1st(technically 2nd) scratch Les Paul-build
Discussion in 'Luthier's Corner' started by Windir, Oct 14, 2017.
  1. SlingBlader
    SlingBlader Premium Member
    310
    227
    Dec 7, 2013
    Hey, I'll just echo what ARandall said. You're asking again for advice on how to fix that "dent" and you were already given some advice about that...
    Frankly, you are not acknowledging ANY advice given here. You continue to plow forward at breakneck speed trying to hit some kind of self-imposed (and unrealistic) deadline.
    I"m beginning to wonder if you're just yanking our collective chain... :)
    Oh, it's difficult to see it in that picture, but did you remember to rout the wiring channel before you glued the maple cap to the body?
  2. rockgod212
    rockgod212 Senior Member
    169
    23
    Nov 5, 2012
    oh i hope you did the wire channel, your screwed if you didn't. at the rate your going, I wouldn't even do a binding channel, unless you have the right binding jig/ palm router. your need to get that neck pocket level and shim it then re route if you have too. pup cavities can easily be fixed with a good router and good bits. I would route the binding channel first then blend it all back in.
    slow down..............
  3. failsafe306
    failsafe306 Senior Member
    109
    101
    Aug 31, 2016
    I am not seeing a wiring channel :Ohno:
  4. ARandall
    ARandall Senior Member
    11,801
    7,196
    Apr 16, 2012
    I'm thinking (hoping) I do......a faint diagonal
    SlingBlader likes this.
  5. Windir
    Windir Member
    32
    7
    Feb 23, 2016
    Yes.I did route the wiring channel. It's barely visible because the base of the neck pickup cavity looks like i had used a blowtorch to remove all the material. Still, it's definitely there.
  6. SlingBlader
    310
    227
    Dec 7, 2013
    Good deal, it was hard to tell for sure. :thumb:
  7. ARandall
    11,801
    7,196
    Apr 16, 2012
    Once more -
    Most of your routing should be done by not routing. Drill out the routs to remove most of the bulk. Even than you should do a pass with the router that removes the remainder of the bulk wood before then doing a fine pass that finally touches the template. This last pass should ideally be less than a mm of wood being removed.
    This is the same for the base. The drilling takes out the majority of depth.....you then do the last pass for depth to remove less than a mm of wood so you get a smooth bottom. Even with very dull bits (which I have used myself when they are due for upgrade) I never end up with the hideous mess you have. Below is a minimum standard for the crisp lines you should be able to achieve.....and should not stop until you do achieve. I still see flaws in this quality of work, but it is hidden so I don't feel the need to go any further.
    Skyjerk likes this.
  8. Skyjerk
    5,740
    6,605
    Feb 9, 2014
    Seriously, what has been said a dozen times.
    You need to slow down, and you need to read (and heed) the advice that's being offered.
    It looks like you try to make a cut, and then ask how to do it while explaining how it went wrong and mangled this or that.
    I totally dig your enthusiasm, man. Still, you cant let it dictate your pace.
    Rushing madly ahead can do damage to more than just your build. You can severely damage yourself as well making mistakes like you've already described. Like picking up your router before its stopped. Be glad it was just a template that paid the price.
  9. SlingBlader
    310
    227
    Dec 7, 2013
    May I point out that you built this whole thing backwards?!?
    :naughty:
    charisjapan likes this.
  10. Windir
    Windir Member
    32
    7
    Feb 23, 2016
    A quick update:
    I made a new neck pocket template yesterday and re-routed the neck cavity. I made neck pocket wider by couple mm:s, getting rid of all the bumps i made previously. There's some burn marks on the bottom but the bottom is perfectly square and flat( unless my metal woodworking square's warped).
    Now i only need to clean the pickup cavities little bit because i didn't finish the job and they look awful.
    failsafe306 likes this.
  11. ARandall
    11,801
    7,196
    Apr 16, 2012
    Much better
  12. ARandall
    11,801
    7,196
    Apr 16, 2012
    Thats the first time I've heard that
    today;)
  13. SlingBlader
    310
    227
    Dec 7, 2013
    Uh... I realize this is your own thread, but how is that comment in any way relevant or appropriate?? Certainly unnecessary.
    :facepalm:
    dickjonesify likes this.
  14. timgman
    timgman Senior Member
    1,806
    429
    May 6, 2008
    Well, I'll say this. You've accomplished more in 2 weeks than I have in over 1 year.
