#1 (permalink) |
MLP Cub Reporter
how would i rewire my semi hollow body?
my epi casino is an incredible guitar i have made no modifications to it what so ever but i when i'm playing her i never fiddle with the controlls because i can never get it to sound how i want it, its a 65 reissue and i'm wondering if i should leave it the way it is or rewire it 50's style with indipendant vol controles. can i get some advice on this allong with how i would get the pots out in order to make the wiring changes
Current gear: Gutted and refitted Epiphone '58 Korina Flying V custom light finish, Marshall JCM900 SL-X head Buckle Rash: Dude, just stop polishing ![]() R.I.P Phillip Burkinshaw 15/8/1945 - ?/8/2009 64 years old and still a rocker. Paul....Where the hell is that guy half the time!?!!
| The Following User Says Thank You to Paul For This Useful Post: |
#2 (permalink) |
Re: how would i rewire my semi hollow body?
" Without a song The road would never bend, Without a song, A man ain't got a friend, Without a song, The day would never end Without a song So I keep singing a song " |
#3 (permalink) | |
MLP Cub Reporter
#4 (permalink) |
MLP Cub Reporter
nah thats only helped me with getting the things out the wireing is really weird would it still work if i jsut wire it like an LP?
#5 (permalink) |
Best thing to do is check with the people at Mojo.
They are very helpful and will guide you as to what is involved and the best way to do it. I ordered 2 sets from them 1 for my LP and 1 for my 335, it's a little tricky with the 335, getting all the pots aligned but in about 1 hour it was done and what a difference.
#6 (permalink) | |
MLP Cub Reporter
all i had to do was study the wiring and see where each led to and it was an easy switch it works great no buzzez no cold solder joints nothing, i love the indipendant vol controles.
#7 (permalink) |
![]() Join Date: Dec 2007
Thanks for this post....I have an old 12 string archtop and was wondering how to rewire it....this helped....
#8 (permalink) |
MLP Cub Reporter
it helps just to study where all the wires lead to and even make a quick digram.
#9 (permalink) |
I always draw a quick sketch of the wiring when I work on mine, that way if I'm interrupted I can go back w/o problems, gladd all is well on your update
#10 (permalink) |
![]() Join Date: Aug 2007
Long pairs of Hemostats ( Surgical tools ) and tie string to the pots top after removing the washers ect before dropping em thru the holes with long string so you can pull them back into place easier thru the sound holes
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#11 (permalink) |
![]() Join Date: Jul 2007
I use heat shrink tubing to pull the pots back through. Get a long piece that just fits over the shaft (1/4"?), push it thru the hole for the pot, out the F hole, put it on the pot, apply a bit of heat, pull it thru and drop the washer and nut over the end of the tube. Finger tighten then cut off the heat shrink.
#12 (permalink) |
*bump for reference*
The Geartalk Video Blog |
#13 (permalink) |
btw, in that Casino, I'd go with NOS .022 Black Beauties. They are cheaper than bees, and would probably have been stock in a '65 (that's what are stock in my 64 ES330)
#14 (permalink) | |
I have some Sprague Orange Drops I could slap into it, and I could probably run down to the store and get some pots, but will that be enough? Also....long or short shafts on those?
#15 (permalink) |
I assume short shaft, it's a thin piece of wood they go through.
I'd check with Jonesy and see what he's got close to Black Beauties. ODs will be okay, but for not much more you can get (IMO) something better. |
| Gibson Custom Shop ES-339 Semi-Hollow body. | jamisonmp | Other Gibsons | 10 | 11-25-2008 10:55 PM |
| PLEASE HELP ME!!!! epiphone rewire? | voxac30dude | Epiphone Les Pauls | 43 | 05-23-2008 06:13 AM |
| Hollow SG 12-string project | Mighty Tom | Tonefreaks | 3 | 04-24-2008 01:15 AM |
| My semi-new Epi | Sinmastah | Epiphone Les Pauls | 4 | 04-02-2008 02:40 PM |
| rewire les paul custom 2? | bandjosh | Epiphone Les Pauls | 16 | 03-23-2008 08:57 PM |
