MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Unread 06-01-2010, 05:58 PM   #1 (permalink)
GLOBAL WIRING GURU
jonesy's Avatar
Wink Video: How a DPDT Push Pull Pot Works
I had a request by one of our Australian MLPF members to make this video explaining how a DPDT push pull pot operates so here it is.
This diagram may also be helpful in explaining how these push pull pots are used to split coils on a Humbucker.
Jonesyblues.com Premium Guitar Electronics & Pickup Upgrades Made in USA
Questions? Email to: [email protected] Call or Text 574-540-9777
Aged Guitar Parts, Vintage Tone caps, Wire & other DIY mods Jonesyblues Custom shop ebay store
Jonesyblues Youtube Channel Pickup & Wiring Demos
21 Tone Jimmy Page Wiring Options
The Following 6 Users Say Thank You to jonesy For This Useful Post:
Advertisement
Unread 06-01-2010, 08:30 PM   #3 (permalink)
Mookakian's Avatar
Re: Video: How a DPDT Push Pull Pot Works
Awsome
Let every man be respected as an individual and no man idolized.
- Albert Einstein
Mookakian is offline   Reply With Quote
Unread 06-01-2010, 09:24 PM   #5 (permalink)
phlz_8's Avatar
Good info there jonesy. Nice job on putting up these videos.
phlz_8 is offline   Reply With Quote
Unread 06-01-2010, 09:52 PM   #7 (permalink)
captcoolaid's Avatar
Class act as always.
DC DOES NOT EQUAL OUTPUT. Dc is a resistance value and that is all. It WILL NOT tell you what it will sound like, it WILL NOT make you sound like another player.
captcoolaid is offline   Reply With Quote
Unread 06-02-2010, 12:33 AM   #8 (permalink)
Thanks so much for the video. I'm wondering, though--is anyone else having an issue with the audio and video not synching?
zap2012 is offline   Reply With Quote
Unread 06-02-2010, 06:51 AM   #9 (permalink)
Mookakian's Avatar
Yep ^
Sound seems a little faster, the mojo is playin 1/2 a beat to fast in this one jonsey, i see how the push pull works, but still a little confused about the wiring for them.
In reference to the SD SLUG coil splitting diagram, would i be right in saying:
the red and white wires are a positive current,
the black, green and braided wires are a negative current,
when you pull the pot up, you disconnect the earth(green/braided) for the adjustable coil(neck side),
leaving the earth for the slug coil (black wire) connected with the positive red/white wires and the SLUG coil working?
- Albert Einstein
Unread 06-02-2010, 09:12 AM   #10 (permalink)
GLOBAL WIRING GURU
jonesy's Avatar
Originally Posted by Mookakian View Post
Yep ^
Yes I think the video is slightly behind the audio, it was not thas way on the original recording but may be due to the video card on my computer. My sony cam is older and it takes the mini tapes so I have to use software to capture. This video editing is all a bit new to me and I am still going through the learning curve.
As far the individual pickup wires go yes they come from the 2 separate coils in the humbucker like you have stated. The red and white wires are what's called the "Series" link. That is where the two coils get joined together. On Seymour Duncans the black wire is hot + and the green wire is ground - normally the red and white get soldered together and then taped off, but they are also the ones you use if you want to split coils. (or change for parallel wiring within the humbucker)
This diagram may help you see things more clearly. As you see the color codes vary from brand to brand, and it can get confusing at times working with different makes of pickups as they are not all the same.
Unread 06-04-2010, 08:58 AM   #11 (permalink)
Indyclone's Avatar
Hey Jonesy, is the coil split in the above diagram for the slug coil? If so, how could this be switched over so that when you pull for the split the screw coil is active instead?
Indyclone is offline   Reply With Quote
Unread 06-04-2010, 10:26 AM   #12 (permalink)
GLOBAL WIRING GURU
jonesy's Avatar
Wink Re: Video: How a DPDT Push Pull Pot Works
Originally Posted by Indyclone View Post
Hey Jonesy, is the coild split in the above diagram for the slug coil? If so, how could this be switched over so that when you pull for the split the screw coil is active instead?
Yeah the slug coil (inner) is on and the screw side (outer) goes off on a Seymour Duncan HB when the red & white (series link) is shunted to ground. The earlier diagram I posted shoes how to wire it if you want to have the screw side coil (outer) on when you do the coil tap mod.
Unread 06-07-2010, 05:08 AM   #13 (permalink)
Mookakian's Avatar
Sweet thanks jonsey, went offline for a few days, sorry. I have these semi buggered pots ill be pulling and having a little fun with. Ill try not to msg you in frustration of my sparky skills Been testing phasing with 2 mics and room size/distance/angles, some interesting stuff! I just hope the same/similar rules apply with electronic phasing, prob less variation in frequency cancellation but yeah......
- Albert Einstein
