#1 (permalink) |
Caps in Ohms?
I know a guy who owns a music store and they used to do TV and radio repairs in the 70s. They have a drawer FULL of capacitors. But they have them all organized in terms of ohms, which I've never heard of because they don't know the exact voltage? So what would a 0.022uF cap be in ohms if anyone has a clue?
My Gear: 2006 Epiphone Les Paul Standard plain-top HoneyBurst 1995 Peavy Predator Traynor YCV-40 |
#3 (permalink) |
Re: Caps in Ohms?
if I remeber correct from my electronics classes, way back when, you cant measure capacitors with an ohm meter. you would get infinate ohms....
a capacitor is 2 metal plates separated by a dielectric, or something like that. there is no physical contact of the plates inside. It is kind of like a quick charge battery of sorts.... could be wrong, it has been a while. you need to sort through them to find .022uf printed on the cap... ed |
#4 (permalink) | |
Re: Caps in Ohms?
Thats why I was confused by this way of ordering. The formula in the Impedance which is measued in ohms for caps is 1/(2*pi*frequency*capacitance) which makes no sense in a guitar because the frequency is always changing.
#5 (permalink) |
Re: Caps in Ohms?
you are correct jesse, impedence is the resistance of an ac circuit.
if I remember, a cap in a circut,(sp) like a guitar, which is producing an ac current from the pickups, is used, along with the pots, which are variable resistors, is just a filter circiut, for filtering out certain frequencies. but then again, you probably know all that...lol There must be a standard frequency used to determine the farads of the capacitor, along with the formula. Your college instructor may be of help here. but it is most likely easier, go to radio shack, or order online, stew mac, warmoth etc, all have caps. Some guys it seems like to use the big ol' caps from old tvs and such, but remember, caps deteriorate over time and change values or dont work at all. More so the old caps that have had a lot of high voltage run through them... ed ps, good luck with your college coarse, it is a rewarding area to get into... |
#7 (permalink) | ||
Re: Caps in Ohms?
My hope would be that the units were mislabeled on his storage bins.
It does make sense in a guitar. As the frequency varies so does the reactance of the capacitor. As can be seen from the formula you provided, a capacitor's reactance which is the majority of its impedance is inversely proportional to frequency therefore, the lower the frequency the more the capacitor resists the current passing through it. The higher the frequency, the more readily current flows. So when applied in a circuit in different ways, it can act as a low-pass or high-pass filter. Check out this link: A couple of typical pickup simulations. It's just a few electrical characterizations of Les Paul pickup/volume/tone circuits that I was analyzing. Quote:
I very much agree with vintage caps being suspect. After years of usage these caps typically dry out, change capacitance and/or tolerance, and become physically brittle and difficult to work with as in the picture below: ![]() Broken leads on expensive caps. Jesse, keep up with the studies, it will pay off. Later,
-Todd 1982 Gibson Les Paul Custom Silverburst |
