~1980 BC RICO refinish
Discussion in 'Luthier's Corner' started by The_Nuge, Dec 13, 2010.
  1. The_Nuge
    The_Nuge Senior Member
    1,761
    1,173
    Dec 12, 2010
    Hi!
    This is my second post, so please be patient with me if this has been discussed before! And yes, I did try searching for the answers!
    I've had this ~1980 BC RICO for maybe 15 years now, and i've thought it was a great guitar. A bit neck-heavy maybe, but good tone and playability.
    My son unfortunately pushed it off its stand a couple of years ago which resulted in the wood around the pots cracking.
    It's quite a rare guitar, being one of only a few BC RICO's being made in Japan before the Rico Reed Co. decided to complain. After that they became known as BC Rich NJs - if anyone has more info I'd love to know!
    I'd like to restore it to its former glory - I have all the hardware - and need some tips:
    1. Is it a nitro or PU finish? I've tried soaking one of the cavities with nitro thinners for about 2 min, which didn't affect the finish at all. I presume it's PU...
    2. If I refinish in PU, will I need to strip the guitar completely?
    3. If so, what's the best way to do so (I live in Germany so may not have access to the same chemicals as in the US).
    4.Some of the damaged areas will need a bit of filling. What's the best stuff for the job?
    5. What's the best way of getting that nicotine yellow hue to the white finish?
    Here are some more pics:
    Lot of questions, I know...
    Cheers!
    mzmo likes this.
  2. j.six
    j.six Senior Member
    2,244
    1,746
    Aug 22, 2008
    that is a SWEET mockingbird! I can guarantee you it's not nitro.
    Sully
  3. shtdaprdtr
    shtdaprdtr Senior Member
    3,095
    249
    Oct 30, 2008
    I say leave it as is...it is currently in its former glory and a refinish would destroy the whole vibe.
  4. TheZ
    TheZ Senior Member
    996
    609
    Nov 9, 2009
    I second that
  5. Stike
    Stike Senior Member
    111
    27
    Dec 10, 2009
    Leave it. It's a polyester finish. A chemical stripper will work on a catalyzed urethane but polyester puts up a good fight with even the strongest of strippers.
  6. The_Nuge
    1,761
    1,173
    Dec 12, 2010
    Hi Again,
    Thanks for all your replies!
    I don't usually mind dings and scratches - I mean I bought it in very much the same condition as it is now. However, the control cavity will need something doing to it as it's not very solid at all. And my gut still tells me to do a refin...
    @Stike: are you sure it's a polyester finish? I once stripped a Fender Lead with a polyester finish which turned out to be a pain - but this stuff looks different. Any way one can tell for sure?
    cheerio
  7. bfcg
    bfcg Senior Member
    4,378
    174
    Dec 6, 2008
    Check inside the control cavity for cracks in the wood along the grain. When the guitar fell over it might have pushed the control knobs into the wood possible causing those cracks. If you find a crack just wick some CA into to stabilize.
    I would leave the rest of it alone, it looks very cool the way it is.
    That "nicotine yellow" is never gonna go away.
  8. El Toro
    El Toro V.I.P. Member
    1,961
    74
    Aug 20, 2007
    So cool!
  9. mdr40z
    mdr40z Senior Member
    717
    86
    Jan 27, 2008
    personally I like the idea of a refin, maybe bright red :-')
  10. Stike
    Stike Senior Member
    111
    27
    Dec 10, 2009
    Very sure, I refinned this Rico earlier this year-polyester.
    Pretty much anything made in Asia has a polyester finish, there are some exceptions but way more often than not it'll be polyester.
  11. El Toro
    1,961
    74
    Aug 20, 2007
    I just bought an early 80's Eagle NJ, silver and beat... what do you think those are worth?
  12. bertzie
    bertzie Senior Member
    19,424
    24,541
    Sep 4, 2010
    Why restore it to its original glory, when you can make it better?
  13. The_Nuge
    1,761
    1,173
    Dec 12, 2010
    I could live with better! What do you suggest?
  14. JonMan94
    JonMan94 Senior Member
    6,477
    1,657
    Sep 22, 2008
    id say go for it... then put like a venner to stablize the top, and then refinish
  15. The_Nuge
    1,761
    1,173
    Dec 12, 2010
    So...
    I went and bought a heat gun today and have so far removed about 3/4 of the paint on the body:slash:. I can confirm it's polyester as it comes off really easily once heat is applied! The damage doesn't look too bad and I'm confident it will be easy to fix with super glue. I might reinforce the control cavity with a piece of copper sheet which will then double as shielding.
    I haven't started on the neck yet as I a bit worried about applying too much heat but will see if I can summon some courage tomorrow...
    I want to repaint in a similar white to the original colour and am considering doing it with rattle cans... Any suggestions? I'm looking for paint that's readily available in Germany or at the very least central Europe.
    Cheers!
  16. ptate
    ptate V.I.P. Member V.I.P. Member
    3,671
    3,120
    Mar 19, 2007
  17. shtdaprdtr
    3,095
    249
    Oct 30, 2008
    How long till we see it on Ebay?
  18. The_Nuge
    1,761
    1,173
    Dec 12, 2010
  19. The_Nuge
    1,761
    1,173
    Dec 12, 2010
    Never! I've had it for so long - and don't need the money - it's staying!
  20. ptate
    3,671
    3,120
    Mar 19, 2007
    Can't you get it through his Belgian suppliers, here?
    Lutherie
    Peace.
