Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 06-27-2009, 01:13 PM   #1 (permalink)
yllsacky's Avatar
Send a message via Skype™ to yllsacky
Is a Lp wiring kit hard to assemble??
i want to wire my lp back to a lp but ill keep the killswitch
anyway is a kit like this hard to assemble? and is it any good?
here is some info about it
What's in the kit:
(2) 500K RS Short-Shaft SuperPots™- We designed these pots in conjunction with CTS. Used for the volume controls in the kit, these pots have a custom taper that gives you a noticeable difference between each number on your volume control. You can finally roll your volume down to 2 or 1 and not loose any clarity, even in the neck position. A smoother resistor path make this the best pot to ever be used in the guitar.
(2) 500K CTS Short-Shaft Audio taper pots
(1) RS .022 GuitarCap®- The guitar cap is the first and only capacitor designed specifically for the guitar. This part is the only capacitor in the world that meets our stringent quality-control standards, not only because of its construction, but because of how great it sounds in the tone circuit!! The .022 microfarad GuitarCap® is best for the bridge position tone control of your guitar.
(1) RS .015 GuitarCap®- This is the same great GuitarCap® as above, just in .015 microfarad. This is best used for the neck tone control.
(1) Length vintage-black wire- Used for the grounding in the circuit.
(1) 4-foot length braided wire- Used for wiring switch.
(1) Long 3-way toggle switch- Manufactured by Switchcraft.
(1) Input Jack- Manufactured by Switchcraft.
gear:
epiphone les paul 97' heavily modified
epiphone les paul 100 96' heavily modified
Gerdin acoustic made in Sweden 51'
line 6 spider 3 15w
digitech rp90
R.I.P les paul we miss you
Originally Posted by diceman View Post
I've seen a bass which was black with a thin silver burst around the edges. It looked pretty good.
Originally Posted by djwilbanks View Post
No you haven't.
yllsacky is offline   Reply With Quote
Old 06-27-2009, 01:14 PM   #2 (permalink)
yllsacky's Avatar
Re: Is a Lp wiring kit hard to assemble??
btw i can solder and stuff like that... i got some experience in that kinda stuff
gear:
line 6 spider 3 15w
digitech rp90
No you haven't.
Old 06-27-2009, 01:22 PM   #3 (permalink)
Lungo's Avatar
I have that same kit in my Les Paul and many highly recommend them.
It's not difficult to install but takes patience. At least for me, I took it slow and tried to make everything as neat as possible. If you don't want to spend the time putting everything together you could always get one of their pre-wired kits. I think if I had to do it over again that's what I would have done just to save some time.
Lungo is online now   Reply With Quote
Old 06-27-2009, 01:28 PM   #4 (permalink)
yllsacky's Avatar
i got loooooooots of time and the pre-wired one is like double the prise and dosent come whit switch or jack
gear:
line 6 spider 3 15w
digitech rp90
No you haven't.
Old 06-27-2009, 01:57 PM   #5 (permalink)
yllsacky's Avatar
anyone else?? (bump)
gear:
line 6 spider 3 15w
digitech rp90
No you haven't.
Old 06-27-2009, 02:00 PM   #6 (permalink)
5F6-A's Avatar
Send a message via Skype™ to 5F6-A
you should be alright...... I love doing things like this so I'd be delighted to be in your shoes... mind you I'll be doing something similar as soon as I have my Lp back from a refret...
Best place in Yorkshire for a cuppa...
Saltaire's Vicars
5F6-A is offline   Reply With Quote
Old 06-27-2009, 02:05 PM   #7 (permalink)
yllsacky's Avatar
ohhh your getting bigger ones right?? like dunlop 6000s?
gear:
line 6 spider 3 15w
digitech rp90
No you haven't.
Old 06-27-2009, 06:05 PM   #8 (permalink)
yes, get it
r9in09 is online now   Reply With Quote
Old 06-27-2009, 06:07 PM   #9 (permalink)
MLP Trucker
dennistruckdriver's Avatar
Not if you are of average or higher intelligence.
Old 06-28-2009, 02:35 AM   #10 (permalink)
5F6-A's Avatar
bigger frets.... correct
Saltaire's Vicars
would be hard to G-Minor Epiphone Les Pauls 3 06-09-2009 07:58 AM
How hard can it be captcoolaid Luthier's Corner 7 05-06-2009 08:45 AM
Feeler: Complete Gibson Les Paul BFG wiring kit, killswitch, pots, caps, wiring. etc. djwilbanks Member Classifieds 25 03-18-2009 08:34 AM
!@!# this is hard! brettk7 The Cellar 5 01-27-2009 04:59 PM
50's Wiring vs. Modern Wiring, Opinions Please Jafo Tonefreaks 3 12-09-2008 10:35 AM
