1973 Custom Neck refinishing
Discussion in 'Norlin Years' started by MT-Guitars, Feb 22, 2018.
  1. MT-Guitars
    MT-Guitars Member
    82
    134
    Dec 21, 2017
    CA8ACF6B-53E5-4ABB-A729-9745CADBC9D3.jpeg FB363539-9D15-4F5C-A53F-91F1A5735844.jpeg 0FBA3EE7-0C3A-493F-990D-F0A5702D3779.jpeg
    Customer was unhappy with his painted neck, it had been refinished before and the paint used made the neck very sticky and hard to play. We suggested a tinted Tung oil finish, Customer is very happy with the look and feel. Though not for everyone it’s a good alternative to painting a neck.... original tuners going back on which cover the holes left by some Grover’s that were fitted during its life..
  2. HardCore Troubadour
    HardCore Troubadour Senior Member
    8,583
    6,542
    Nov 17, 2012
    Ever done an entire body??
  3. NorlinBlackBeauty
    NorlinBlackBeauty Senior Member
    8,524
    24,542
    Oct 29, 2017
    I have one of those ...
  4. MT-Guitars
    MT-Guitars Member
    82
    134
    Dec 21, 2017
    About too, many days sanding, I don’t use paint stripper.....
  5. 1981 LPC
    1981 LPC Senior Member
    2,192
    1,547
    Dec 8, 2010
    I stripped the original finish off two years ago for the same reason. A combination of slick bare maple and sticky original finish hampers playability.
    Covered the neck with a few thin coats of Tru Oil. Wish I had done it sooner. Originality be damned.
    Moby Dick and MT-Guitars like this.
  6. MT-Guitars
    MT-Guitars Member
    82
    134
    Dec 21, 2017
    90A24FBA-64EF-4D64-8F25-8A4C03037FC8.jpeg Original tuners back on, happy with the end result..
    1981 LPC and Moby Dick like this.
  7. HardCore Troubadour
    8,583
    6,542
    Nov 17, 2012
    I think the entire guitar would look really great with that finish.
    scozz likes this.
  8. Dilver
    Dilver Senior Member
    1,013
    1,516
    Apr 26, 2011
    Out of curiosity, how much would the fact that the neck finish has been stripped impact someone's decision to buy a Norlin era LP? Would you expect to pay less because of it?
  9. grumphh
    grumphh Senior Member
    787
    476
    Oct 10, 2015
    Yes.
    That's a partial refin and takes away value.
    ...also, unless it was a bargain i would't even look in the direction of an unfinished neck - who knows if the *censored* doing the refin hasn't sanded down the neck while at it?
    Now, on newer Gibsons i have experienced the "sticky neck syndrome" and with those it is different - i'd look at one with the finish removed - but no Norlin i have ever held did have necks that were as sticky as the newer ones are.
  10. MT-Guitars
    MT-Guitars Member
    82
    134
    Dec 21, 2017
    Owner wouldn’t sell it, and minimum sand paper used was 400 grit, why it took hours to sand.
  11. 1981 LPC
    2,192
    1,547
    Dec 8, 2010
    Aceton!
  12. MT-Guitars
    MT-Guitars Member
    82
    134
    Dec 21, 2017
    This neck can be painted again, the process is reversible, Tung Oil can be painted over, we wouldn’t resand the neck. This was discussed with the owner before the work commenced. At least the owner can now see his serial number, the previous refinish had covered it and “Made in USA” up.
  13. kakerlak
    kakerlak Senior Member
    1,813
    864
    Feb 5, 2014
    @MT-Guitars I don't think anybody's implying that you over-sanded the neck, just that they'd be hesitant to buy a guitar off the internet that had been sanded/refinished. I'd be the same way -- not so, if I had it in hand and could clearly tell that the work was done right. I've seen so many amateur refins where folks got carried away sanding off the old finish that they distorted body countours, destroyed crisp edges, altered the neck shape, etc. Those can look okay in photos, but not in hand. I'm sure you've done a professional job of removing finish, but not wood and that the owner is happy with the work done. I like the black-and-tan look it's got, now!
  14. grumphh
    787
    476
    Oct 10, 2015
    Just in case i was misunderstood - i did not want to imply that this particular finish removal was done shoddily :)
  15. MT-Guitars
    MT-Guitars Member
    82
    134
    Dec 21, 2017
    I understand, I’m fixing a SG that had a Headstock break, someone has sanded the neck causing a dip. There fix was a lot of spray putty to fill it. No one would believe you if you told them 7-8 hours of work that Customs neck refinish. And it was a love job, Customer was not charged for the work.
    kakerlak likes this.
  16. kakerlak
    1,813
    864
    Feb 5, 2014
    Man, 20 years ago, when I used to trawl all the pawn shops, you'd see so much crazy shit. Using a screwdriver as a chisel to modify your guitar is fine, right? Once saw a 20th anniversary Custom that somebody refinished in natural that still had lots of black stuck in the pores, plus the binding was so rounded over, it was down to the black ply in spots.
