1956 Les Paul Special - middle position out of phase
Discussion in 'Vintage Les Pauls' started by windsen, Jun 12, 2017.
  1. windsen
    windsen Member
    46
    62
    Aug 31, 2010
    I recently acquired a single owner/all original '56 LPS. Bridge and neck pickup tones are just superb. In the middle position, the pickups are obviously out of phase, which I know is not uncommon. While the tonal options are cool with varying volume/tone knob settings, I think I'd get more use out of the in phase tones from both pickups - and I do intend to play this thing. I understand that the phase issue can be corrected without touching solder joints - just flip the magnets along the access of the guitar body in one pickups, correct? Seems like minimal alteration to the originality of the guitar. Thoughts, fellas? Thanks in advance!
    Oh and yes, pics will come =)
    jcsk8 likes this.
  2. 69 Goldtop
    69 Goldtop Senior Member
    2,656
    1,928
    Mar 24, 2011
    Yep, flip magnets on one. You could always make a note of
    it inside case. So it would be originally known to have been
    out of phase.
    Kris Ford likes this.
  3. Kris Ford
    Kris Ford Senior Member
    4,754
    4,028
    Dec 17, 2011
    Not a fan either..there's a notable sound difference when switching, and I like a smooth switch myself.
  4. Tarcisioo
    Tarcisioo Member
    99
    73
    Oct 19, 2013
    Doesn't p90s have 2 magnets? Wich one to flip, or should he flip both?
  5. windsen
    windsen Member
    46
    62
    Aug 31, 2010
    Flipped both magnets on the neck pickup and it sounds perfectly in phase now! Good stuff!
    Only thing is the holes for neck pickup mounting screws in the neck pocket are stripped - I'll need to fill them in and remedy that. Wish these screws were longer!
    jcsk8 likes this.
  6. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
    remedy.. toothpick broken off in wood. Tighten screw.
    jwinger, IGRocker and LeftyF2003 like this.
  7. windsen
    windsen Member
    46
    62
    Aug 31, 2010
    It's tricky because the screw holes for the neck pickup are way down in the cavity and the screws barely go into the wood to begin with.
  8. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
    break it off at the top of the hole.
    LeftyF2003 likes this.
  9. windsen
    windsen Member
    46
    62
    Aug 31, 2010
    Toothpick + titebond worked perfectly! Thanks, man!
  10. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
    Awesome!!
  11. LeftyF2003
    LeftyF2003 Premium Member
    7,253
    8,173
    Mar 2, 2010
    I keep some toothpicks in my cable bag in case of stripped strap buttons, etc. That and a screwdriver can solve a multitude of problems!
  12. 69 Goldtop
    2,656
    1,928
    Mar 24, 2011
    another if someone wants to use Maple, is used small detail brush handles. They are tapered too
  13. ColdCobra
    ColdCobra Senior Member
    647
    287
    Jul 17, 2012
    I've used the toothpick trick more times than I can count. My wife makes fun of me for it.
    *Me getting a toothpick from the kitchen after dinner*
    Wife: Going to fix a guitar?
    jwinger, Curlymaple and RevWillie like this.
  14. jwinger
    jwinger Senior Member
    2,228
    844
    Apr 7, 2008
    My old p90s are out of phase...personally, I love it but it varies from pickup set to pickups set.
