#1 (permalink) |
![]() Join Date: May 2008
How to Use the Controls on a Les Paul
Because a couple of people asked about it, here is the stuff I wrote in another thread about using the controls on a Les Paul. The OP asked how to use the controls to get sounds like Page and other classic players. My reply includes some alternative suggestions on how you might EQ your amp to get a different range of noises, and get a little bit more out of the neck and middle positions.
Hope it's of some use. Here it is: First, your volume controls do not just control your loudness, but also your level of distortion (‘gain’ or ‘overdrive’). If your guitar has modern wiring, lowering the volume will also reduce the available treble, as if you’d turned the tone down too. If you have 1950s wiring this effect is far less prominent. Secondly, your tone control not only cuts your treble, it also reduces the amount of ‘space’ your guitar seems to take up in the mix. Turning your tone down can effectively pull you ‘back’ into the mix. Enough basics. Here’s some pointers. EQ Your Amp for the Neck Most of the time you’ve probably set up your amp for a good tone from the bridge. Try this instead and see what happens. 1. Turn all your volumes and tones up to 10. 2. Select the neck pick up. 3. Adjust your amp so you get a good soloing tone for that pickup. 4. Switch to bridge. This will be too bright. Ice-pick through ear territory. 5. Tame bridge with tone control, until you’ve got a good soloing tone. You now have your ‘boost’ sounds. Now turn the bridge vol down (about 75-80%), until you’ve got a good crunching rhythm sound. If you have modern wiring you may need to turn up the tone a little at this stage. You could now play the rhythm on the bridge, and switch to the neck for the solo. Solo on Bridge, cleans on Neck Turn up your bridge tone and vol. That’s your solo sound (ice pick and all). Turn your neck vol down to about 50%. If your amp is any good, that should be nearly clean. If you’ve got 1950s wiring, it won’t be muddy either. You may now play the intro to Since I’ve Been Lovin’ You on the neck pick up. Switch to bridge for the signature lick. Back to neck, or turn down bridge to 50-60%. For a more sensible bridge pick up sound, just turn the tone down a fraction to clip some of the hairs off it. If your amp is good, it should be sensitive enough to clean up when you turn down, and also to clean up if you back off with your right hand an pick gently. Use both these effects to control your tone. Middle positions Leave your bridge in its rhythm setting, then switch to middle. Now turn down the neck to nearly nothing, then slowly turn it back up (to about 50%). Somewhere across this range you’ll hear three fairly distinct tones. It’ll start out sounding like the bridge on its own. Next, it will fill out (i.e. get some extra bass), and it might do this quite suddenly. This is a really useful sound for soloing, because it basically sounds like the bridge pickup, but it’s fuller and meatier without being in any way muddy. As you keep turning up the neck vol it will start to sound more like both pick ups. This can be sort of nasal, but quite good. Once you get both pick ups to the same vol (~ 75%) you’ve got the classic middle sound. Many people find this a bit muddy, but if you EQd the amp for your neck pick up, you should be OK.
...A tasty world...a very tasty world... |
| The Following 48 Users Say Thank You to Splattle101 For This Useful Post: | 5F6-A, AmazingJourney, asher67, axepilot, blues.junior, BluesLover, BOBBO, Curlymaple, Dexter.Sinister, diceman, eddy999, ElhazGuy, Emiel, epilespaul2000, ExpatBrit, fatb0t, Fuelish, guitarsmark, HellfireLP, Hope, Iceman0124, Jariot, Jason, jason_mazzy, JBranch, jo07, Jonathan, Liam, Luke122, matthornet, mitchbob9, MrRhoads, PINKBITS, Pink_Floyd, r9in09, Ride on a Pony, Silverbursted, siore, skateboardtomygrave, stone_gossard, Sudetenland, tang350, Tuya Customs, underivy, vkennedy, vladmaximus, voodooChile, xsouldriverx |
#2 (permalink) | |
Re: How to Use the Controls on a Les Paul
In this one, Garry Moore's right hand returns to his controls after every lick, as if by reflex. He's riding his volumes all the way home. Good luck with it, man. cheers, Splat
#3 (permalink) |
And:
Before I forget again, there's one thing about the middle setting that I forgot to mention. It’s a lot easier to use than it sounds to describe it! If you set your neck so it’s basically clean (~ 50%), and then set the bridge to about 75%, that will give you the sounds-like-the-bridge-pickup-but-fuller tone. As I said before, that’s a good rhythm or lead sound. From that basic position, if you want to get a boost, all you have to do is adjust ONE volume control up to 100%. Either will work. If the bridge, you get the biting sound, if the neck you get the fuller sound. When you’ve finished, simply turn that volume back to where it was. Simple. In other words, once you’ve worked out your pre-sets, using the Les Paul this way is as simple as playing a Telecaster.
