1952 Broken Headstock Repair
Discussion in 'Vintage Les Pauls' started by boogieongtr, Jan 26, 2014.
  1. boogieongtr
    boogieongtr Senior Member
    1,145
    1,242
    Aug 15, 2008
    I haven't posted on this forum for a while so here is one to enjoy.
    I bought this 52 guitar several years ago and in fact I was using the neck as a template to carve my necks.
    After stripping the finish you can see that someone used screws, nails and glue but the wood at the break is beyond repair.
    Before starting the repair I came up with a process that would allow me to use my existing templates and machining. The key for this was a 2-1/4" piece of wood. I'll call it the "blank" and it has to be perfectly square and straight.
    First thing is to remove the existing truss rod. I found center line of the blank and centered a 3/16" dado going thru the blank leaving both ends of the blank solid wood. Then I took neck and fastened it to the blank with two sided tape. I know the depth of a 52 truss rod dado so I removed most of the maple spline with my table saw and dado.
    I made certain that I stopped before the truss rod anchor.
    With a razor blade I removed the maple by the anchor.
    With all of the maple spline removed the truss rod came right out.
  2. b_rogers
    b_rogers Senior Member
    459
    250
    Sep 1, 2013
    Love these threads. Totally subbed.
  3. RAG7890
    RAG7890 Premium Member
    14,749
    23,488
    Jul 11, 2010
    + 1. :thumb: :applause:
    :cheers:
  4. Shadowplayer
    Shadowplayer Senior Member
    8,657
    5,538
    Nov 1, 2012
    Neck looked ugly
    wheres the rest of the guitar?
  5. Mr Insane
    Mr Insane Senior Member
    10,786
    5,788
    Dec 8, 2008
    love these threads!
  6. boogieongtr
    1,145
    1,242
    Aug 15, 2008
    I'm going to make a new headstock and use a scarf joint which has the most surface area for gluing. First I lay out where I want to cut the scarf joint making sure I'm past the rotted wood.
    Knowing that after I make the cut the blank would collapse I glued a 3/16'" maple spline into the slot making it stick past the surface 1/8" (this will center the old neck to center line of my blank) then make the cut using my headstock angle jig.
    Scarf cut make and my blank is in tact for future jigs.
    I'll use another 52 neck to see how thick my headstock blank needs to be and also lay out for rough cut to the headstock blank once it's glued to the neck.
    I'll do a dry clamp to see how things line up. The neck is still attached to the blank.
    Next I'll glue the neck to the headstock blank and let it set overnight.
    10 people like this.
  7. jimi55lp
    jimi55lp Senior Member
    1,968
    288
    Mar 24, 2007
    Your work is so impressive and it always inspires me!
  8. Jean Christophe
    Jean Christophe Senior Member
    504
    1,860
    Nov 12, 2010
    Great job as usual Jim !!!
    Keep up the good work.
    Jean Christophe
  9. Sct13
    Sct13 Premium Member
    17,459
    20,813
    Sep 18, 2011
    I love this stuff. :hmm:
  10. cherrick
    cherrick Senior Member
    1,730
    557
    Jan 5, 2008
    To those not in the know, this guy is just a total monster luthier. Total.
    All in.
    2 people like this.
  11. Stoj
    Stoj Senior Member
    3,350
    2,026
    May 23, 2007
    Totally subscribed I can't wait to see the final result :cheers:
  12. Barks McKay
    Barks McKay Senior Member
    193
    209
    Sep 20, 2011
    Brilliant - who thought you could enjoy learning again in your later years!
  13. ColdCobra
    ColdCobra Senior Member
    652
    291
    Jul 17, 2012
    Subbed as well.
    I know enough about woodworking to know what you're doing with jigs etc., but I'm many years from being able to do any of it with any appreciable skill. Very impressive work.
  14. Frails
    Frails Senior Member
    2,782
    504
    Nov 20, 2008
    Haven't been on here in a while. This is a great thread to come back to.
    1 person likes this.
  15. boogieongtr
    1,145
    1,242
    Aug 15, 2008
    Thanks everyone :thumb: Next I'll make a parallel cut and trim the excess wood on the top side using a spacer and my table saw. I'll leave the wood about 1/32" strong.
    Touch it up on my sander
    Next I'll take the fretboard and mark the length and where the angle cut needs to be for the top side of the headstock.
    Once again I'll attach the neck to the blank so I can continue to use my jigs.
    With the correct length of the neck marked I cut the angle to the top side of the headstock. This cut is now parallel to the scarf joint since both cuts were made from the same jig.
    I'll make the truss rod pocket using another jig.
    Slot for the truss rod.
    Ready for the truss rod.
    The old rod fits perfect.
    14 people like this.
  16. 1981 LPC
    1981 LPC Senior Member
    2,189
    1,541
    Dec 8, 2010
    Impressive. Always fun to watch a craftsman work.
    I take it the '52 came without a serial number? Are you reusing the Gibson logo inlays (if that's what they are)?
  17. boogieongtr
    1,145
    1,242
    Aug 15, 2008
    Long gone, renecked and making music
    Patience :)
  18. boogieongtr
    1,145
    1,242
    Aug 15, 2008
    Next up I'll work on the backside of the neck. First I mark the thickness of the headstock.
    Using my band saw I make a rough cut removing most of the material.
    I use another jig and my overhead router to get the back profile. By now everyone can see how important the "blank" was to the machining process.
    Glue on the headstock wings.
    Glue in the new maple spline.
    Trim the excess maple flush to the neck plane.
    I'll make one pass thru my jointer taking off about 1/64". This insures a flat plane when I go to glue the fretboard back onto the neck
    8 people like this.
  19. boogieongtr
    1,145
    1,242
    Aug 15, 2008
    Next I'll glue on a new veneer to the headstock using a block and clamps to get even pressure. I use a white luthiers glue from LIM. It dries hard and brittle like hide glue.
    I trim off the excess wood on my bandsaw and screw a template to the headstock. The screws are positioned so they fall inside the Gibson MOP logo and the truss rod cavity and will never bee seen.
    With a router and a pattern bit I do the final trim cut.
    With the same pattern I drill for the tuners.
    The neck is going to get Grovers so I bore out the back the depth of the housing leaving enough wood so in case I want to use Klusons the ferrules will fit.
    Grover tuner fits nice and snug.
    13 people like this.
  20. fretnot
    fretnot Senior Member
    1,902
    1,091
    Apr 20, 2008
    Looking great!
