MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Like Tree2Likes
  • 1 Post By martin6string
  • 1 Post By Pickens Slim
Unread 11-30-2012, 09:58 AM   #1 (permalink)
Question on 50's style circuitry
I'm building a 50's style harness for a 335 clone.
I built it and tested it and when I plugged it in it blew my amp.
Could be a coincidence. I have a question though
Looking at the diagrams, because the wire to the pickup connects to the center lug where the capacitor is, it looks like the pickup can never be taken completely out of the circuit, just another 500k of added resistance to it.
Is this correct. The reason that I ask is that I always have a closed circuit to the center lug of the switch even when the switch is open.
The pots test OK, I've re-wired and put heat shrink tubing over each lug of the pots so I can't see the possibility of a short.
Thanks,
Eric
Pickens Slim is offline   Reply With Quote
Advertisement
Unread 11-30-2012, 10:21 AM   #2 (permalink)
Papa's Avatar
Re: Question on 50's style circuitry
Originally Posted by Pickens Slim View Post
I'm building a 50's style harness ....
The capacitor connects to the same lug as the switch in 50's wiring.
They both connect to the center lug for "50's dependent".
They both connect to the outer lug for "50's independent".
Pickup to center lug with capacitor is "Modern Independent".
Wiring Library
Not saying it's impossible, but...
In any case, I don't see how it would blow your amp.
Papa
Papa is offline   Reply With Quote
Unread 11-30-2012, 10:28 AM   #3 (permalink)
Business Closed
As Papa already mentioned, on the volumes, the center lug gets the cap lead and switch lead. The open lug gets the pickup hot lead.
I can imagine any possible reason that the wiring harness would blow your amp.
Papa likes this.
martin6string is offline   Reply With Quote
Unread 11-30-2012, 11:01 AM   #4 (permalink)
I didn't think that the wiring could do it either. Just a coincidence. I wanted to ask before I blow out my remaining amp
My wiring looks correct according to the wiring diagrams that I found in the library. Switch and cap to the center lug of the volume. Pickup to the switch, other lug to ground plane.
The other leg of the cap goes to the hot lug of the tone control. Center lug to of tone control to ground plane.
Unread 11-30-2012, 11:53 AM   #5 (permalink)
Papa's Avatar
Pickens Slim,
Can't tell real well from the pics but, I'm not seeing anything that stands out as being wrong.
If you're worried about blowing another amp....take it to a local G.C. and tell them you might want to replace a blown amp.
Tell them you want to see what your guitar would sound like through some of their amps.
Kidding?
Papa
Unread 12-01-2012, 07:09 AM   #6 (permalink)
chrisuk's Avatar
There are only passive voltages from the pickups in a guitar's wiring - it's not possible to damage an amp in this way. It must be a coincidence.
Some say as a child he was adopted by old growth trees and that all of his tendons are actually topwrapped. All we know is he's called chrisuk.
chrisuk is offline   Reply With Quote
Unread 12-13-2012, 02:10 PM   #7 (permalink)
Heard back from the amp repair place. Cracked solder joints on the tube socket. Should be covered under warranty. So it's was a coincidence.
The harness is installed. I'm still setting up the guitar and learning how to use the controls. But it sounds good to my ears.
Thanks for the replys.
Mookakian likes this.
