Go Back   Les Paul Forums > The Les Paul > Vintage Les Pauls > Vintage SG
Like Tree5Likes
  • 4 Post By 61sg
  • 1 Post By 61sg
Unread 02-03-2011, 11:12 AM   #1 (permalink)
My S.G.
I posted this on a different page, but it is at home here I think.
This is my SG, handed down to me from my father, it is the best guitar i've ever played, it's my Pearly Gates! Ive tried loads of other sg's, none ever come close.
geochem1st, Nils, Alvinfan and 1 others like this.
61sg is offline   Reply With Quote
Unread 02-03-2011, 11:41 AM   #2 (permalink)
Re: My S.G.
That's the first time I've seen a B7 on an SG. Very cool.
How much of that guitar is original?
61SGLP is offline   Reply With Quote
Unread 02-03-2011, 11:56 AM   #3 (permalink)
Kevin James's Avatar
Re: My S.G.
My 60/61 (issues/player... see NVGD thread a few threads down in this section) has the side pull trem but at one time it had a B7 on it as well. It has scars on the top where the two mounting screws would be from a Bigsby and it has four filled holes at the bottom where the strap button is that could only be from a B7 Bigsby.
I have no idea which trem was original to my guitar though. My thought was that the side pull was removed and a B7 installed probably soon after the guitar was purchased new out of necessity because the sidepull is a huge pile of crap functionally speaking. And then the sidepull was probably put back on later after the guitar became valuable (but before it suffered its issues). But who knows.... maybe the Bigsby was original???
Kevin James is offline   Reply With Quote
Unread 02-03-2011, 12:00 PM   #4 (permalink)
Re: My S.G.
Cripes....here we go....
The neck is maple, it got smashed 3 times during it's years on the road, the third time was almost game over. The chAnge of wood and the weight of the bigsby actually balanced the guitar out.
One tone and one volume knob was replaced.
the tree of life logo has gone from the headstock.
old tuners were replaced with grovers in about 74 I think.
This is one of the few SG's I have seen with a B7, Andrew Stockdale (Wolfmother) plays another
This guitar was bought in 71, the bigsby was already on it. Chances are, it originally has a sideways Vibrola.
Unread 02-03-2011, 01:35 PM   #5 (permalink)
Dolebludger's Avatar
Re: My S.G.
61:
I'm almost 100% sure your 61 came from the factory with a side pull trem. Do you happen to still have it? As you say, the side pulls were and are musically crap (and I believe that having the rear of the strings attached to a spring loaded attachment is a tone sucker, too.) And the lower pot metal arms have had a bad habit of breaking.
And a couple of questions. As to the "tree of life" logo on the headstock being gone, are there indentations where it used to be? And you say the neck is MAPLE (not mahogany)? This is the first early SG I have ever heard of with a maple neck, if the neck is original.
'62 Gibson LP SG Standard
'09 Epi Goldtop LP P 90
Two Carvins
Custom Strat
Electra Strat type
Hondo Longhorn
Durango Guitar Works "Contender" (ask me about this one!)
Sterling SUB AX3 (ask me about this one too)
PRS SE "Orianthi"
Genz Benz El Diablo 60 TS.
Bugera V22
Dolebludger is offline   Reply With Quote
Unread 02-03-2011, 07:14 PM   #6 (permalink)
kharrison's Avatar
Re: My S.G.
Originally Posted by Dolebludger View Post
61:
Sounds like it has a maple reneck. Looks like a real cool guitar and quite possibly a dealer installed B7 at the time.
kharrison is offline   Reply With Quote
Unread 02-04-2011, 04:12 AM   #7 (permalink)
Re: My S.G.
The guitar must of had a sideways vibrola, no I do not have it. The tree of life logo was lost when the guitar was smashed for the 3rd time in 75, a new headstock face was put on and the tree of life logo was not included in the repair.
The maple neck was a replacement, after it was smashed the 3rd time as well.
This guitar has done a lot of gigs......
Here is one of them
and here is the guitar on the O G W T
Nils likes this.
Unread 02-04-2011, 10:26 AM   #8 (permalink)
Re: My S.G.
Is that you or your father? Pretty great playing!
Unread 02-04-2011, 05:33 PM   #9 (permalink)
Re: My S.G.
No, that was my father. He is in the great Jam in the sky now.
Unread 02-05-2011, 03:52 PM   #10 (permalink)
Re: My S.G.
Your Dad was a great player. Even through my cheap computer speakers, I can hear the greater tone definition the maple neck gives. I've always felt that the 61 (and early 62) SGs have a problem as the bodies are thin, as are the necks, and made of mahogany which is not a particular dense and heavy tone wood. (And not very strong either, as your Dad and many others discovered the hard way.) I strongly suspect that the maple replacement neck, while hurting collectors' value, actually increases this guitar's musical value.
Someday, I will have a luthier friend of mine build me a true custom guitar. We've talked about it, and it will be shaped much like a 61 SG -- except the fretboard will be narrower as I have small hands. But it will have a maple neck (maybe a neck-through) with a thicker body made of denser wood than mahogany. Cost quote is $1800, so it will be a while. But hearing the tone your Dad got out of an SG with a maple neck reinforces my theories that a "denser" SG would be worth going for.
Two Carvins
Custom Strat
Electra Strat type
Hondo Longhorn
PRS SE "Orianthi"
Bugera V22
Unread 02-05-2011, 05:09 PM   #11 (permalink)
Re: My S.G.
Sounds like what you need is a mid/late 65 SG. I just picked one up. It has the look of a early 60's small guard/short neck joint SG, Both the body and the neck are just a little bit thicker and it has an improved longer neck tenon. It also has the narrow 1 9/16" nut. Sounds like a perfect match for you, although your quote of $1,800 is certainly less expensive.
Unread 02-05-2011, 06:06 PM   #12 (permalink)
Fletch's Avatar
Re: My S.G.
Wow, nice story and your dad was a REALLY outstanding player. I liked both videos.
fletch
Fletch is offline   Reply With Quote
Unread 02-06-2011, 04:27 AM   #13 (permalink)
SingeMonkey's Avatar
Location: Cape Town, South Africa (Yes. It's a real country)
Re: My S.G.
Wow. He played some awesome slide guitar. Great voice. And a seriously hip looking dude too.
And that SG sounds the bollocks.
SingeMonkey is offline   Reply With Quote
Unread 03-02-2011, 10:35 AM   #14 (permalink)
BadBeat78's Avatar
Re: My S.G.
Man thats awesome.
And what a great story behind that guitar.
Everytime you play it you can remember your father!
BadBeat78 is offline   Reply With Quote
Unread 06-18-2011, 02:07 PM   #15 (permalink)
Lebo's Avatar
Re: My S.G.
Awesome, great history and great player
Lebo is online now   Reply With Quote
