,576
    18,332
    Feb 29, 2012
    Curious to see this...
  10. badly drawn les
    725
    1,270
    Sep 27, 2010
    As you can see over the nut, all the colour is in the lacquer.[​IMG]
  11. badly drawn les
    725
    1,270
    Sep 27, 2010
    I'm a bit scaredy-cat to use the heat gun on the neck, so, old fashioned scraping there. [​IMG]
  12. badly drawn les
    725
    1,270
    Sep 27, 2010
    It had these funny lugs for the bridge posts. I had used conversion posts from Browns Guitars (which were rather good) but I thought I may as well do it properly, so out they came. I made a little mask, to stop any chipping but I could have pulled them out with my fingers. Pretty loose.[​IMG]
    1 person likes this.
  13. badly drawn les
    725
    1,270
    Sep 27, 2010
    I couldn't help but notice, the most beautiful slug on my lawn. A rockabilly slug for sure, or maybe a Cramps fan.[​IMG]
    Limeshack, jimmer_5, rykus and 6 others like this.
  14. badly drawn les
    725
    1,270
    Sep 27, 2010
    OK, all stripped & sanded.[​IMG]
    17 people like this.
  15. badly drawn les
    725
    1,270
    Sep 27, 2010
    2 people like this.
  16. badly drawn les
    725
    1,270
    Sep 27, 2010
    Right, let's tackle those bridge post areas. I had to plug them but I wanted to keep the maple top as clean as poss. I measured the holes & bought some steel tube with an internal dimension the same as the holes. I filed the tube down & put some teeth in it, to make some plugs.[​IMG]
  17. badly drawn les
    725
    1,270
    Sep 27, 2010
    I cut a couple of plugs from some hard-wood I had (oak, maybe) I then cut some plugs from the maple inside the control cavity.[​IMG]
  18. badly drawn les
    725
    1,270
    Sep 27, 2010
    Like this.[​IMG]
    2 people like this.
  19. badly drawn les
    725
    1,270
    Sep 27, 2010
    Trying to get the grain in the right direction, I glued & tapped them in.[​IMG]
    2 people like this.
  20. badly drawn les
    725
    1,270
    Sep 27, 2010
    Right, other things to do before spraying. Round off the fret ends.[​IMG]
