Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 08-08-2009, 10:07 PM   #1 (permalink)
Installing EMG's
I am installing a set of EMG's into my Les Paul. Do I need to still use the metal plate in the control cavity to install the EMG volume and tone pots? Or should that be left out?
Any help, links, etc. on this installation would be greatly appreciated.
Thanks!
blackelement is offline   Reply With Quote
Old 08-09-2009, 02:17 AM   #2 (permalink)
jrnic's Avatar
Re: Installing EMG's
Depends on you. You don't have to if you don't want to. Plenty of people have done it here. The main reason for the plate is for grounding issues. EMG's don't have to be grounded to your bridge. They're supposed to be isolated from it. It would work quite easy without the plate. Just use the shorter shaft pots. (The longer ones are made for use with the metal plate.) Think of it this way. If you remove the entire plate with all the controls, you can tuck it away and re-install it to make the guitar original again.
As for links, go to EMG's web site. They have great wire diagrams for their pickups with different combinations if you want to customize it.
jrnic is offline   Reply With Quote
Old 08-09-2009, 02:26 AM   #3 (permalink)
Thanks for your help! I ordered the pickups with Long shaft pots thinking I needed them. Of course, once I took the plate out and put a volume/tone pot in I realized they were to long
Could I use the washers etc. from the plate to take up the extra length? Or just use the plate to install all pots and wires and then attach it to the body?
Of course, if i use the plate I figure I would remove the original output jack wiring and bypass the center section of the plate where the output jack and other wires attached too? Is that right?
Sorry for all the questions... just trying to get an idea of how to do this!
Old 08-09-2009, 03:07 AM   #4 (permalink)
Beerdog80's Avatar
Epiphone Les Pauls use the short shaft pots since the tops on those are really thin. Gibson Les Pauls require the long shaft pots. To adjust the height of the pot, just use the washers that came with the EMG kit.
In my Gibson Les Paul, I took out the plate and used the long shaft pots that came with EMG's kit.
Beerdog80 is offline   Reply With Quote
Old 08-09-2009, 10:05 AM   #5 (permalink)
Ok, makes sense. I'll try that and see how it comes out. Thanks for your input.
Old 08-11-2009, 01:40 AM   #6 (permalink)
jrnic's Avatar
If you want to, you can removed everything from the plate and start from scratch with the new electronics. It should work fine.
EMG's in a PRS MarcAutomatic My Other Guitars 1 03-14-2009 12:32 AM
EMG's Deftone Pickups 13 03-11-2009 07:00 PM
What is it with 'EMG's'? dennistruckdriver Epiphone Les Pauls 95 08-06-2008 05:33 PM
EMG's & LP SLY_Z_28 Epiphone Les Pauls 17 07-08-2008 05:28 PM
Les Pauls with EMG's LePaul54 Gibson Les Pauls 21 01-28-2008 01:50 PM
