MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Unread 04-09-2010, 03:20 PM   #1 (permalink)
dakotajones's Avatar
Bumblebee Cap Opinions...
without checking these on a meter...which of the following would you prefer for a neck and bridge cap (all bee caps):
.01 10% 400 VDC
.01 20% 400 VDC
.012 10% 200 VDC
.022 10% 400 VDC
Dakota Jones
www.dakotajones.net
dakotajones is offline   Reply With Quote
Advertisement
Unread 04-09-2010, 03:33 PM   #2 (permalink)
MrRhoads's Avatar
Re: Bumblebee Cap Opinions...
,01uF for both positions, preferably 10% tolerance but 20% would do fine to
Proud user of "JonesyBlues Customshop" parts
T-Top info read this http://www.mylespaul.com/forums/pick...490r-490t.html
Alot of good wiring help http://www.mylespaul.com/forums/tone...g-library.html
Help on soldering http://www.mylespaul.com/forums/tone...ow-solder.html
Capacitor info http://www.mylespaul.com/forums/tone...apacitors.html
MrRhoads is offline   Reply With Quote
Unread 04-09-2010, 07:23 PM   #3 (permalink)
dwagar's Avatar
"without checking these on a meter" is a bit of a problem. You don't know if they are within tolerance, or even if they are, which way the +/- % is (ie, a .[email protected]% could be .012, good, or .008, not so good). They could have drifted too. Test them all in the guitar, trust your ears.
I'd prob run with one of the .01s in the neck, maybe the .012, and either the .012 or the .022 in the bridge. But I don't generally like an .022.
Don
Primary Tone: what the body and neck does not have cannot come out as tone - Iwanade, BOTB
Originally Posted by reswot
A 50's Special is, IMO, the coolest guitar ever made.
dwagar is offline   Reply With Quote
Unread 04-09-2010, 07:24 PM   #4 (permalink)
Micky's Avatar
.01 or .015 in the neck
.022 in the bridge
- lower tolerance is better
Micky is offline   Reply With Quote
Unread 04-09-2010, 10:19 PM   #5 (permalink)
bryvincent's Avatar
i use .022 on both positions but with 650K vol & tone pots on the neck position.
bryvincent is offline   Reply With Quote
Unread 04-10-2010, 10:29 AM   #6 (permalink)
5F6-A's Avatar
each value has its merits.... generally I like low values
I use 0.010 neck and 0.022 bridge in my LP with fairly bright bickups.
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
5F6-A is offline   Reply With Quote
Unread 04-10-2010, 12:43 PM   #7 (permalink)
Mac Guitars
lukemacauley's Avatar
A 0.01uF in the bridge probably won't be enough.
Take a 0.022uF for the bridge and 0.01uF for the neck. The tighter the tolerances, the better.
Mac Guitars - Custom Wiring & Electronic Upgrades.
Sign up to the mailing list for an update on new products as they become available.
My eBay store: drumbrae4.
10% Sale—Mac Guitars—Guitar Electronics and Celluloid Nitrate Inlays.
lukemacauley is offline   Reply With Quote
Unread 04-10-2010, 01:02 PM   #8 (permalink)
MrRhoads's Avatar
0,01uF in the bridge works fine for me
"EDIT" It actually reads 0,0136uF by the way
Unread 04-10-2010, 01:03 PM   #9 (permalink)
Mac Guitars
I often roll my bridge off to 2/3 so it wouldn't for me. YMMV.
Unread 04-10-2010, 01:44 PM   #10 (permalink)
5F6-A's Avatar
my 0.022 uF actually reads 0.019 uF
I liked the 0.010 in the bridge but the 0.019 works slightly better... probably due to the pickup low output ( 7.9k ) and a bright, fully charged Alnico V magnet
Unread 04-10-2010, 02:21 PM   #11 (permalink)
MrRhoads's Avatar
7,7kOhm Alnico V here in the bridge with slightly missmatched coils and 0,0136uF Bee
Unread 04-10-2010, 04:26 PM   #13 (permalink)
MrRhoads's Avatar
Originally Posted by jonesy View Post
.01 neck .012 bridge, I prefer the lower values myself. Much better upper mid curve and killer woman Tone when rolled all the way off
Most of thoose who get to try me Les Paul get´s shocked about the bright bridge i have but i don´t find it to bright, instead the PIO caps (Bumblebee) let´s me go real bright but without being harsh, but i´ve found that different amps and especially different speakers affect that to.
Like you say, upper mid curve killer woman tone and tons of clarity even when tone is on 0
It was you and Hilario who inspired me to venture into 0,01uF value
Unread 04-10-2010, 04:41 PM   #14 (permalink)
essguitarman's Avatar
If they all read around those values, then I would use .01 10% for both positions.
essguitarman is offline   Reply With Quote
Unread 04-10-2010, 04:54 PM   #15 (permalink)
johnbeloe's Avatar
i hear this too...have a .01 in my neck, and .022 in the bridge...the woman tone is considerably better on the neck pup
johnbeloe is offline   Reply With Quote
Unread 04-10-2010, 05:00 PM   #16 (permalink)
Mac Guitars
Woman tone is considerably better on the neck pickup because woman tone is when you're using the neck pickup with the tone rolled all the way off and volume on full.
Unread 04-10-2010, 06:31 PM   #17 (permalink)
GLOBAL WIRING GURU
jonesy's Avatar
Woman Tone can be achieved using the neck or bridge pu's and rolling off the Tone. It does not have to be just be the neck pickup.
My Esquire just has a bridge pu and I have the 3 way switch wired so the front setting is "fixed wah" and it has a Sweet sounding Woman Tone
Jonesyblues.com Premium Guitar Electronics & Pickup Upgrades Made in USA
Questions? Email to: [email protected] Call or Text 574-540-9777
Aged Guitar Parts, Vintage Tone caps, Wire & other DIY mods Jonesyblues Custom shop ebay store
Jonesyblues Youtube Channel Pickup & Wiring Demos
21 Tone Jimmy Page Wiring Options
Unread 04-10-2010, 06:32 PM   #18 (permalink)
Mac Guitars
Woman tone was created by using the neck pickup, that's why it's achieved better and easier when using it.
Unread 04-10-2010, 06:35 PM   #19 (permalink)
Benjammin's Avatar
Id say .012 neck, .022 bridge
I have a .0115 on my neck pickup, and its perfect imo. I also have a .018 on my bridge, it could stand to be darker, but it hasnt bother me enough to swap
Benjammin is offline   Reply With Quote
Unread 04-11-2010, 02:38 AM   #20 (permalink)
MrRhoads's Avatar
I once dialed in a Marshall 100w solid state amp MG series i think so that i had a very beefy tone with the neck pickup and i played the smoke on the water riff I you didn´t know it was the neck pickup i was using you would never have guessed it.
Bottom line, same tone can be achieved in different ways
EDIT the guitar was a Fender Stratocaster MIM rosewood fretboard
Unread 04-11-2010, 02:47 AM   #21 (permalink)
Benjammin's Avatar
Clapton says it can be either pickup
Unread 04-11-2010, 04:33 AM   #23 (permalink)
MrRhoads's Avatar
Originally Posted by benjammin420 View Post
Great post
