#2 (permalink) |
Re: P90 Soapbar to dogear conversion
And the point of this exercise would be...?
Purely cosmetic?
http://blueplatespecials.net/ |
#3 (permalink) |
Its easy, just change the baseplate.
Marc '59 Les Paul Junior '60 Melody Maker '62 SG Special '64 LG-1 '88 RI Les Paul '94 Les Paul Standard '07 CR8 and a ton of other non Gibson. |
#4 (permalink) |
![]() Join Date: Nov 2008
Yep, it you have a soapbar P90 that needs to go in a guitar that requires dogears, simply transfer the inner workings on a dogear base plate, get a dogear cover and you are set! (oh, and mounting screws for a dogear too)
#5 (permalink) | |
Bartlett Retrospec Member
![]() Join Date: Nov 2010
Will any baseplate fit or have the specs changed over time? The soapbar is from the late '50's to early '60's |
#6 (permalink) |
Why not just put a dogear cover on and then you're done. It's been learned that some 50s LP juniors, for instance, have regular P-90 pickup (including baseplate) lurking under a dogear cover.
Makes it a pretty simple process. |
#8 (permalink) | |
Duh. Now back to your regularly-scheduled program.
#9 (permalink) |
![]() Join Date: Mar 2007
A soap bar can be used for a solidbodied P90 rout but not for a Hollow bodied guitar. A dogear P90 has a different screw bar underneath the bobbin which will not have the screw holes drilled out for the two inner mounting screw holes. The base plate and screw bar are different. It can be drilled out, but the heat can melt the bobbin and hurt the winding. I have seen people take the wings off of Dog ear baseplate, but still have to replace the polescrew bar. Some dogear P90 bobbins have the two inner screw holes, but not on the bar and base plate. When searching for P90's on the web all these things have to be considered.
No thank you to Burst I'll Bronze instead. I just love the green left on my arm in the morning. It Looks Like Victory. |
#10 (permalink) |
Thanks for the info guys. I had no idea that you could put a soapbar in the rout with a dogear cover over the top. I thought it would have been too tall as soapbars usually have spacers that dog ears don't. I'm going to give it a try. That said, if anyone has an old dogear baseplate they don't mind parting with shoot me a PM.
#11 (permalink) | |
