Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 10-29-2009, 12:06 AM   #1 (permalink)
lp_junkie's Avatar
PA sytems
I am shopping for a new PA system, and I am leaning towards Carvin.
Years ago we used Carvin systems for touring Japan and parts of the US, and never had any issues at all.
Now that I am putting my own band together I am starting to look at systems that will do medium to large clubs/outdoor venues.
So what are you guys that are currently gigging using?
LP_Junkie
my personal MySpace
Disclaimer- The opinions expressed on this site may cause incontinence, wadded panties, indigestion, insecurity and other serious maladies. Use as directed, not intended for the overly sensitive and humor impaired.
lp_junkie is offline   Reply With Quote
Old 10-29-2009, 02:43 AM   #2 (permalink)
BMS
BMS's Avatar
Re: PA sytems
I use Mackie boards, QSC amps, and Yorkville Speakers(Mains & Monitors) . For outboard gear I use Lexicon dual channel effects. DBX EQ and Berhinger Compressor/Gates. Of course the reliable Furman conditioners. Yorkville make some great powered mixers that have built in effects and can power mains and monitors at a great price without sacrificing quality. I also use the Yorkville subwoofers. 18" for large venues and 10" for pubs. Cheers!
BMS is offline   Reply With Quote
Old 10-29-2009, 05:33 PM   #3 (permalink)
lp_junkie's Avatar
Re: PA sytems
How do you like the QSC amps?
LP_Junkie
my personal MySpace
Old 10-29-2009, 10:23 PM   #4 (permalink)
BMS
BMS's Avatar
Re: PA sytems
Crisp and clean. I also use Yorkville amps. But you can sure tell the difference against the QSC. And the Yorkville's are great so that tells you how good the QSC's are.
Old 11-06-2009, 05:36 PM   #5 (permalink)
will c's Avatar
Re: PA sytems
+1 for the QSC amps and Mackie boards.
Check out McCauley loudspeakers. McCauley.com : Home Built near my hometown. I think they sound great and have never had an issue with them. Solid.
Will
will c is offline   Reply With Quote
