Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 11-03-2009, 01:12 PM   #1 (permalink)
will c's Avatar
Split or Parallel
So I want to install a split circuit in my LP and was just perusing the Seymour Duncan wiring diagrams. One diagram ( Wiring Diagram) says that "parallel is a single coil sound" and that both series and parallel are hum canceling. I was very intrigued by this. To anyone using parallel wiring-do you find this to be true? Should I consider having a split option and a parallel option? How would I wire this up? More questions to follow for sure.
Thanks,
Will
will c is offline   Reply With Quote
The Following User Says Thank You to will c For This Useful Post:
Old 11-03-2009, 01:18 PM   #2 (permalink)
will c's Avatar
Re: Split or Parallel
Oh yeah, 50's style.
Old 11-03-2009, 02:21 PM   #3 (permalink)
FF_Pedals's Avatar
Try it out, just follow the diagram.
FF_Pedals is online now   Reply With Quote
Old 11-03-2009, 08:12 PM   #4 (permalink)
will c's Avatar
Thanks FF. I guess what I want to know is if a parallel mod sounds like a single coil.
Will
Old 11-03-2009, 08:27 PM   #5 (permalink)
Capacitor Ambassador
jonesy's Avatar
Will
You are doing the series/ parallel within the two coils of the humbucker. Normally they are wired in series with each other, if each coil is wound to 4 ohms each when you wire them in series they would be about 8 ohms. This is the normal full output humbucker sound we hear.
If we take the same two coils and wire them in parallel then we would get a lower 2 ohm output, but with both coils on, much lower output and closer to a single coil but with noise canceling features. A humbucker will never sound like a true single coil, but it will get you close.
Old 11-03-2009, 09:06 PM   #6 (permalink)
axepilot's Avatar
2, 4, 8 ohms? Certainly these are not DC pickup resistance readings................more like speaker impedance ratings. Just how do these values correlate to pickup windings? Every pickup I've ever played can be measured in K ohms...................
1996 Les Paul Studio Gem, 2001 Les Paul Studio Plus, 2002 SG Supreme, 2006 Les Paul Standard LE, 2008 SG Classic, Fender Double Fat Strat, Bluesville "Super" Strat copy, Fender Tele, Ovation 1897 Adamas, Taylor 355CE
Germino Club 40, Johnson JM150 Millennium, Johnson JM250 Millennium, Axe FX Standard rack rig, Mesa 4x12 cab (V30's), Highly modded Gibson Titan Medalist
axepilot is offline   Reply With Quote
Old 11-03-2009, 09:42 PM   #7 (permalink)
FF_Pedals's Avatar
I think it was an example. You could multiply by 1000 to get numbers representative of DC resistance. Same math though.
Old 11-03-2009, 09:44 PM   #8 (permalink)
FF_Pedals's Avatar
Will
Sorry, I didn't really know what you were getting at. I just use coil taps instead of parallel coils. I like being able to get both coils individually at the bridge.
If you're interested you should check it out though. Some people prefer the parallel coils.
Old 11-03-2009, 11:16 PM   #9 (permalink)
jonesy's Avatar
Yeah you are correct I left the K out, just like the M on caps sometimes .022. .047 etc. But did you get my drift as far as the question about parallel sounding like single coil or no? That was the point I was trying to make
Old 11-04-2009, 12:42 AM   #10 (permalink)
will c's Avatar
Well after seeing that at the SD website, I'm thinking of having both! : )
Can I have one tone (push/pull) dedicated to splitting the coils of both PUPs and have the other pot (push/pull also) dedicated to switching both PUPs to parallel mode?
I'm after a quasi-single coil tone in my Epi and thought the noise cancelling feature was too good to pass up.
Will
Old 11-04-2009, 12:46 AM   #11 (permalink)
will c's Avatar
Thanks Jonesy. I value your knowledge. I want to talk about getting some Bee's from you (maybe). If not those then some of your other PIO's. I don't think I can PM yet.
Will
Old 11-04-2009, 06:12 AM   #12 (permalink)
huw
huw's Avatar
Will
Seeing as you're in a SD frame of mind have you considered their Tripple Shot pickup mounting rings? Built in mini switches to allow you to get either coil on its own, or both in either series or parallel configuration.
That would seem like a good solution to me - I plan to try it out myself when I can.
Real amps have FENDER written on them...
huw is offline   Reply With Quote
Old 11-04-2009, 08:46 AM   #13 (permalink)
jonesy's Avatar
Will
No problem it's all good. You have over 50 posts so you should be able to PM. Or send me an email at jonesyblues@yahoo.com.
Old 11-04-2009, 12:55 PM   #14 (permalink)
FF_Pedals's Avatar
Will
Yes you can do it. You only need 1 side of a push pull to short out one of the coils so you can use 2 pots for the parallel thing on each pickup then a 3rd to split the coils. If you want separate coil splitting you could use all 4 pots.
Old 11-04-2009, 11:22 PM   #15 (permalink)
will c's Avatar
Sweet!
Old 11-04-2009, 11:24 PM   #16 (permalink)
will c's Avatar
I've seen those and thought the concept was really cool. I like the idea of having push/pull pots though. I was really just using SD for their diagrams.
Thanks,
Will
Old 11-04-2009, 11:25 PM   #17 (permalink)
will c's Avatar
PM sent last night! Thanks Jonesy.
Will
Old 11-05-2009, 06:01 PM   #18 (permalink)
axepilot's Avatar
OK...................I wasn't trying to be a wiseass........................I was just a little confused since you're one of the guys in the know here.
Old 11-05-2009, 06:07 PM   #19 (permalink)
jonesy's Avatar
Good observation.....I have had the flu the past 3 days so I have been out of it a little more than usual
Old 11-05-2009, 06:14 PM   #20 (permalink)
axepilot's Avatar
Mojo sent for a speedy recovery, jonesy.
Old 11-05-2009, 06:57 PM   #21 (permalink)
jonesy's Avatar
Thanks man I appreciate that!
Serial to parallel or parallel to serial? Silverbursted The Custom Shop 5 09-14-2009 12:31 PM
Series/Parallel Switch mike newport The Squawk Box 2 02-25-2009 03:45 PM
Parallel Humbucker vs. P90 jayj Pickups 6 12-25-2008 10:24 AM
Does this switching split or set to parallel? Jacko The Custom Shop 1 11-09-2008 07:02 PM
Humbucker Series/Split/Parallel Mini Switch Help jumpinjackf1ash Pickups 1 10-05-2008 04:39 AM
