1971 Les Paul Deluxe Conversion Repair - The "Dirty Grandpa"
Discussion in 'Norlin Years' started by TwistedMonk, Sep 7, 2017.
  1. restless
    restless Member
    98
    29
    Mar 13, 2010
    My 20th Anny. Custom has the same Caps ('74)
    69 Goldtop likes this.
  2. Progrocker111
    Progrocker111 Senior Member
    3,347
    2,373
    Oct 30, 2011
    Actually into 73, my early to mid 73 Deluxe still has this squared logo (21. week 73 pots). :)
    Kris Ford likes this.
  3. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    Ok, so here is an image of the route when I got it.
    The screw holes are blown out and the pickup was barely hanging on.
  4. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    Here it is after carving it out with my chisels.
    I curved the corners like the originals on the bottom and cleaned up the top.
    lakeburst and judson like this.
  5. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    Here is the wood. I bought it from Bell forest products over the internet they sell mostly to fountain pen makers $25.00 total
    It is flamed maple and African mahogany
  6. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    LoL
    Clamped it to the wood stove and cut it with the fret saw.
  7. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    I made a template of thick paper to get the shape then carved the pieces to fit.
  8. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    I had made mohagany pieces for the bottom but they weren’t needed so I ended up not useing them.
  9. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    Cut some cardboard to hold it together while the glue dries.
    This worked really well.
    I was going to cleat all corners originally but there was still enough wood on the bridge so I filled and drilled.
    After it was all dried I came back and carved the wood down flush with the top.
    This maple is hardwood so I drilled pilot holes for the pickup ring screws.
    lakeburst and fpatton like this.
  10. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    FA6D7E1A-3A7D-4B8A-A31D-F230358ED5BA.jpeg 9BF4FB70-07BA-46AA-BB91-068962ADD7B6.jpeg
    Ok so here’s a tool to pull the tail piece posts. I had to pull em to reset the pot ground wire that had broken off and the other one was in too deep so I set it flush with the top.
  11. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    So here it is done.
    Just to let you know,
    This replacement pickup rings are the gibson historic cost you extra deal they are selling and are smaller width wise and barely covered the original mini humbucker rout. I would not have gotten them if I had known and they almost didn’t work.
    It’s a buthair on to the body on the sides but it covers the hole with no spaces.
    Did these
    http://www.gibson-talk.com/forum/es-sential-hollowbodies/15130-gibson-factory-set-up-specs.html
    Setup specs then set action to taste and intonation an BaBamBa ready to play.
    lakeburst likes this.
  12. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    E563049A-CA71-4FD2-8ABC-C0857804605F.jpeg BA599BFE-8425-461A-9766-C7B393C3CE7E.jpeg
    I might top wrap the strings on the next change to see how that feels.
    See the missing screw, the cleat popped off cause I didn’t wait long enough and didn’t drill a pilot hole.
    It was the last one to go in and I wanted to play this thing so I will glue it back later LoL
  13. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    E79052C2-8A08-47C0-B191-E53797C4DFBE.png 3BE14CCB-F5E6-4C54-A53B-7CD7624AB96B.jpeg 3E1D2552-7DBF-481D-89F3-A45DB19F2697.jpeg 3BE14CCB-F5E6-4C54-A53B-7CD7624AB96B.jpeg
    It’s player clean which is fine by me I got tired of polishing it. It’s always this way with me I want it to work perfect and the looks are secondary.
    It had brown switch cover and no control cover. I was gonna get brown but they didn’t have a set that color and wanted more than double for just the control so black it is.
    As far as I can tell the neck’s got a grey wire T Top around 1972-73 cause no shield on the lead and it has a little bit of the pat sticker on the bottom under a piece of tape someone stuck on it . Like the one in the picture . I saw another grey wire T Top with an gibson embossed cover was a 73 I think.
    And I don’t know whats in the bridge the bottom is brass and has a small m or w stamped into the metal.
    Looks a bit like a mighty mite but the bobbins have holes.
    The screws are bigger I had to make the pickup ring holes bigger to mount it.
    And it sounds really good.
    lakeburst and PermissionToLand like this.
  14. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    Some links
    50’s wiring diagram
    http://archive.gibson.com/Files/schematics/lespaul2.gif
    Gibson set up specs I used then set action to taste,
    Gibson scale length years changes
    http://www.stewmac.com/How-To/Onlin...retting_and_Fretw/Scale_Length_Explained.html
    Wood supplier
    http://www.bellforestproducts.com/
    Guitar repair book free online sweet,
    https://books.google.com/books?id=zF24JMkjSpQC&pg=PA93&lpg=PA93&dq=abr+thread+into+wood&source=bl&ots=DxwA8uy0P_&sig=8gf1lBNeoBzW7iodSKX4__w_JFo&hl=en&sa=X&ved=0ahUKEwjox-LS8aDWAhWmjVQKHb6rDyoQ6AEIczAV#v=onepage&q=abr thread into wood&f=false
    Here’s a link so you can hear the sound,
    Recorded with iPad mic and camera
    Playing through 1965 Vibrolux Blackface with 1 greenback and 1 alnico gold 10” celestions installed and a ts-9 tubescreamer.
  15. mojave12
    mojave12 Junior Member
    10
    5
    Jan 16, 2018
    Nice job ! Interesting thread , thanks
  16. judson
    judson Senior Member
    2,829
    2,823
    Jan 26, 2016
    your hands would be the best to condition it , my opinion...:thumb:
    i really like this thread and learned a few things, great job on that and a great reference for future readers that run across similar issues
    very nice, that is a player no doubt
    thanks for the thread :h5:
    slug_maine likes this.
  17. slug_maine
    slug_maine Senior Member
    1,119
    2,370
    Dec 11, 2012
    Beautiful old guitar, Can't help it, I'm a sucker for worn guitars, I love patina. Very interesting thread, great pics, and I love the tone, that bridge pickup sounds good whatever it is.
  18. marsten
    marsten Senior Member
    209
    280
    Sep 22, 2009
    Very cool thread. Love seeing these old Norlins.
    Thanks for sharing.:thumbs:
  19. 1969 weatherman
    1969 weatherman Senior Member
    136
    53
    Oct 15, 2015
    you can squeeze lots of tone out of these old deluxes
  20. TwistedMonk
    TwistedMonk Member
    53
    95
    Sep 7, 2017
    yeah I really like that neck pickup.
    I think it is a pat# sticker. It sounds like a few I have heard on reverb.
    The mystery bridge all slug no screws pickup ( like a mighty mite) sounds really good too. I can roll off the vol and tone a bit and it sounds sweet.
    max it and get that bite.
    It isn't icepickey like that 498t crap garbage Gibson likes to put in everything. The 490r isn't too bad but the 498t in my 96 standard ya gotta keep messin with it to get a ok sound.
    My friend has a 2000 custom and same complaint same pickups.
    The deluxe pickups on the other hand ya gotta keep messin with em to find a sound you don't like.
