Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 01-31-2008, 12:05 AM   #1 (permalink)
schmidty123's Avatar
what can help me get increased sustain
i own a epi les paul standars with a burstbucker 2 in the bridge i was wondering any little tricks that can increase the sustain
schmidty123 is offline   Reply With Quote
Old 01-31-2008, 05:40 AM   #2 (permalink)
Re: what can help me get increased sustain
theres a product called fatfingers which screws on the end of the headstock (made of brass i think?)...guitar mag reviews say increase in sustain is pretty amazing and unexpected.
I've also heard of folks clipping a shubb capo up there to do pretty much the same thing...not tried it myself..
barrydjuptight is offline   Reply With Quote
Old 01-31-2008, 07:41 AM   #3 (permalink)
Bluesjam's Avatar
A nice amp (half stack). A good pedal to drive them pre amp tubes. And play louder.
Gibson 2001 LP Standard Honeyburst w/WB Habaneros
Gibson Les Paul Studio Vintage Mahogany w/ WB Vintage Hot's
Fender Jimmie Vaughan Strat w/ WB 6707's set#7
Marshall DSL 50 w/ 1960AX
Fender Deluxe Reverb RI
Bluesjam is offline   Reply With Quote
Old 01-31-2008, 10:18 AM   #4 (permalink)
dwagar's Avatar
a couple things I can think of:
- if you're playing with a really light action, try raising it a bit
- try dropping the TP right down to the body. If your strings hit the back of the bridge, you might have to topwrap
- try a pair of steel tailpiece studs
- try a different brand of strings. Try going up one step (if you're using 9s, try 10s)
- most importantly I think, work on your vibrato.
dwagar is online now   Reply With Quote
Old 01-31-2008, 11:42 AM   #5 (permalink)
Master Luthier V.I.P.
Roman Rist's Avatar
I agree with all points except for one.
Lighter strings sustain longer than heavier strings.
The general rule is a heavier string will give you better tone, and a lighter string will give you better sustain.
The lighter string just vibrates longer.
Roman Rist is offline   Reply With Quote
Old 01-31-2008, 11:42 AM   #6 (permalink)
eddie_bowers's Avatar
Apart from compression (which can muddy things up if over used) try the Faber Tone-Lock locking Tailpiece Studs and Spacers. That helped mine a lot. It's better IMHO than dropping the tailpiece because it sandwiches the tailpiece (off the body) making it immobile and creating better coupling.
-Eddie
eddie_bowers is offline   Reply With Quote
Old 01-31-2008, 11:54 AM   #7 (permalink)
dwagar's Avatar
See? You learn something new everyday here.
Thanks man.
Old 01-31-2008, 12:36 PM   #8 (permalink)
yea i use 11's now cus i like the tone i also heard that rasing the pole peices can help?
Old 01-31-2008, 12:48 PM   #9 (permalink)
Make sure your pickups are not TOO close to the strings. I have my pickups set an 1/8" away from the strings (press the last fret and measure from string bottom to top of pickup screw). For a while I had the neck at 1/16" by mistake. The pickup magnets were impacting string vibration. When I moved it down to 1/8", the increase in sustain and pickup bloom was quite noticeable.
Terry.
Tone Seeker is offline   Reply With Quote
Old 01-31-2008, 04:15 PM   #10 (permalink)
Blues Power's Avatar
a good amp and pedal like already mentioned is all youll need IMO
Blues Power is offline   Reply With Quote
Old 02-02-2008, 08:28 PM   #11 (permalink)
mrkenny's Avatar
-"most imortantly I think, work on your vibrato."
I host an open mic and experience a lot of guitar players, most of then use a pedal of some kind to achieve sustain. You can use vibrato to squeeze and knead the string thus creating the "sustain" (at any volume) to the same result. Producing a sustained note manually has a different quality than one coming from a stompbox. A stompbox has the potential to become a crutch, especially early on. Working on your vibrato is really important.
mrkenny is offline   Reply With Quote
Old 02-03-2008, 08:14 AM   #12 (permalink)
5F6-A's Avatar
fernandes sustainer....
:P
or a bit less drastic try a set of titanium saddles but it alters the tone a bit.
Julie & Shelley; my kind of heroines. read why...
