Go Back   Les Paul Forums > Music Gear > Tonefreaks
Unread 10-24-2009, 04:49 PM   #1 (permalink)
ggc
Multi/Rack Effects Recommendation?
Hi Folks. I'm hoping to get some opinions/recommendations for a multi-effects unit. The unit can be in rack or floorboard form, but I need some pretty specific requirements to be met. Please keep in mind that I have not looked at this type of gear for at least 10 years, so I'm sure that there's a lot of stuff available that I'm not aware of.
I don't use a lot of effects most of the time, but I'm pretty specific about the ones I like. I'm looking for something that will do a good CE-1 type chorus (I'm using a Retro-Sonic right now), an Electric Misstress type flanger (I'm using an EHX), a MXR Phase 90 type phasor (I'm using the re-issue now), and some decent Reverbs, Delays, and Pitch Shifting (I'm using a RSP Intelliverb for these now).
The other requirement is that the unit have a 100% wet output available as my Mesa/Boogie has a parallel effects loop.
My goal is to simplify my setup, without losing any flexibility. I would like to have my volume, wah, and tuner going to the input of the amp and everything else coming from whatever effects unit I end up with.
I would really appreciate any suggestions or input that anyone has. Thanks very much in advance for your help!
ggc is offline   Reply With Quote
Unread 10-25-2009, 08:08 AM   #2 (permalink)
Re: Multi/Rack Effects Recommendation?
find an old analog ibanez ue-400
johnny1423 is offline   Reply With Quote
Unread 10-25-2009, 10:56 AM   #3 (permalink)
TreeHugger's Avatar
I was in the same position as you, hadn't looked at or messed with rack gear in years. I gave it another shot, so I bought a few things used and dirt cheap. I am totally back to pedals now, much easier to deal with and tweak ANYTHING simply. But at least I have a rack that sits there and looks cool
Using as many effects as you say that you want, I think your sound quality will be better using pedals, and your overall tone won't be affected as much.
When I was researching rack gear, I read good things about the G Major. What's your budget? You could pick up a BOSS GT-8 for cheaper these days. I haven't heard good things about the GT-10. I have the BOSS ME-50 but I don't use it anymore, sounds really good though.
Gibson 08' Les Paul Traditional GT
2000 Fender American Standard Tele
1998 Fender American Standard Tele
Fender Highway One Strat
Gretsch 6120RHH
Marshall JCM900 50w DR
Marshall 1960 cab
1975 Fender Twin Reverb
TreeHugger is offline   Reply With Quote
Unread 10-25-2009, 03:38 PM   #4 (permalink)
ggc
Thanks for the responses folks! I would prefer to keep the cost at $500 or less. The only problem I would have with using pedals for everything is that I need to be able to program quite a few delay times...chorus/phase/flange I pretty much just get the sound I like and use it for everything.
Unread 10-25-2009, 05:55 PM   #5 (permalink)
lp_junkie's Avatar
Check out Digitech GSP1101 and the floor controller that goes with it, I use it in the studio a lot and it is incredible and versatile. It is a bit expensive but worth it's weight in gold, especially in the studio but I could definitely see using it live with a power amp and a couple of 4x12's.
Shane
Just a guitar bum...........
lp_junkie is offline   Reply With Quote
