1952 Goldtop LP... My New '59 Burst Project
Discussion in 'Vintage Les Pauls' started by boogieongtr, Jan 2, 2010.
  1. diceman
    diceman V.I.P. Member
    29,932
    5,214
    Jul 5, 2007
    :applause:
    That really did fade out, huh? Looks great!
  2. Cyanide
    Cyanide Senior Member
    163
    2
    Apr 30, 2009
    that top is so nice and killer finish too!
  3. LeftyF2003
    LeftyF2003 Senior Member
    7,355
    8,499
    Mar 2, 2010
    That looks amazing. Was worth doing the top twice!
  4. jworle01
    jworle01 Senior Member
    836
    10
    May 13, 2009
    I just love that flame pattern. I think the blank I bought from the same stash may have similar potential... Of course it will not be strapped to a 50's les paul :(
    What a great thread and project. I can't wait to see her strung up ;)
  5. jimi55lp
    jimi55lp Senior Member
    1,964
    286
    Mar 24, 2007
    Nice flame!
  6. boogieongtr
    boogieongtr Senior Member
    1,147
    1,233
    Aug 15, 2008
    Getting close to the end now. I have been letting the lacquer cure out and today I tackled the headstock. I sprayed the headstock with black aniline dye mixed into lacquer. After a couple coats there is a nice build up of black. I then applied 3 more coats of clear lacquer. I'll let the lacquer cure out for a coule of days and then do the LP silk screen.
  7. mapleflame
    mapleflame Senior Member
    2,650
    1,294
    Mar 18, 2007
    Niccccce!!! Hows the fading going.
  8. RobP
    RobP Senior Member
    2,026
    205
    Sep 25, 2010
    Great work! Lookin' good...:cool:
  9. ryancrossguitars
    ryancrossguitars Senior Member
    337
    12
    Sep 11, 2009
    I sold my 52 miss it today , there is a mod out there a bridge that does justice,andy brauer pulled it off a esay conversion does not effect the guitar but will get strings on top instead of the under
  10. boogieongtr
    1,147
    1,233
    Aug 15, 2008
    Thanks, today I had some time so I buffed out the entire guitar.
  11. ordenes10
    ordenes10 Senior Member
    171
    5
    Jan 17, 2010
    Wow.What for a great guitar.Great Job.
  12. boogieongtr
    1,147
    1,233
    Aug 15, 2008
    Thanks, today I'll do the silk screen. Thanks to forum member Voices for a great job on the sild screen!!
    The silk screen has the Gibson logo and the tuner holes etched into the screen. I use a flashlight to line up the tuner holes on the template.
    One swipe with gold oil paint and the results are a vintage looking silk screen.
  13. lpcustom69
    lpcustom69 Senior Member
    2,024
    553
    Aug 9, 2009
    Very cool.
  14. jonnycool
    jonnycool Senior Member
    133
    30
    Jan 25, 2010
    Now that you've told us how all this is done are you going to kill us?!?!:eek
  15. boogieongtr
    1,147
    1,233
    Aug 15, 2008
    I need to cut down the existing P90 pickguard for humbuckers. First I made a template. Then I screwed the pickguard to the template and used a trim router to reshape the guard.
    Here is the guard mounted to the guitar. I also installed the pickup rings. Next I'll do the final assembly and neck adjustment.
  16. ordenes10
    171
    5
    Jan 17, 2010
    hi.how are you cleaning the screen from color (oil) without distroy the screen?
  17. ordenes10
    171
    5
    Jan 17, 2010
    Another question about the color. is the red only red anyline or did you mix blue or anything? the red looks great.
  18. pinefd
    pinefd V.I.P. Member Premium Member V.I.P. Member
    9,200
    13,607
    Mar 23, 2007
    Good question. Also, I recall from when my mom used to paint with oils, they used to take forever to dry. Is that the case with the paint you're using too, or did you add something to it to help it dry faster?
    The guitar is looking fantastic, BTW, Jim! I'm loving this thread!
    Frank
  19. planks
    planks Senior Member
    15,039
    6,233
    Feb 16, 2010
    Fantastic great thread!
  20. boogieongtr
    1,147
    1,233
    Aug 15, 2008
    Thanks, it's almost complete. I also have 2 more in the works. I clean the screen out with Naptha then blow it dry with an air hose. It doesn't harm the screen in any way. The gold oil paint I use is from Wal Mart. You get a 12 pack for $7. bucks. The oil takes about 5 days to dry without any accelerant. I'm experimenting with a few different products to try to get the dry time down to 48 hrs. or less. I'll let you know what I think works the best.
