#121 (permalink) | |
Re: De-Bunking Myths About Capacitors
![]() will do man, but gotta try the .022 k40s I just got first. Just can't get around to A/B'ing them just yet as I'm finishing a pedal build. Also heard that the k42's are good, but just a different kind of good from the k40's. After the k40's, I'll be looking to build a stash, don't worry about it! Thanks for suggesting.
#122 (permalink) |
TONE FREAK
![]() Join Date: Mar 2008
The main difference that I have found between the k40's (silver case)and the k42's (green case) is that the 42's have a more pronounced upper-mid curve to them. I tested both and got slightly different readings which got me curious.
The k40 .022's read about .020-.021 on my meter and that is what I would expect them to read. The .022 k42's only read about .018-.019-ish. They also have a thick coat of green enamel paint on the outside of the case. I was thinking that they may be soviet mil spec, and suspected they were made to run in a high temp. environment like tanks, submarines, missle systems? So I heated one up with a bic lighter while it was attached to the meter and when it got hot it read .021-.022-ish. ![]() The oil may be a bit thicker in the 42's and that would explain the slight variation in Tone. I find the 40's a bit warmer and the 42's more wah like, but they are both great caps IMO.
"Pro Guitar Wiring Upgrades Built & Designed by a Guitar Player with over 33 years of Experience" ![]() Jonesyblues.com for Professional Guitar Wiring Upgrades & DIY Kits Questions? Email to: jonesyblues@yahoo.com or Call 1- 574-249-8816 Aged Parts, Vintage Tone Caps & Wire in my ebay store Jonesyblues Youtube channel Jimmy Page Wiring.com GOD ROCKS! |
#124 (permalink) |
Hi Jonsey,
"Even though .022 has been the standard for Gibson .015 and .010 are the choice by many players seeking good Tone and more useful room on their Tone dials". Would the 0.15 go on the bridge and the 0.10 on the neck in most cases? That first SG kit you sent me has 0.15 and 0.10 and I was thinking about using them on another guitar. Thanks, Kevin |
#125 (permalink) | |
TONE FREAK
Yes Kevin .015 bridge .010 neck... since bridge pu is normally a little brighter the slightly darker cap is used there. I run .010's on both pickups of my SG with good results.
#126 (permalink) | |
Certifiable Tone Chaser
![]() Join Date: Oct 2009
I really like the results the .022's got too muddy when rolled back for that guitar, but they work well for my Epi |
#127 (permalink) |
Curious... RS Caps. Are these PIO? Does anyone know?
Lionel http://soundcloud.com/whitestrat/voices-of-lilith Gear: Lilith, Skatterbrane Pickups, RS Guitarworks Electronics, Fender 65' Princeton Reverb Reissue, Ibanez TSA15 Combo, Blackstar HT5, Digitech Hardwire Pedals, Ibanez TS808HW |
#129 (permalink) | |
Rewiring the ES |
#130 (permalink) |
TONE FREAK
Goldtop-Pretty sure most of the Luxe and Jensen are paper in oil, the black RS caps with the yellow leads I saw on their site are polypropylene. Ask Hillbilly he works for RS and can give you more details.
From the RS website: RS GuitarCaps® feature the finest Polypropylene and metal foil for the truest dynamics and tone
#131 (permalink) | |
TONE FREAK
Glad you tried several caps and found the one that sounded best to YOU.
#132 (permalink) | |
TONE FREAK
#134 (permalink) |
TONE FREAK
Like I have said in earlier posts I favor the lower values for several reasons.
1.The .01's give me plenty of color when needed, you don't want your Tone to bassy for Rock and Blues. Still great Jazz Tone though when rolled off. 2. They give me a lot more usable room on the Tone dial without the mud of an .022 From 7-0 with an .022 can be very dark and unusable for the most part. 3. Excellent woman Tone when rolled all the way off, no guessing where to set Tone dial. More of a upper mid wah Tone.