"The tyrant dies and his rule ends, the martyr dies and his rule begins." Sören Kierkegaard
5F6-A is offline   Reply With Quote
Old 02-03-2008, 08:44 AM   #13 (permalink)
-Eddie
+1. I use Tone Pro's locking tailpiece/studs/bridges and they make a HUGE difference in sustain. And, RFR is correct too, that the lighter the gauge the more vibration.
marshallcrazy is offline   Reply With Quote
Old 02-13-2008, 06:56 PM   #14 (permalink)
that and i also heard rasing the pole pieces
Old 02-13-2008, 07:18 PM   #15 (permalink)
...with a big mouth
Big John's Avatar
...- most importantly I think, work on your vibrato.
Originally Posted by mrkenny View Post
...Working on your vibrato is really important.
+1000
Big John is offline   Reply With Quote
Old 02-13-2008, 08:00 PM   #16 (permalink)
lol i get it guys lol vibrato
Old 02-14-2008, 12:51 AM   #17 (permalink)
dwagar's Avatar
not just for sustain, vibrato is extremely important tonally as well. Gotta be in your bag of tricks.
Old 02-14-2008, 01:13 AM   #18 (permalink)
Vibrato Vibrato and MORE Vibrato, I love a long sustaining guitar, and I am with Mr Kenny about relying on any pedals ,If your strings are too close to your neck and or pickups, the magnetic field and the proximity of the frets are goin to have a bearing on your string vibtrations . I use 10's minium, strings set a lil higher than many put them, and as much natural tube saturation as I can get from my amp and location. a decent tube amp, there is no second place substitute for good tone, and no better way of getting that natural drive sound that leads to sweet sustain
lp59aholicDon is offline   Reply With Quote
Old 02-14-2008, 10:34 AM   #19 (permalink)
What height do you set your strings at?
Terry.
Old 02-14-2008, 02:03 PM   #20 (permalink)
Terry.
I dont set by a gauge, its sorta an eyeball / feel thing but several guys who have tried em go, "Eh, a lil high on the action?"
Old 02-14-2008, 02:20 PM   #21 (permalink)
I was just listening to a live version of Parisienne Walkways by Gary Moore and there is point where he holds a note for what sounds like 15 seconds. Geez, I don't know how he does that.
Old 02-14-2008, 02:33 PM   #22 (permalink)
You have never had a tube amp cranked out and found those magic spots where the note has been picked off where the speaker, strings , pickup all seem to be all connected to your fingers? Your WHOLE Guitar just resonates ?
have done it many times, but it takes the right kind of set up , Its bascially a controlled feedback
Old 02-14-2008, 02:36 PM   #23 (permalink)
...with a big mouth
Big John's Avatar
Here's something I found on the net a few years ago by guitarist Paul Shuler.
"When you pluck a string, a group of waves are propagated at the point of contact (pick). This wave group travels down the length of the string until it hits a reflection point (fret). A small bit of energy is transferred across and into the fret, but most of the wave group and it's energy are reflected back to the bridge. The same basic mechanics of reflection occur at the bridge. When the wave group returns to the original starting point (where you picked the string), the cycle is complete and you hear the note. The slower this cycle happens, the lower the note. The faster this cycle happens, the higher the note. To increase the length of the note (sustain), you either need hard and heavy reflection points, or you need to add energy back into the string at one of the reflection points. This is called vibrato."
Old 02-14-2008, 06:52 PM   #24 (permalink)
GLOBAL EMO MOD
FLICKOFLASH's Avatar
get these Proto WB Pickups / Les Paul all with a custom 2x12 Peavey Classic 20
FLICKOFLASH is online now   Reply With Quote
Old 02-14-2008, 07:07 PM   #25 (permalink)
It didn't sound like it was feedback induced (but what do I know). Usually you can hear that surge sound and then it settle in on the tone (which usually doesn’t have the same quality as the original), but this just sounded like he held the note forever.
Old 02-14-2008, 07:17 PM   #26 (permalink)
shotgunlew's Avatar
Damn right, best pickups ive ever heard!
60% of the time...it works every time....
Gun Control = Using Both Hands!!
Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys!
Chris "The Gunhand" Of the MLP Pirates Crew
shotgunlew is online now   Reply With Quote
Old 02-14-2008, 07:28 PM   #27 (permalink)
tarddoggy's Avatar
