1955/59 Conversion
Discussion in 'Vintage Les Pauls' started by Jumping@shadows, Feb 24, 2018.
  1. Jumping@shadows
    Jumping@shadows V.I.P. Member
    1,292
    2,110
    Sep 15, 2012
    Tbh veneering without a dedicated vacuum press, or bespoke caul/book press is very tricky and high skill as you have to exactly trim the centre line to compensate for the compound curves of the top allowing a flush join, and the unattached veneer will sit ‘cupped’ and preformed on the bench top, so a simple refin would be FAR less labour intensive..
    The reason to veneer was made between myself and the owner, as he already has a ‘50s GT, and this one with its three piece mismatched plain top, end grain wraptail plugs and crack between the knobs/seam separation had very little to offer visually, and he wanted a classic Burst.
    I’ll be shooting my usual vintage correct faded/aged finish so while the figure is exceptionally strong for a ‘50s original, it’ll have a totally authentic vibe and present very well imo :)
  2. moreles
    moreles Senior Member
    2,874
    1,515
    Apr 16, 2011
    Thanks for the answer. Just curious. Sounds like a fantastic build -- and a process I am sure I could never execute, personally. It's amazing how a great finish comes through even in digital pix on a laptop. I love your finish work, as virtually everyone else posting here does, too!
    Jumping@shadows likes this.
  3. bonchie
    bonchie Senior Member
    573
    185
    May 8, 2010
    Probably a dumb question, but is it possible to replace the maple top? Or is it impossible to separate from the original mahogany body?
  4. Jumping@shadows
    1,292
    2,110
    Sep 15, 2012
    You can of course remove the neck and body binding then run the body through a thickness sander to remove the top, but I want to retain as much vintage wood as I can.
    CRobbins and deadlyweasel like this.
  5. nuance97
    nuance97 Premium Member
    2,178
    1,237
    Feb 26, 2009
    How thick is the veneer?
  6. Jumping@shadows
    1,292
    2,110
    Sep 15, 2012
    It’s about 0.8mm after sanding
    nuance97 likes this.
  7. Greco
    Greco Senior Member
    5,654
    8,399
    Aug 30, 2007
    Amazing work!
  8. mapleflame
    mapleflame Senior Member
    2,650
    1,295
    Mar 18, 2007
    You need to really up your game in these conversions. Just kidding, as always phenomenal job. You are getting better by the Day.
  9. Pesh
    Pesh Senior Member
    332
    165
    May 4, 2015
    That's a fantastic finish result on the '55! Great job.
  10. badly drawn les
    badly drawn les Senior Member
    729
    1,352
    Sep 27, 2010
    Great work Yuuki.
  11. captdan61
    captdan61 Member
    63
    44
    Nov 13, 2011
    Very nice! Great job.
