#1 (permalink) |
Changing a capacitor - what does it actualy do to the sound?
Sorry for such a stupid question, but I'm reading about replacing the stock capacitors with Bubmlebees, Vitamin Qs, Jensens etc...
What do they actualy do? Do they change overall sound of the guitar, or they just help in smoother (or whatever) manipuilation of the tone controls?
![]() In my youth I rocked with a Strat, but with age came an appreciation for class and style... so I bought me a Les Paul. Cherry-red with gold hardware. Goes well with my greys. |
| The Following User Says Thank You to Doctor Dread For This Useful Post: |
#2 (permalink) |
![]() Join Date: Aug 2007
Re: Changing a capacitor - what does it actualy do to the sound?
Doc , all depends if you are changing to the same values and or using vintage over modern wiring, When I put Orange Drops in with my new WCR Fillmores , They truly came alive, the caps that were in there were sucking the life and tone out of good pickups Tones and harmonics just jump right off but then part of that were WCR's incredible pickups too
You can cure the harshness of some pickups with a higher value cap , you can also brighten up a dark front pickup by lowering the .022/400 Value cap
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#3 (permalink) |
Now I see the point... will investigate further.
Thx, Don!
#4 (permalink) |
Doc, What Don said, But keep in mind that the pots will also have an affect or effect on the tone. I like audio taper pots like you find in better guitars. Try different caps, they're easy to change. Make good clean solder-joints. You may not need expensive " Historically Correct" caps to get the tone you want. I have heard some great tone from inexpensive caps. Try .047uf,.022uf,and .010uf, and you may mix them up too...for example a .02 in the neck, and a .010 the bridge.
Anything will sound better than the polyester ones in some newer axes. Whether you use PIO's, ceramic disks, and and electrolytic cans is up to your ear. try to avoid any caps made in China, stick American, Japanese, or German made. Good luck, and keep us posted.
Sometimes it is better to remain silent and be thought a fool, than to open your mouth and remove all doubt... |
#5 (permalink) |
Sorry, I meant to quote lp59aholicDon.
#6 (permalink) |
![]() Join Date: Oct 2007
i dunno about all this hype spending $10 or more on boutique caps. ive been using the radio shack caps 2 for $1.79 for 30 some odd years now with no ill effects.
from what i know about electronics the guitars voltage is too minimal to to utilize the better componants to its full potontial. all i can see is that theyre made to closer specs. whereas the cheapos may be +/- 10% the boutiques will be +/-2% or 1% i think thats what your hearing in the up grade |
#7 (permalink) |
![]() Join Date: Jul 2007
IMO, if you want a vintage tone, the most noticeable change in tone is going to come from PIOs, and I'm a firm believer in vintage Bees.
you can roll off the tone knob and it sounds like you kicked in a wah pedal. Killer, killer tone. |
#8 (permalink) |
+1
'92 Les Paul Studio '96 Les Paul Studio '05 Les Paul Deluxe '07 Voodoo LP Special Traynor YVC-20(stock) Crate Vintage Club 20 WB Pickups:Habeneros,Firewaters,67-07 VTPs,67-07 VTP Hotttsss,Greeny 67's
#9 (permalink) | |
#10 (permalink) |
One of the best things you can do to your tone, if you want a full pickup sound is to take the tone control right out of the circuit... or better yet, the volume control too. Straight to the jack... EVH could tell you more about it.
![]() Not my thing, I prefer to have a few tonal options... but I might cut the tone control off my bridge pickup, just to try it. I'm more of a neck player anyway, and that tone control gets a workout. |
#11 (permalink) | |
F%^&*( EVH, He is just another guitarist, Yeah he may have sold millions of records , he can do what he wants with his tone and guitars, has no bearing on what I do, or want to achieve
#12 (permalink) | |
Location: Malta, somewhere in the mid of the Med Sea. Beyond that, everywhere & nowhere.
All the best! |
#13 (permalink) | |
I think its amazing though, what your pickups actually sound like when the controls are out of the equation. Its like a different world. If they could make a set of pots that were full bypass when you turned them up to 10, I'd be interested... Either that or some nifty wiring trick... Hmmm. |
#14 (permalink) | |
#16 (permalink) | |
Have those on anoter Strat in 250K. Used as a tone, gives you razor sharp trebble but with a slight growl, very nice sound. And if you bypass vol too, guitar turns rabbid. Very aggressive. So the word you are looking for is NO-LOAD.