#135 (permalink) | |
#136 (permalink) | |
TONE FREAK
#138 (permalink) |
Well, what I did like about them, is how controllable the tones are with these caps. Full on, i get a clear tone, which is very hi-fi like and rather "modern". But I can just roll down the tone a bit, and I get a bit more warmth and "honk". So, it's like having a vintage tone at my disposal, and then some!
#139 (permalink) | |
TONE FREAK
Most all your Sprague caps and other USA made are going to be top notch and are the benchmark in the industry. You have to remember that these were originally intended for amps and other electronic devices so they have different properties designed on those applications. They evolved into use as Tone caps in guitars later on. You want to watch out for the cheap Chinese and other brand knock-offs of the "Orange Drops" they will be no where near as good as the Sprague caps.
#140 (permalink) |
My hovland tone caps have the black line, does that mean they are polarized?
"Kobe, tell me how my ass tastes..." |
#141 (permalink) | |
TONE FREAK
You could always try switching them end for end and see if it makes any difference in the way they sound?
#142 (permalink) |
Many Capacitors are Polarized, The most common is of course the Electrolytic, both in through hole and also SMD type, The (Ta) is also polarized and quite common, it is more generally found in power supplies or in DC DC converters where it is now being replaced by Ceramic Multi layer caps , known as MLCC. The drawback with the MLCC is top end cv is only 100uF however there is no need to upsize in voltage or cap value, but there is still a trade off with DC Bias.
To take the point of sounding different in a guitar circuit, the jury is probably out on that it is a passive roll off circuit and in real terms highly unlikely that a sound difference can be heard, It is of course also virtually impossible to prove. We're after all Human beings, we buy some nice caps, they look so cool we get all excited almost wishing them to sound better to justify our indulgence, our mind usually doesn't want us to be disappointed and guess what we're not. I personally love the look of the caps on these p[pages the replica old wax ones look really cute and even better in person, But I cannot hear any difference between one of our cheap ceramic .022 and a PIO ,022, I can hear a difference when I change the cap value, but that is to be expected. The company I work for makes in excess 55 billion pieces of Chip Capacitor ( MLCC ) per month, we also produce, ceramic disc leaded, and many other ceramic products I would guess that virtually everyone her on this forum is using our product. My view on these things like everything else is if you like them buy them and it's not a very big outlay for a bit of fun, and they do look very cool , the jonesy ones are very pretty enjoy
You ain't seen me...... Right! |
#143 (permalink) | |
![]() Oh, and I tried reversing both caps. A slightly different sound. I like it better with the outer foil to the tone pot side. |
#144 (permalink) |
Myth #4 Does it matter which end of my capacitor I wire up to what, is there a polarity?
Here is where I have a problem. I have experimented enough with bumble bee PIO caps and I notice a different tone on one end compared to its opposite. One way, it sounds clearer, better, especially when turning down the tone knob to 0. You get a better woman tone. Flip it the other way and it sounds more midrangey when you turn it down to 0, not as clear and not as good of a woman tone. I used alligator clips and flipped it over and over again to be sure. But, the tone is different no matter if it is considered a non polarized capacitor. Has anyone else noticed this? I will test it thouroghly before I solder them in! Last edited by mojo69; 02-10-2010 at 12:21 AM. |
#145 (permalink) |
Hey Jonesy, have you ever heard of one of these caps before.
Reproduction Cornell-Dubilier "Tubular" .05mfd Vit T? Got sent one with my new Tele pickups. Sealed with wax which could be interesting know my soldering skills.
#146 (permalink) | |
TONE FREAK
If it is the ones that I am thinking of I think they are made for mojotone out of the UK, kind of a spin off on the vitamin Q trademark but I don't know much more about them then that to be honest. They are most likely a new production paper in oil cap, metal case, glass sealed ends. Let me know what you think of it once you get it installed
#147 (permalink) | |
#148 (permalink) | |
TONE FREAK
It just may be a modern pio cap with a Relic'd wrapper?
#149 (permalink) |
I'm sure it's a modern reissue cap. I have just never heard of them. Here's a pic.
#150 (permalink) |
TONE FREAK
Similar to what Luxe puts out I imagine, repro type caps.
