Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 08-30-2009, 06:18 AM   #1 (permalink)
What is the benefit of higher strings and lower strings?
What are the benefits of higher strings and lower strings? How does it effect the sound? and how does it effect your playing?
enes is offline   Reply With Quote
Old 08-30-2009, 07:57 AM   #2 (permalink)
dalandan's Avatar
Re: What is the benefit of higher strings and lower strings?
it has a bigger effect on your playing than it does on tone IMHO. although a lot of people would disagree.
you wont be able to play as fast and as easily with higher strings. but lower ones are a bit harder to bend for me. i can't seem to feel the bend as much.
i like my strings a bit on the high side because I like the tension better.
Enjoy the music.
dalandan is offline   Reply With Quote
Old 08-30-2009, 08:20 AM   #3 (permalink)
siore's Avatar
Higher: Better tone. Note breathes more when you dig into those bends. Much more expressive.
Lower: More economical to play faster stuff (eg. diatonic scales played as legatos).
Those are the differences that matter to me. I like it somewhere in the middle, something that allows me to get the best of both worlds.
siore is offline   Reply With Quote
Old 08-30-2009, 09:33 AM   #4 (permalink)
Capacitor Ambassador
jonesy's Avatar
Higher action/ strings will give you a bit more volume and you will get more "bounce" from your strings when you play, also better if you play some slide once in a while.
Lower action will allow ease of fretting as it takes less pressure to push strings down, so you may be able to play a bit faster. To low of action will cause problems like fret buzz and decreased attack.
jonesy is online now   Reply With Quote
Running lower watt head into higher watt rated cab. bildozr The Squawk Box 25 07-27-2009 08:11 PM
Strings moshikoalis Epiphone Les Pauls 17 04-16-2009 01:52 PM
.09 Strings vs. .10 Strings--Newbie Question goby Guitar Lessons 39 11-15-2008 07:01 PM
9`s 10`s 11`s strings ruffdog64 Tonefreaks 2 08-02-2008 01:52 PM
My strings are higher than normal.... Fixxxer The Custom Shop 0 01-27-2008 10:35 PM
Powered by vBulletin® Version 3.8.4
