#182 (permalink) | |
Re: Guitar Grounding Common Misconceptions?
A bunch of Strats, some Gibsons, a couple clonewheels, a few Fender amps, various stompboxes Posted from MyLesPaul.com App for Firebird X |
#183 (permalink) | |
TONE FREAK
![]() Join Date: Mar 2008
Yeah I think a lot of the "noiseless" single coils and Fender SCN's are really just stacked humbuckers. I have a variety of un-potted Humbuckers and vintage style single coil pu's in my guitars and they all are really very quiet. The one that gives me the most Buzz/Humm is the P-90 in my LP Jr. Clone. It' properly grounded, and sounds really good, but add a little gain on the amp and it just gives off the more noise than my other pu's. After all P-90's are just big single coils and this one is wound just over 8K.
"Pro Guitar Wiring Upgrades Built & Designed by a Guitar Player with over 33 years of Experience" ![]() Jonesyblues.com for Professional Guitar Wiring Upgrades & DIY Kits Questions? Email to: jonesyblues@yahoo.com or Call 1- 574-249-8816 Aged Parts, Vintage Tone Caps & Wire in my ebay store Jonesyblues Youtube channel Jimmy Page Wiring.com GOD ROCKS! |
#184 (permalink) | |
TONE FREAK
Yeah I think a lot of the "noiseless" single coils and Fender SCN's are really just stacked humbuckers. I have a variety of un-potted Humbuckers and vintage style single coil pu's in my guitars and they all are really very quiet. The one that gives me the most Buzz/Humm is the P-90 in my LP Jr. Clone. It' properly grounded, and sounds really good, but add a little gain on the amp and it just gives off more noise than any of my other pu's. After all P-90's are just big single coils and this one is wound just over 8K.
#185 (permalink) |
Here we go
![]() Original soldering joint from the factory in Japan 1987 ![]() Let me know if you need any other Strat picīs
Proud user of "JonesyBlues Customshop" parts ![]() T-Top info read this http://www.mylespaul.com/forums/pick...490r-490t.html Alot of good wiring help http://www.mylespaul.com/forums/tone...g-library.html Help on soldering http://www.mylespaul.com/forums/tone...ow-solder.html Capacitor info http://www.mylespaul.com/forums/tone...apacitors.html |
#186 (permalink) | ||
TONE FREAK
Thanks for the pics
#188 (permalink) | |
TONE FREAK
You might want to take some rough 100-150 grit sandpaper and clean that spot off on the trem where the wires goes if there is any oxidation on the metal that way the solder will stick better. I don't sand the back of the pots but on that trem claw it might help out.
#190 (permalink) | |
Tim Mason
![]() Join Date: Jan 2010
Quote: Roman Rist on "natural highs" whilst playing It's not just endorphins you feel... No, you are connecting with the spiritual world.............you're just not sure exactly what it is.... But you are in the spirit world, that's what Hendrix was trying to tell us. |
#191 (permalink) |
TONE FREAK
Yeah normally new pots have a coating on them that helps the solder stick so if you sand it off it doesn't really help you with soldering.
If you have an old pot that has a lot of oxidation on the back sanding it may help, but as a general rule I do not sand the back of pots.
#192 (permalink) |
Mac Guitars
![]() Join Date: Oct 2009
I've actually found the exact opposite Jonesy. I always use a 25W soldering iron, and when I got the new CTS 'True Vintage Taper' pots in, they were brand new and very shiny. However, the solder just wouldn't stick without me sanding the pots.
So, I always give pots a light sand, as in theory it gives the pot a greater surface area for the solder to stick to. Are you using a 40W iron for soldering to the back of pots?
Mac Guitars - Custom Wiring & Electronic Upgrades. Sign up to the mailing list for an update on new products as they become available. My eBay store: drumbrae4. 10% SaleMac GuitarsGuitar Electronics and Celluloid Nitrate Inlays. |
#193 (permalink) | |
#194 (permalink) | |
TONE FREAK
Luke I have used 25 watt iron with a chisel tip to solder to the back of the pots but a 40 watt iron works so much easier and really gives a good tight solder joint in a lot less time. Billy from RS has also repeatedly said that sanding the back of new pots is not necessary, and I don't think you see him doing that in any of his videos. If you get a chance try a 40 watt iron for the soldering to the backs of the pots and see how that works out for you. I also find that the 40 watt works great for soldering to that big ground lug on the toggle switches as well. You can still use your 25 watt for soldering to the pu lugs and other assembly work.
