#91 (permalink) | |
Re: De-Bunking Myths About Capacitors
#92 (permalink) |
TONE FREAK
![]() Join Date: Mar 2008
It's all good, be sure to let us know how that .015 sounds to you OK?
"Pro Guitar Wiring Upgrades Built & Designed by a Guitar Player with over 33 years of Experience" ![]() Jonesyblues.com for Professional Guitar Wiring Upgrades & DIY Kits Questions? Email to: jonesyblues@yahoo.com or Call 1- 574-249-8816 Aged Parts, Vintage Tone Caps & Wire in my ebay store Jonesyblues Youtube channel Jimmy Page Wiring.com GOD ROCKS! |
#94 (permalink) |
TONE FREAK
The k40y-9's sound Sweet
#95 (permalink) |
Great Thread!!!
Jonesy, what effect do capacitors have on volume pots? Is a 'volume bleed kit' another way of saying you have a capacitor on your volume pot? I ask this with my Tradition Tele in mind, because I read a review in which a guy with the same guitar opened his up and found a capacitor on the volume pot. According to him, the cap was rated too high, and he replaced it with a .001 cap. (a voume bleed kit ?) The change supposedly helped his volume control to work better, which is what I need in my Tele. |
#96 (permalink) | |
I forgot to mention that to understand what I was saying about phase angles, one must first think of the electrical flow of electrons in a waveform as a 3D object, and not a 2D expression. The 2D version is used mainly in mathematics, which can explain clearly how the primary waveform is affected when the charge is discharged from the capacitor. But to picture it, it must be a 3D model.
Lionel http://soundcloud.com/whitestrat/voices-of-lilith Gear: Lilith, Skatterbrane Pickups, RS Guitarworks Electronics, Fender 65' Princeton Reverb Reissue, Ibanez TSA15 Combo, Blackstar HT5, Digitech Hardwire Pedals, Ibanez TS808HW |
#97 (permalink) | |
TONE FREAK
![]() I think I get it bro, good explanation
#98 (permalink) | |
Wine "experts" are not scientists. No empirical proof can be given about taste. (though how white tastes like red, even if dyed, I'll never know.) Read my post on phase angles and discharge qualities. That should make a lot more sense... Note that I never said anything about whichever being "better". There is no such thing. It's preference.
#99 (permalink) | |
#100 (permalink) | |
#101 (permalink) |
Proud user of "JonesyBlues Customshop" parts ![]() T-Top info read this http://www.mylespaul.com/forums/pick...490r-490t.html Alot of good wiring help http://www.mylespaul.com/forums/tone...g-library.html Help on soldering http://www.mylespaul.com/forums/tone...ow-solder.html Capacitor info http://www.mylespaul.com/forums/tone...apacitors.html |
#102 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Oct 2009
Yeah I do too. I just need to get myself a capacitor meter do some measurements to see which one are the best.
By the way what I ballpark range should be looking for in these caps?
#103 (permalink) |
Since they have 10% tolerance they should be between 13,5 - 16,5uF.
#104 (permalink) |
Well I am getting
.010 .022 .033 .047 I want to get .015 but they didn't have any so I will have to look somewhere else or wait.
#105 (permalink) | |
He might have some.
#106 (permalink) |
Not yet I have to wait until next month to do some purchase.
Beside I have his eBay Store save on my eBay Search for stores.
#107 (permalink) | |
TONE FREAK
I think just about every new capacitor I have ever measured, always reads below the spec'd value never over. The .003's I have actually read .029 uf Pots will read over or under but New caps always seem to read lower than specs. Now Used Old caps will either read at spec or many have gone dark and read higher than than should. I have checked .022's that read .068 and .083 before. Also it depends which range you use on the meter to test them at. I think on my meter I use 200n or 20n and you you will also get a slight different measurable. I may have to look again and make sure those numbers are correct (it's early, still on my first cup of coffee ) on the meter but one reads higher and one reads lower so I measure both than average the two readings.
#109 (permalink) | |
MLP Pacific NW!
![]() Join Date: Jan 2008
Maybe they use those for the Pepsi challenge, and you got them mixed up. But I digress...bump for the thread! ![]() BB
Life's too short to deal with bad tone! |
#110 (permalink) | |
![]() Join Date: Jul 2007
most of the old caps (pulls) I've checked read higher, but 99% have been within tolerance. But, I've probably only checked 100 or so.
------------ Don Primary Tone: what the body and neck does not have cannot come out as tone - Iwanade, BOTB Quote:
#111 (permalink) |
TONE FREAK
I have a VIOT Multi purpose bench meter reads capacitance, volts, amps, ohms etc. I don't test caps for "Leakage" or voltage etc. not necessary for Tone caps just to see what they actually read in uf.
#113 (permalink) |
TONE FREAK
You must have used a "Flux" Capacitor
#114 (permalink) | |
Digital LCD Display Multimeter BEST-890B BEST Multimeter, Digital Multimeter - DinoDirect.com
#116 (permalink) |
PIO caps do make a difference. Swapped out .010 mylar caps (green chiclet thingies) for some .010 russian k40 PIO's from jonesy. Just what my neck position needs. More brightness, but jonesy's 'sparkle' term is probably more accurate. Just a tad bit more. But it's exactly what I wanted it to be.
My bridge position has gone from .022 mylars to .015 k40's. Bigger change here, as I changed cap type AND cap value. There's a bit more clarity and aggressive edge to the sound, but I do miss the more vocal qualities of the old cap. I think I may prefer .022's, since I could use more of that roll-off that higher values give. ![]() Anyways, just to cover all bases, I'm gonna test out these .022 k40's that just got into my mail. AT LEAST, if I keep cap type to the k40-y9's, and manipulate the values, I think I can figure out my preference before I muck around with other types. |
#117 (permalink) | |
TONE FREAK
That looks very similar to the one I have, it should work fine for for checking cap values and measuring pots and circuits
#118 (permalink) |
TONE FREAK
#119 (permalink) | |
Jonesy has them and i´m currently using a K42Y-2 0,022uF in the bridge and it´s the best one i´ve ever tried IMO. IT´s very vocal, musical, really shines in audio (clarity) quality as well IMO. I´m waiting for a K40 to try in the neck but K42´s really kicks ass IMO
#120 (permalink) |
Sticky,sticky,sticky,sticky,
Loads of help!!! Thanks!!!
Flametop Special Build - Carvetop Doublecut Build - '57 Custom BB Replica Build - '56-ish Flame Top Build - Boudreau Celia build - Lefty Walnut Les Paul Build My ebay auctions.. http://www.ebay.com/itm/290915967253...#ht_843wt_1395 |