#17 (permalink) |
I'm putting some lace alumitones into my chambered standard. What would caps possibly do for me?
2007 Les Paul Custom 200x Fender Mary Kaye Relic V-Neck See thru Blond 2008 Fender Custom Classic V-Neck Daphne Blue 2003 MIM Strat Faded Green Metalic A couple of Alvarez Acoustics AMPS: VOX AD60VTX, Micro Cube |
#18 (permalink) |
I've seen no-load pots, and wondered if thats what they did. I always assumed the notch was a complete 'off' switch, but now I see it goes the other way around. I might have to give it a shot.
#19 (permalink) |
If you do, please post results. They produce good results even on cheap single-coils, wonder what they'll do with this powerful humbuckers.
#20 (permalink) | |
![]() Join Date: Sep 2007
Same here...............I have some original bumblebees and vitamins,and can't hear that BIG difference that some say they do.
"Play skillfully with a loud noise." PS. 33:3 MyJams http://www.soundclick.com/bands/page...?bandID=330460 "Sometimes you have to gag on fancy before you can appreciate the plain". |
#21 (permalink) |
Me too! I go as far as orange drops IMO they look Cool. And do not sting me in the wallet.Like the bumble bees.
#22 (permalink) |
hey just to chip in my 2cents worth, i swapped my ceramic caps for russian PIOs. I can't say for sure what it does to the tone since i changed the pups at the same time.But i can safely say, if you're planning to make the switch, you should consider wiring it the vintage way. There's significant treble loss when i turn the gain knob down now. I didn't have that with ceramic caps. |
#23 (permalink) | |
#24 (permalink) |
You can make your own "No Load" pots. I did it for my neck pickup tone control. It's easy, just follow the steps at:
Project Guitar :: Checking DC resistance on your potentiometers It works perfectly. I didn't do it on my bridge because it sounds harsh as it is. I was worried that you might hear a pop or something when it goes to 10, but you don't. I don't think this works for volume controls because the signal side of the pot would have no connection. I just used 1 Meg pots for volume. -Eddie |
#26 (permalink) |
I heartily recommend rewiring your LP. My experience is that is brought out more of a natural wood tone and not so artificial as it was before, and the tone/volume pots actually do what they are supposed to, it will spoil you but for less than $100 - Vintage Mahogany Rewire
#27 (permalink) |
I recently found that somewhat of a treble bleed mod sounds great on my lp standard. I connected the first and second lug on the volume pot together with a sprague .001uf cap and a 90k carbon composition resistor. I did his to each volume pot. I also wired in a momentary kill switch for the neck pickup. I'm also thinking of putting in vitamin Q caps...any opinions?
#28 (permalink) | |
Possum in a bucket. It's what's for dinner. Justin McCorkle uses and recommends: Gibson Guitars Copley Guitars WCR Pickups In Tune Guitar Picks |
#29 (permalink) |
Why would you buy one cap over another? Like Vitamin Qs over Bumblebees, or vice versa.
Current Toys: - 07 Gibson Les Paul Classic Antique (Guitar of the Week) -Taylor 110 - 1991 Soldano Series II Super Lead 60 - Egnater Tourmaster Cab - Korg pitchblack - Boss CS-3 - Dunlop Crybaby - Fulltone Fulldrive 2 - Boss DS-1 (why?) - Hendrix Fuzzface |
#30 (permalink) |
Disciple-of-RobotOverlord
![]() Join Date: Apr 2008
i changed gibsons stock pots and .022 caps to an rs kit with .015 PIO caps and it made a dark, almost unplayable guitar into a nice rock machine.IMHO they make a difference.
2005 Ibanez H.R. Giger Iceman VHT Deliverance 60
| The capacitor thread. | Paul | Tonefreaks | 220 | 10-27-2009 12:23 PM |
| Capacitor Connection | ozone | Tonefreaks | 0 | 04-29-2008 01:28 PM |
| Plugged in sound not jibing with acoustic sound; what gives? | Encinitastubes | Historics & Reissues | 9 | 04-26-2008 11:25 AM |
| How to make guitar sound like banjo and a church bell sound | FLICKOFLASH | Tonefreaks | 7 | 03-23-2008 10:16 PM |
| Capacitor Sleeves? | PoorMan | The Custom Shop | 12 | 11-28-2007 10:51 PM |
