Go Back   Les Paul Forums > Music Gear > Tonefreaks
Unread 11-15-2009, 11:55 PM   #1 (permalink)
10guitars's Avatar
Hum/buzz when volume halfway
I'm sure I've seen this topic on the forum somewhere but my search-fu and Google-fu have failed me!
When my volume knobs are on 10 I get zero earth-type buzz. As I wind them down the buzz appears, then disappears again as I go to 0.
Any thoughts?
10guitars is offline   Reply With Quote
Unread 11-19-2009, 11:36 AM   #2 (permalink)
10guitars's Avatar
Re: Hum/buzz when volume halfway
Bumpity-bump.
Unread 11-19-2009, 12:08 PM   #3 (permalink)
Daeborn's Avatar
That probably is a ground problem somewhere in your chain not your guitar. If you have a lot of pedals check your cords. I had the same thing and narrowed it down to one patch cable not making a good connection. Changed it out and problem solved. Way I was told is if you turn down the volume it changes the impedance and if you have a problem in your chain you'll hear it.
It could be a bad pedal too. Trial and error. Plug straight into the amp and slowly add stuff.
Daeborn is offline   Reply With Quote
Unread 11-19-2009, 05:23 PM   #4 (permalink)
axepilot's Avatar
Any thoughts?
Both volumes?
Played just guitar into amp?
Need more info.......................
axepilot is offline   Reply With Quote