#4 (permalink) | ||
Flicktehbean!
![]() Join Date: Aug 2008
Good on ya Spatt, great post.
Laney amplification disciple. Quote:
#6 (permalink) | |||
Flicktehbean!
#7 (permalink) |
Many thanks Splattle! this is one of those...... why didn't I think of that! Dude, you rock, Bro! I was complementing you on one post, but couldn't remember which thread, but anyhow, I did try that set up (my r9 with RS vintage kit) last Saturday for a gig (open air venue) I must admit, you freakin' nailed it. I got bunch of guys coming over after the set and checking out my set up and asking?? Dude, that never happened to me before (i gues I suck
) like they say, "you got it going on", i felt really good! But I think it will take a little more practice (re learn my habit) if you will...Thanks again, Curly |
#10 (permalink) |
About time! Sticky this thread! Way valuable post for me since I came here. When I chanced about Splat's tip, I was having a hard time dialing in a tone that can go from raunch dirty to pristinely clean at the touch of the knobs. It didn't occur to me how valuable the tone knob is. I thought it was just something to cut the treble.
So the way I approach les paul controls now is, EQ for the neck, roll back the bridge tone. Then I adjust the amp gain so that it's dirty on 10, but I get clean clean tone, even when I dig in, around 2-3 of the bridge volume knob. This way, I can easily switch from clean to crunch at the turn of the volume knob. Then use the tone knob for more cut if playing with other instruments. Step on an overdrive pedal set to boost for heavier music. With the bridge set to clean, I can further thin out the les paul bridge honk by switching to the middle position, utilizing phase cancellation to my advantage for those funky rhythm comps. Thanks again Splat.
#11 (permalink) |
Great post, thanks! I am no Gary Moore, but I also adjust my volume and tone controls all the time while I play. It is true that after a while, it becomes second nature and you don't have to look down at all, just reach and grab the appropriate volume or tone knob and season to taste.
“I know how to get there, all I've got to do is keep playing.” - Jimmy Page. |
#12 (permalink) |
it's so funny that we automatically EQ the bridge pickup, then wonder why the neck sounds odd.
excellent thread. two thumbs up
"There is hopeful symbolism in the fact that flags do not wave in a vacuum." - Arthur C. Clarke |
#13 (permalink) |
great info.
1990 Les Paul Standard 1980 Fender Strat Hard-Tail reissue 2008 Blueridge BR160 1983 Fender Concert II |
#14 (permalink) |
saved this to my favorite section so I can always come back to this
Guitars: Taylor custom solid body Gibson: LP Brimstone Burst LTD, LP Trad PRO Vintage Sunburst Epiphone Elite MIJ: Ebony SG, Ebony LP Fender Toronado, and Gemini 3, handed down to me from the man in black himself! Amps: Line 6 Spider 3 15watt Fender Super Sonic combo 1x12 avoiding risk at the cost of living is human. Living your life assuming the risk is heroic. I choose the latter. US ARMY RANGER (RET) Disabled Combat Veteran |
#15 (permalink) |
i've hardly put my guitar down since i read this. best piece of musical advice i've ever had.
