1971 les paul deluxe conversion repair the "Dirty Grandpa"
Discussion in 'Norlin Years' started by TwistedMonk, Sep 7, 2017.
  1. ARandall
    ARandall Senior Member
    11,539
    6,804
    Apr 16, 2012
    Nice project.
    But hot hide glue has a working time of 30 seconds or thereabouts. The liquid hideglue does have an open time of what you say......not anywhere as strong of course.
  2. TwistedMonk
    TwistedMonk Member
    35
    41
    Sep 7, 2017
    Kris,
    Yes the serial is in the 185xxx series.
    Guitar dater placed it from 1970-1972 by serial#.
    The les paul signature model is silkscrened and the gibson inlay has closed b and o with the dot on the I.
    Being a cherry burst puts it after 1970.
    Having silkscreen before mid 1972 I believe.
    Almost every part has been changed on this thing except the switch and the knobs I think they are original.
    it's really hard to date these old guitars.
  3. TwistedMonk
    TwistedMonk Member
    35
    41
    Sep 7, 2017
    LPC,
    I played it for about a month before starting the repair work. It has a really fast thin neck which I prefer.
    This guitar has a really woody sound, almost honks at you with a lot of sustain. Similar to zztop just got paid today sound.
  4. TwistedMonk
    TwistedMonk Member
    35
    41
    Sep 7, 2017
    ARandall,
    Yeah you are right.
    I changed it to under a min.
    As long as the glue hasn't gelled it will work.
    Always test fit and do a dry run before any glue is applied.
    hazmat7719 likes this.
  5. grumphh
    grumphh Senior Member
    757
    422
    Oct 10, 2015
    Good job :yesway:
    This looks like it could be the twin to mine which is (by consensus on this forum) most probably a '71 or early '72 - except mine has a fairly fat neck, and didn't come quite as dirty as this one.
    I especially note the routing for the wiring channel in the control cavity, where the channel sits closer to the lower pot than they did later on.
    ...what would be really nice would be a closeup of the headstock, because apparently there are several distinctive logo shapes in the early 70's era that make identification a bit easier.
    Kris Ford likes this.
  6. 69 Goldtop
    69 Goldtop Senior Member
    2,656
    1,928
    Mar 24, 2011
    Serial # and wiring channel location = 1973 -74
  7. grumphh
    757
    422
    Oct 10, 2015
    But the wiring channel sits low?
    I always assumed that it started off low in the cavity and then moved upwards as the years went by - until the drilled channel appeared...
  8. chasenblues
    chasenblues Senior Member
    19,938
    28,236
    Apr 2, 2007
    Has been discredited by many sources.
  9. HardCore Troubadour
    HardCore Troubadour Senior Member
    8,113
    5,832
    Nov 17, 2012
    grump it starts to move in mid to late 74, if I recall correctly.
    grumphh and Kris Ford like this.
  10. Kris Ford
    Kris Ford Senior Member
    4,754
    4,028
    Dec 17, 2011
    So far in the sea of Norlin confusion..the 1XXXXX range has been consistent to '73-'74.
    The ERO II caps and pot code nail it for me as well.
    69 Goldtop likes this.
  11. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
    wiring channel in middle location. In the move upward post 1974. No doubt a 73-74.
  12. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
    Yes, in 1968 they/it were down low next to the bridge VOL.pot. In 1973 mid/late they/it started the move up.
  13. TwistedMonk
    TwistedMonk Member
    35
    41
    Sep 7, 2017
    IMG_0297.JPG Ok, lol so here's the headstock photo.
    It's got grovers on it.
  14. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
    So yeah, thats a 73-
  15. Kris Ford
    4,754
    4,028
    Dec 17, 2011
    This is '71 logo:
    The key is the squareness..this went into '72, then became the logo that yours has.
    Really..doesn't matter..still Kzoo made! Still amazing LP..but is a '73..(MAYBE '74..pot code is very late in year)
    judson and 69 Goldtop like this.
  16. Kris Ford
    4,754
    4,028
    Dec 17, 2011
    Also, Les Paul script is higher on '71.
    judson likes this.
  17. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
  18. Kris Ford
    4,754
    4,028
    Dec 17, 2011
    ...and then there's those '76s that used the '71 style logos!:D
  19. Dilver
    Dilver Senior Member
    697
    818
    Apr 26, 2011
    Interesting... Really interesting thread. I have an all original (except for the output jack plastic and frets) '72 Les Paul Deluxe. I know it's a '72 as this was the only they had the "Gibson" embossed pickup covers. Obviously, the OP wouldn't have those as his pickups have been replaced, but I'll see if I can find any other identifying marks when I get home from work.
    To the OP - If you're still having difficulty cleaning gunk off the finish, try P21S Paintworks Cleanser. It's an automotive product that works really well on nitro finishes that need a lot of help, is silicone-free and won't eat through the finish. http://www.p21s.com/products/bis_pc.html
  20. HardCore Troubadour
    8,113
    5,832
    Nov 17, 2012
    there are a few 71's with embossed pup covers......
    judson likes this.
