MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Unread 10-11-2012, 11:36 PM   #1 (permalink)
How to coil split and coil tap humbuckers
With my current setup 2 volume pots, one tone pot and a 3 way switch can i split both humbuckers seperately and choose which coil i want to use of the humbucker and coil tap the chosen coil of the humbucker? I want the option to use either coil of the humbucker but do this seperate from one another meaning bridge humbucker i choose to use either coil and neck pickup be able to do the samething to basicaly have seperate controlls for each humbucker.
Can this be done if so what would i need to do this? E.g. Push/pull, mini toggle...
Is there a wiring diagram i could use
Thanks for reading
Isaac.t is offline   Reply With Quote
Advertisement
Unread 10-12-2012, 08:49 PM   #2 (permalink)
Indyclone's Avatar
Re: Humbucker mod possibilities
If you go with Jimmy Page #2 Wiring it gives you pretty much everything...
2 independent coil splits, out of phase, and series... 24 or 25 different tones, depending on the schematic
Indyclone is offline   Reply With Quote
Unread 10-12-2012, 10:46 PM   #3 (permalink)
Re: How to coil split and coil tap humbuckers
I came across asif i just wanted two independant controls for each humbucker to split the coil but i also want to be able to coil tap the chosen split coil too if possible with my current setup