#16 (permalink) |
sticky????
#18 (permalink) |
stick this, it's the best advice. i've not had my bridge tone at 10 since i read this. i have so much room to play with!
#19 (permalink) | |
#20 (permalink) |
call for a sticky again. looks like snaredrum seconded, any 3rds?
#21 (permalink) |
hell mazzy, you 3rd and i'll 4th
#22 (permalink) | |
![]() Join Date: Nov 2007
Never too old to try a new trick, I thought I'd see what happens if I followed this advice... Not millions of miles away from what I usually do, but enough to make a difference. I actually cheated a bit and rolled the tone control off a tiny bit on the neck pickup while I was setting up the amp tone controls.
Splattle, you're a legend! Really getting into the BBRI, Powerbrake and R9 with OTPs, RS Superpots and real bees. Couple of gigs this weekend and had a real killer tone (rhythm intros on the bridge pickup with all the controls up was razor sharp and warm at the same time, but removed the tops of people's heads! Neck pickup just sublime...) More and more into using the controls interactively now, pedals still get used, but not half as much. Quote:
Thanks again for the brief tutorial, definitely set this "old dog" in a new direction. Liam |
#23 (permalink) |
I can't tell you how much this has helped me! Thank you so much! I have a Fender Blues junior and the low end can sound pretty farty and muddy. I eq'ed the amp for the neck pickup and set the tone and volume controls how you said. It improved the tone of my overdrive so much! It went from farty and muddy to creamy and smooth! Now granted it still sounds a little farty because of the small cabinet, but it still sounds WAY better. Thanks so much dude!
+5 on stickying this! This thread can help so many people!
Guitars: Gibson Les Paul Studio, Ibanez AEG20E Amp: Fender Blues Junior Pedals: Boss BD-2 Blues Driver, Boss SD-1 Super-Overdrive, Boss DD-20 Giga Delay |
#24 (permalink) |
Excellent post Splattle.
I must be playing about 15 years now and I dont think I have ever EQ'd for the neck p'up. DOH!!! I look forward to trying this at the weekend when I get rid of the wife and kids for a few hours.
#26 (permalink) |
I always thought that people tended to use the neck for Rhythm and the bridge for lead? Obviously it is not a hard and fast rule.
#27 (permalink) | |
![]() Les pauls are so nice. Lots of tones, so little time.
#29 (permalink) |
i was watching freebird the movie, and i'm sure gary rossington switched to neck for some solos. sounded ace
#30 (permalink) |
There are many examples of neck pickup solos. Have a listen to Shine On You Crazy Diamond. I don't care what kind of guitar it was played on, it had a healthy dose of neck pickup involved.
...any number of Cream songs... ...Blackmore with Purple (yes, it was a strat, but still neck a lot of the time) ...what about the intro to Since I've Been Lovin You? And most of the verses... ...what about Gary Moore and Still Got the Blues?!!??!! I mean, really. Neck pickup for rhythm only? I don't think so... [EDIT]Sorry if this post seems a bit negative or garoul...garrou...gar...argumentative. I just got back from the pub...watching hot young girls bending over and groaning... [END EDIT][EDIT 2]That'd be the TENNIS, you depraved sods!! Whatever did you think I meant??!![END EDIT 2]
| How Do The New Controls Work?? | hipofutura | Gibson Les Pauls | 1 | 04-17-2009 08:55 PM |
| The Volume and Tone Controls - Do You Use Them | David P | Gibson Les Pauls | 62 | 04-15-2009 02:58 AM |
| PCB Controls? I know, I know but this is different! | Last | Gibson Les Pauls | 1 | 02-05-2009 12:54 PM |
| tone controls basically broken | leftylover | The Custom Shop | 4 | 01-26-2009 12:50 PM |
| Where To Set Guitar Vol. Controls | Classicplayer | Tonefreaks | 13 | 12-01-2008 07:29 AM |
