#1 (permalink) |
Wah pedal problem
so ive been playing around with my Crybaby pedal and it seems to be really changing my tone... when its on no matter what position its in it sounds like its in a tunnel.. thats the best way i can describe it, most live bands ive seen when they use wah it doest change the tone so drastically..... the other pedals in the chain are a boss tuner and a digitech metal master have i done something wrong?
#2 (permalink) |
![]() Join Date: Feb 2009
Re: Wah pedal problem
where do you have the wah in your chain of fx? do you power it with batteries or a power supply?
Come away, O human child! To the waters and the wild With a faery, hand in hand, For the world's more full of weeping than you can understand. -W.B. Yeats Tonemojo'd all the way... |
#4 (permalink) |
should be first or second in the chain. I put my Big Muff first, then my wah, then my od, chorusy-modulation effects, volume pedal, delay, reverb... etc.
I don’t know, I was really drunk at the time |
#5 (permalink) |
Even if you have the wah off, it's still having a negative effect on you tone as your signal is still going through a good number of the components.
You can fix this with a true bypass looper or by modding your wah to true bypass. You can find the instructions for the latter with a quick Google search. I also agree that the wah should be first or second in the chain. My setup runs Guitar->tuner->wah->compressor->OD->Delay->Amp. Just my personal tastes though. I know a lot of guys run their distortion/OD before their wahs.
#6 (permalink) |
As the others have said, try bringing it up in the chain. It's an experimentation and personal preference thing, but I have the wah first. I have the tuner outside the chain.
If that doesn't work, just try the wah between the guitar and amp and see if you're still getting strange noises out of it. Have a look at something like this How to Properly Order your Effects Pedals | |
#7 (permalink) |
Mac Guitars
I'm selling the guts of a Wah with a true bypass mod, and numerous others to take the brittle high end off and make it mellow with a smoother transition. Think Hendrix.
Check my previous threads for more info.
Mac Guitars - Custom Wiring & Electronic Upgrades. Sign up to the mailing list for an update on new products as they become available. My eBay store: drumbrae4. |
#8 (permalink) |
![]() Join Date: Jan 2008
To be honest, it's the whole chain...
Tuners are notorius for sucking the tone right out, and the "metal master" and wah probably aren't helping. "True Bypass" in the wah won't help, because you still have to battle whatever circuitry is in the "metal master" and the tuner. What needs to be first in the chain is a true-bypass A/B box---the true-bypass of the A/B box will act like nothing is between your guitar and the 1st pedal of your chain, whatever it is. So, if you use an A/B box, the 'A' side goes to the tuner, and the 'B' side going out to the rest of your chain... But the big improvement is getting that tone-sucking Tuner out of your signal's chain... The DigiTech ^MetalMaster^ probably has a buffer in it (that will help add a little "extra" to the signal), so if it were me, my chain would look like this: Guitar | | A / B---->MetalMaster--->Wah--->Amp | | Tuner I run my EFX like this: Guitar--> Clean Boost pedals --> OverDrive pedals --> Distortion pedals --> Fuzz Pedals --> EQ pedals (wah, graphic, parametric, etc.) --> Modulation pedals (phaser, univibe) --> Time-Based EFX (flanger, chorus, delay, reverb). But really, any way that works for you is the right way...try every combination out til you find out what works...
I think myself that we have more machinery of government than is necessary, too many parasites living on the labor of the industrious. Thomas Jefferson ![]() >>> RS GUITARWORKS <<< |
#9 (permalink) |
#10 (permalink) |
Dont shoot the messenger, but Crybaby's are crap. Tone sucker to the max.
Go Fulltone, or some other wah that has true bypass.
___________________________________ amplification...
#11 (permalink) |
That is true, but the real culprit is the tuner.
| Trade analogman chorus pedal for hbe psilocybe phaser pedal | tunanut13 | Member Classifieds | 0 | 01-13-2010 05:43 PM |
| Blackstar HT5 and O/Drive Pedal Problem | fuzzbox100 | The Squawk Box | 8 | 12-03-2009 02:59 PM |
| Fastening Wah Pedal to home made Pedal Board. | Toogy | Pedals | 18 | 10-16-2009 08:22 PM |
| Pedal newbie question: decent, affordable delay pedal reco? | SpinWheelz | Pedals | 8 | 11-11-2008 04:32 PM |
| my ernie ball volume pedal...problem? | d1 guy | Pedals | 1 | 09-02-2008 03:19 PM |