#195 (permalink) | |
Mac Guitars
And now you're going to tell me that microscopic bits of metal get into the pot and wreck the taper if you sand the back of the pots. Jog on.
#196 (permalink) | |
Mac Guitars
#197 (permalink) | |
![]() If you sand the back of your pots in your rigs and they work fine then thatīs just another way of doing it. Whatever works for you.
#198 (permalink) | |
Mac Guitars
It would look better if I didn't have to sand them, so I'll be looking into the 40W iron.
#199 (permalink) | |
TONE FREAK
A couple months back I bought a Weller soldering station that is adjustable from 5-40 watts but I have been saving it and it's still new in the box. You might want to look for something like that. You can turn it up to 40 watts when you are soldering to the back of the pots and dial it down to 25 watts for other work. And if you are working on a PCB you can go as low as needed so you wont burn anything up. Just thought I'd mention it. This is the one I have it was only $42.00 usd, they make some high dollar versions depends what you want to spend. Weller WLC100 40 Watts Soldering Station for Hobbyist and Do-It-Yourselfers | ToolBarn.com
#200 (permalink) |
TONE FREAK
The black wire soldered to the volume pot that you see coiled up would run through the body, into the trem cavity and then get soldered to the trem claw.
![]() Just wanted to be clear on how the grounding on a Strat works so I traced the ground path in green. You can see the black wire that comes into the trem cavity and is soldered to the trem claw. The other end of that wire is soldered onto the back of the volume pot and all the pots are grounded together by a wire. ![]() The springs carry the ground to the trem block, the bridge sits on top of the trem block and is screwed to it, then the strings feed through the back of the trem block and run over the bridge saddles. This is how your strings and bridge are grounded back to the wiring controls on a Strat.
#201 (permalink) | |
looking back on your notes i get it
#202 (permalink) | |
TONE FREAK
Like someone posted earlier...(Lampens?) I hear and I forget, I see and I understand, I do and I remember
#204 (permalink) | |
I don't know how I missed this thread. Very informative- thanks for posting!
-Matt. Quote:
#205 (permalink) |
Tim Mason
Heres a boggler, if you put too much solder on the back of pots can this create a resistor of some kind, read it over at ANZLF from the administrator, but i question everything, even my sexuality(kidding) Not that theres anything wrong with that
#207 (permalink) |
my grounding wire from the bridge to the pot on a Gibson Les Paul Classic has broken at the bridge end so i need to replace it. Do i need to pull the bushings out (totally or just a little) to get a new wire under and press the bushing in on the wire or does the stud screw in deeper than the bushing (the bushing having no bottom) and therefore being sufficient to unscrew the stud to make room for the wire and then screw it back in, pushing on the wire ?
thank you
http://www.soundclick.com/bands/defa...?bandID=978081 |
#208 (permalink) | |
TONE FREAK
![]() Afterwords you can check continuity with a multimeter to make sure you have a good ground path between the ground wire and the bridge.
#209 (permalink) |
Hey jonesy,
Is there a reason why the pots in a guitar aren't wired this way, with the lugs that go to ground connected with the bus wire, instead of being soldered to the pot casings and then the pot casings all connected with the bus? Doing it this way in an amp eliminates ground-loops and reduces background noise. I may try it in my guitar. Because I still haven't been able to get rid of that noise. I suspect a ground-loop is the cause. ![]() ![]() Normally, that bus wire is wired up this way (much like in a guitar), where the pot casings are connected and then the lug that needs to go to ground is soldered to the bus. Hello ground loop! ![]() ![]() Why not separate the ground connections? The lugs that should go to ground get connected by a bus wire, instead of having them soldered to the casing and then connecting the casings.
Diezel VH4 Cameron CCV Bogner 4x12 '79 Silverburst '84 Silverburst |
#210 (permalink) |
TONE FREAK
Amps deal with high voltages so grounds loops are in issue as far as generating noise. In guitars there is barely any measurable voltage (milli-volts) at all, so as previously discussed ground loops in guitars do not cause noise or humm like they do in amps.
Guitar wiring has not changed a whole lot in 50 years because grounding to the back of the pots is a simple reliable way to do things. Most all the amps controls and circuits are mounted inside a metal chassis along with the transformers so a universal star ground is commonly used. I highly doubt your noise issue in your LP is caused by a ground loop, it is more likely a bad ground or a partial short that is causing the problem.
| Tags |
| ground loop, grounding |
